Raspberry Pi Forum Is the Raspberry Pi Forum Broken ?
  • Replies 34 replies
  • Subscribers 705 subscribers
  • Views 7949 views
o.thornwall
o.thornwall over 3 years ago
Hello All !
I recently purchased a Raspberry Pi 4, only to find out the wifi does not work.
I purchase it from CanaKit.
Sadly to say CanaKit are no help other then they told me to "Go to the RP forum and ask them" (or something almost exactly like that)
So I tried to log into the RP Forum only to find after about 15 tries, I got no where. Can't get in or cant even get a email response for the forum administration.
Anybody know what is going on with the RP forum ?
And does anyone have any good suggestions on how to (or where to) get my RP4 fixed ?
Thank you all ! Standing by !
  • cstanton
    0 cstanton over 3 years ago in reply to o.thornwall
    o.thornwall said:
    Who said I considered you an admin ? you just showed up. So your assuming I'm considering posters of this forum as admins of RP forum ? You assume wrong. And who's "WE" ?
    I'm not responding to my self. You assume wrong again. I'm adding info to my response to help others who are trying to help
    Woah there, take a step back.
    In this case I often use the 'we' as 'element14 Community' I'm a community manager here - because Raspberry Pi products have 'element14' branding on them, often times people come to the element14 Community and assume members and staff here also work for Raspberry Pi - which's unfortunately not the case because I'm sure it would be beneficial a lot of the time, but we do have some contact with people from the Farnell/Newark/element14 apac online stores.
    o.thornwall said:
    I'm adding info to my response to help others who are trying to help.
    Oh yeah, totally, I was adding that commentary as a "that kind of behavior on other forums, people take issue with" because some people subscribe to the old notion of 'talking to yourself and bumping threads is bad', it wasn't something I was pointing out as an issue here.
    o.thornwall said:
    Copy and paste does not work for me.
    Clicking the Insert menu does not open my file cabinet.  Maybe you can add some more information ?
    I'm not sure what you mean by your file cabinet.
    When you click on the menu option I showed, you should then be able to click 'upload' that will prompt you to select the files to insert.
    o.thornwall said:
    Thank you for the help you offered that is/was useful, have a nice day
    Yeah, I hope that a solution can be found to your problems Slight smile
    0 Jan Cumps over 3 years ago in reply to o.thornwall
    Do you have a pop-up or scripting blocker active?
  • o.thornwall
    0 o.thornwall over 3 years ago in reply to cstanton
    Ok that was helpful information. Now I know a little more about how to install screenshots.
    Thank you for that.
    "File Cabinet" is what windows used to call the "File Explorer" (I'm guessing that is what it is called now?)
    No, I never assumed anybody or anyone on this forum would be employed or affiliated with Raspberry Pi.
    That's a new one one me. I never considered and new (or old) members of this forum would "consider" others member or posters as associated with RPi.
    cstanton said:
    For example:
    - What operating system are you using?
    - Have you tried using a default installation of the Raspberry Pi OS / Raspbian?
    - What is the setup and configuration of your WiFi access point?
    - Are you using 2.4Ghz or 5Ghz?
    - What are your encryption settings on your WiFi access point?
    - What version of WiFi is on the WiFI access point? (802.11a, b, g, n, ac, ax, etc?)
    - Do other devices connect to the WiFi access point?
    - Have you updated the firmware on your Raspberry Pi 4?
    - Have you updated the eeprom on your Raspberry Pi 4?
    - Is the Raspberry Pi 4 in the same room as the WiFi access point?
    Raspbian I believe .
    Wifi setup and config ? Not sure
    2.4 Ghz as far as I know.
    Not sure about the encryption settings.
    Not sure of the version of Wifi.
    Maybe 1 or 2 other devices are connected as far as I know.
    No firmware or eeprom up date. Haven't been able to get online, remember ? IS it possible to download these two updates to a sd then install on the my RP ?
    The RP is less then 50 ft. My laptop has no problems connecting if that helps ?
    I'm browing wifi from a very small business so I do not have full access to there system.
    Below is the screenshot (thanks to your help) of the kit I purchased from CanaKit (for those who are still interested. .
  • scottiebabe
    0 scottiebabe over 3 years ago in reply to o.thornwall
    That is fascinating, thank you for sharing an image of your PI it is in an aluminum tin!
  • o.thornwall
    0 o.thornwall over 3 years ago in reply to o.thornwall
    Correction to CStanton : The "Wifi " is less then 50ft away from the RP when I have it with me.
  • o.thornwall
    0 o.thornwall over 3 years ago in reply to Jan Cumps
    I think CStanton helped me figure this out. Thank you.
    • Vote Up -1 Vote Down
  • o.thornwall
    0 o.thornwall over 3 years ago in reply to scottiebabe
    Actually it seems to ONLY have an aluminum outer band or case, with plastic top and bottom sections. Not exactly as CanaKit describes it on their website product details as I remember. I wouldn't care about that fact either if I could just figure out what this problem with this RP (and the RP forum)
    0 shabaz over 3 years ago in reply to o.thornwall
    What was the issue, and how did you solve it? I'm keen to know, and others might too if they come across this with the same issue.
    The antenna is right at the side. That means the aluminium is right alongside the antenna. That means it is affecting the antenna, regardless that the top and bottom are plastic. It will seriously affect it.
  • o.thornwall
    0 o.thornwall over 3 years ago in reply to shabaz
    I haven't solved the wifi connection issue yet. I was referring to that CStanton helped me solve the "post a screenshot" issue.
    • As for your antenna idea, that is a good reason to take the Pi out of the case to see if it helps.  But the last time I attempted to get  the Pi online, I could see my network on the list of available.  I also attempted to test the PW on my laptop to make sure it was good, but couldn't figure out how to log off line completely on Win1 pro ?
