Raspberry Pi Forum What would you do with 16G of RAM on a Raspberry Pi 5?
  • Replies 33 replies
  • Subscribers 700 subscribers
  • Views 9997 views
  • pi 5
dougw
dougw over 1 year ago
  1. Would you run a larger operating system?
  2. Would you use it for some larger model AI?
  3. Would you use it for running a larger number of concurrent applications?
  4. Would you use it for robotics and ROS or autonomous systems?
  5. Would you use it for video editing?
I would like to see if it is suitable for video editing...
Please comment on what you would use it for or what you think it would be good for below.
  • vmate
    0 vmate over 1 year ago in reply to dougw
    Not anymore. The Pi 5 uses a significant amount of power now, with a lot of x86 PCs actually using less, while having significantly higher performance.
    https://bret.dk/raspberry-pi-5-review/
    The Intel N100 machine uses 10% less power at idle, and 85% more at full load, while being a bit over twice as fast as the Pi 5, for a comparable cost. It also has more and upgradable RAM, more USB ports and video outputs. The N100 also has hardware H264/H265 encoding, while the Pi5 has nothing.
    The only advantages the RPi has managed to keep are the GPIOs, MIPI, and form factor.
    Hooking up a Pi Pico or similar to an N100 machine gives you all the GPIO (and more) back, so realistically, only MIPI and the form factor remain.
  • phoenixcomm
    0 phoenixcomm over 1 year ago
     dougw  option 6 of course! use it as the server to run SmartHab! which needs a Web Service & Jetty for the Java aps.
  • phoenixcomm
    0 phoenixcomm over 1 year ago in reply to vmate
    You are right about the cost, but ( me confirmed Intel basher ) I would get a AMD Phenom II 4 cores CPU & Motherboard and never look back! ~~ Cris
  • SensoredHacker0
    0 SensoredHacker0 over 1 year ago
    Id trade it for a pile of 3b+ or 4b pies.
  • cstanton
    0 cstanton over 1 year ago in reply to vmate
    Not to overlook the processor architecture of course, there has been a lot of increased development on arm in recent years.
  • vmate
    0 vmate over 1 year ago in reply to cstanton
    The issue isn't ARM vs x86 here. It's that Raspberry Pis use close to a decade old technology, while Intel/AMD/Nvidia/Rockchip/etc. are much, much newer.
    The Pi 5's SoC is somehow still on 16nm, a node from 2013, with an ARM core from 2018.
    The N100 uses the "Intel 7" node from 2020, which is an enhanced 10nm process, using a core design from 2018.
    This used to be an advantage for Raspberry Pi, as they were able to make their boards super cheap. However, their prices started going up, and others' prices started going down, and today, an N100 or similar AMD system costs pretty much the same as a Pi, while being more efficient and way faster.
    Or another example: RK3588. It uses the same A76 cores as the Pi 5's SoC, but it's made on an 8nm process(and also has four more lower power cores). As expected, the Rk3588 uses significantly less power than the Pi 5, while being slightly faster most of the time.
  • cstanton
    People have a penchant for one architecture over the other, often for reasons beyond price, which was more my point.
    Do you have links to the source for your information that you can share?
  • vmate
    Sure!
    www.youtube.com/watch
    From 9:49: RK3588 outperforms Pi5 in Linpack by about 75%, being 70% more efficient per watt. There are other benchmarks too, the RK3588 being faster for almost all of them.
    Similar results from here:
    Pi 5 idles at 4.7W, N100 at 4.2W, RK3588 at 1.7W.
    Pi 5 under load uses 11.6W, RK3588 uses 11W, the N100 uses 21.4W
    There is also this, showing the RK3588 being only about 10% faster on average, which seems to be odd,considering the benchmarks from the previous sources, and also doesn't show power consumption data, but here it is anyways:
    www.phoronix.com/.../3
  • kmikemoo
    0 kmikemoo over 1 year ago in reply to cstanton
    cstanton You are right.  I'm one of those people.  So maybe not so much about architecture, but Raspberry Pi has provided me an opportunity to delve deeper into microprocessors than I ever thought possible.  The "ecosystem" is built for "beginners" like me.  How much more powerful or less power hungry other chips are.. totally immaterial to me.
  • battlecoder
    0 battlecoder over 1 year ago
    2 and 4! I love playing around with AI  and artificial vision algorithms, and some of them do require lots of RAM. Coincidentally, their primary use would be for robotics and automation.
