Raspberry Pi Forum Raspberry pi as a SPI slave
  • Replies 11 replies
  • Subscribers 697 subscribers
  • Views 8137 views
  • slave
  • spi
  • raspberrypi
OriolPascual
OriolPascual over 2 years ago
I need to configure a setup to have two SPI buses, with the Raspberry Pi acting as the slave in both cases. Despite searching extensively, I couldn't find any information on how to achieve this.
My conclusion is that the Raspberry Pi might not be designed for this specific use case, as it seems reluctant to operate as a slave device. However, I'm reaching out to see if anyone has managed to configure it in this way and if there are any resources or documentation available that could help me achieve this configuration.
Any guidance or insights would be greatly appreciated.
  • salmun
    salmun 1 month ago
    If you’re using a Raspberry Pi 4, I’ve published an experimental Linux driver for its BSC SPI slave peripheral: bcm2711-spi-slave-driver. It provides one SPI slave interface through /dev/bcm2711_spi_slave, with wiring and installation instructions. It won’t provide two independent slave buses by itself.
