Raspberry Pi Forum WIPI (wifi) adapter trouble with RPI version 2
  • Replies 13 replies
  • Subscribers 685 subscribers
  • Views 3158 views
  • raspberry_pi_space
I ordered and received a first run raspberry pi version 2 when it was first announced and available in the US.  Since then I have had trouble installing various wifi adapters on and getting to work with this unit.  I have several version "B" and "B+" units and they work fine with the wifi adapters I have tried but not on the version 2 and I am beginning to question that there is a problem with the version 2 RPI hardware I have.  I am using the latest RASBIAN build Feb. 16, 2015 build from raspberrypi.org website with any available updates installed on the RPI2.  I am using the well accepted "WIPI" wifi dongle and others that as I said worked fine with the other RPI versions mentioned above.  Can you provide any direction in this matter since it is important that wifi work on the RPI2 project I am working on.
    0 Former Member over 10 years ago in reply to Former Member
    Robert,
    I just set up my wifi although I do not need it as I am using Ethernet.  Here were my steps:
    • Inserted my wifi USB adapter, pulled out the Ethernet cable, and rebooted.
    • Launched wpa_gui.
    • Clicked on Scan.
    • Found my router and double-clicked on it.
    • Entered the PSK (password) value.
    • Waited for a bit as my connection is poor.  Success.
    The following wpa_supplicant.conf file was generated by wpa_gui without any manual editing on my part required:
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    network={
        ssid="<myssid>"
        psk="<mypsk>"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
    The difference in experience might be simply that you have your router security setup not to respond to scans from wpa_gui.
    By the way, did you beef up security AFTER configuring and using the older Pis?  I would guess so.  To scan or not to scan is irrelevant once they have been fully configured with the router's particulars.
    0 Former Member over 10 years ago in reply to clem57
    Clem,
    I believe that Robert found his own correct answer for the problem at hand; I just debugged his "pasting".
    All,
    scan_ssid
             SSID scan technique; 0 (default) or 1.  Technique 0 scans for the
             SSID using    a broadcast Probe Request frame    while 1    uses a
             directed Probe Request frame.  Access points that cloak them-
             selves by not broadcasting    their SSID require technique 1,    but
             beware that this scheme can cause scanning    to take    longer to com-
             plete.
    from https://www.freebsd.org/cgi/man.cgi?wpa_supplicant.conf%285%29
    Robert, you seem to be knowledgeable in the  wpa_supplicant file.
    I have a small problem and maybe you can help me.
    I have a iBox nano SLA 3D printer and I am trying to get it to talk to a local belkin N150 router.
    This router is just local , not on the net, just to talk to the iBox.
    Here is a copy of the wpa_supplicant.conf I was told to use from the iBox people.
    'ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    network={
    ssid=“jml31347”
    psk=""
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    Is this file setup correctly ?
    I do not wish to use any type of security or pass code. I is just so I can use a browser to print with.
    This is the only interface provided for printing to the iBox nano.
    Joel Leathers
