Raspberry Pi Forum Connect analog cctv to RPI 2
  • Replies 12 replies
  • Subscribers 709 subscribers
  • Views 8540 views
  • cctv
  • raspberrypi
  • analog
I am working out for my project and I want to use my old Analog CCTV and connect it to RPI 2. Is it possible to connect the analog cctv to RPI pins without using any converter? Anybody who can help me with this?
I am a nube by the way and still don't know the tracks. But I want to learn and expand my horizon.
Thanks for the help in advance.
  • Problemchild
    Problemchild over 10 years ago in reply to e14 Contributor
    Nope most probably  not have a look at those cheap USB VHS to DVD capture  cards as I said they are only around £10
  • rew
    rew over 10 years ago in reply to Problemchild
    John Alexander wrote:
    how do you know he doesn't mention it you are assuming
    It's subtle. It was in the way it was worded that I picked up that the intent was to connect a camera.  But yes, maybe I was guessing, and guessed correctly.
    CCTV effectively has a 0.3 Mpixel resolution. I.e. when you wave your hand at the camera you can say: "Hey that's me, waving" when you watch the recording.  But when something actually happens, too often you end up with images that make it hard to recognize people.
    Nowadays cheap USB webcams can allow much higher resolution and thus better quality in case you end up needing the footage.
    With my raspberry pi camera extension kit, you could also get a 2 Mpixel video and 5 Mpixel-stills camera and then place it a few meters away from the 'pi. Less neat plastic packaging than with a webcam, but it will optimally use the hardware of the PI to say compress the fullHD stream to something you can archive.
