Raspberry Pi Forum Pi Desktop - control power by button
  • Replies 34 replies
  • Subscribers 710 subscribers
  • Views 5412 views
  • rpi3
  • raspberry-pi3
  • raspberry_pi_space
  • pi desktop
pepeel
pepeel over 8 years ago
Hi all
I have Raspberry Pi3. I want buy Pi Desktop and connect it with RPI3 and add mSata hard disk SSD. I use it for home automation application. But i have a problem becuase Pi Desktop has own POWER BUTTON. And one problem which i have before buy is that after lost POWER all RPI3+Pi Desktop no start automaticaly when POWER come back. I must click on POWER BUTTON.
Is any chance to configure this to when power lost and when power lost RPI3 worsk , and then when power come back to RPI3 + Pi Desktop start automaticaly ?
Rpi3 without Pi desktop start automatical but power adapter is connected to RPI3 but when use with Pi Desktop powerd adapter is connected to Pi Desktop(and power is transport also to RPI3 by GPIO or USB)
I need have auto start rpi3+pi desktop because it is use for home automation and when it not start auto , when power lost and come back my home automation control stop working. But when i am away home i can not power On it by button.
Please help me.
  • gadget.iom
    gadget.iom over 8 years ago in reply to pepeel
    Press the power button.
  • pepeel
    And is no any chance to change this to remember last status power? And after lost power automatical start....?
    In normal PC this option is available.
  • gadget.iom
    This is not a normal PC with a customisable BIOS.
    Sounds like you need a PC.
    shabaz over 8 years ago in reply to pepeel
    I agree with gadget.iom
    It also seems you're trying to solve the wrong problem. A good solution wouldn't lose power and risk corrupting the microSD or hard drive/SSD.
    Why not look into backup power (like a uninterruptable power supply or UPS) system. They are surprisingly easy to implement, but need some small bit of electronics design experience unless you can find an off-the-shelf one (which you can, because they exist).
  • gadget.iom
    gadget.iom over 8 years ago in reply to shabaz
    Hi shabaz
    You must've been reading my mind. I've just finished reading this:
    https://www.enigma14.eu/wiki/5V_UPS_for_Raspberry_Pi
  • pepeel
    pepeel over 8 years ago in reply to shabaz
    I use UPS but after ups dead also raspberry power off. And then i must power on manualy( if i use pi desktop)
    But when i connect power plug not for pi desktop but to RPI3 ? Disk mSATA SSD will work ?
    The Pi doesn't have a power button. When you apply power, it boots. You're using an enclosure with circuitry and a power button. If the button works for you, great.
    If it doesn't, at some point you'll have to either
    (a) try it yourself, document precisely (to yourself at least, but you should publish it to help others in a blog post format) and then develop code (scripts perhaps) and some hardware to help you control the Pi in the manner that suits your needs, or
    (b) use a known working design and live with the fact that it isn't precisely what you want unless you experiment and discover how to modify it, or
    (c) - easiest option of all - Bigger battery for your UPS. Simple. Job done!
    There are bits of hardware like SleepyPi that could be used to help you. It requires you to experiment though. If you go this path, please document it to help everyone.
  • pepeel
    Please explaine me more (a) and (b) point...
    (a) requires you to design the solution. It could be a lot of work. If I type any more, I'd be writing scripts and laying out schematics for you..
    (b) - easy, google 'home automation' or 'home automation with pi' to see other people's solutions.
  • pepeel
    But other people maybe not use Pi Desktop to Home Automation to connect Ssd disc.
