Raspberry Pi Forum What would you like to see tested on the Raspberry Pi 4?
  • Replies 50 replies
  • Subscribers 713 subscribers
  • Views 7635 views
  • raspberry pi 4 testing
cstanton
cstanton over 7 years ago
We have a couple of these in the office that we can run software / test some things on - so what would you like to see tested on the hardware that would help to swing the decision for you as to whether or not it's worth it?
I've seen a few questions about Sega Rally running on MAME, questions about h264 encoding, realtime transcoding - for some of these I'd have to find the software/setup but it's certainly do-able.
So let me know, what do you want to see tested on the Pi 4?
    michaelkellett over 7 years ago in reply to michaelkellett
    Some progress in writing data from Pi to FPGA, I'm able to send packets of 2048 words (16 bits wide) in a typical time of about 175us. No errors so far but I've only sent a small number of packets.
    Rate = 23.4 Mbyte/s.
    Next to try and get FPGA -> Pi up to a reasonable rate.
    I'm not quite as fast as PCie (image) but this works without modding the Pi !
    shabaz over 7 years ago in reply to michaelkellett
    Hi Michael,
    Wow, that's very interesting : ) It's making me think all sorts of things to interface to the Pi : )
    michaelkellett over 7 years ago in reply to shabaz
    Well, I have the ability to send data packets in both directions and I don't get errors.
    The sad news is that Pi Reads of the IO seem to top out at about 264ns - the code loop is very simple:
    GPIO_SET(P_FRAME);                // start the frame
    while(word < n_words)
    gpio_regs[7] = (1 << 18);     // set MR high
    //gpio_regs[7] = (1 << 18);
    *data++ = gpio_regs[13];
    gpio_regs[10] = (1 << 18);     // clear MR
    //gpio_regs[10] = (1 << 18);
    word += 2;
    GPIO_CLR(P_FRAME);                 // end the frame
    adding the commented out statements or changing the level of compiler optimisation make no difference at all to the speed, the MR pulses remain at 264ns and the period at 528ns.
    This looks like 32 - 33 cycles of the IO clock (assuming it is 120MHz or 125MHz - I've seen both claimed.)
    It would not surprise me if there is a setting in the processor that could change this - so if any RPi bods are reading this - please let me know !!
    As it is I can transfer 7.575 Mbyte/s into the Pi from the FPGA. It would be so nice to go at twice that speed image.
    @ Christopher Stanton - do you have any RPi contacts you might ask ?
  • urkraft
    urkraft over 7 years ago in reply to cstanton
    I thought that there was some kind of tool on the Raspi to show cpu temperature, but i can't find it on my Pi 4. Was i mistaken? If not, can you tell me where to find it?
    - raymond
  • cstanton
    cstanton over 7 years ago in reply to urkraft
    vcgencmd measure_temp
  • urkraft
    Thank you Christopher!
    - raymond
  • urkraft
    Your suggestion worked just fine, Christopher, but what i was really looking for was the CPU temperature widget. I found out that it is very easy to access in Buster:
    Right click on taskbar --> Add/Remove Panel Items --> [Add]
    Select [Temp Monitor] --> [Add]
    - raymond
    shabaz over 7 years ago in reply to urkraft
    Hi Raymond,
    The widget is still available, I think it's a right-click on the top bar, and then via an option. Or it was in the normal top-left menu. I did manage to get the widget displayed last week, using one of those two methods, so I know it can be done, I just cannot recall the precise steps (I don't have access to my Pi 4 currently to check).
  • urkraft
    urkraft over 7 years ago in reply to shabaz
    Hmmm, don't understand your response to my post. What i wrote was that i was really after the widget which shows the CPU temperature and that i had discovered how to get it. My post included instructions on how to get the widget. The instructions i included in my post was tested and verified by me on the Buster version of Raspian. I posted this information in case there were others who were also interested in using the widget but did not know how to access it (or if one even existed). My post was not a request for information - it was an attempt to supply information for others who may be interested.
    - raymond
    Sorry, I didn't read your entire post. I only read your first sentence.
