Raspberry Pi Projects
Blog Astrophotography with Raspberry Pi cam and telescope then streaming to phone
  • Author Author: itsalivehobbies
  • Date Created: 11 Jun 2017 1:27 PM Date Created
  • Views 2277 views
  • Likes 9 likes
  • raspberry_pi_projects
itsalivehobbies
itsalivehobbies
11 Jun 2017
This post will cover the basics of how I use a 3D printed camera mount to take photos of the moon using a Raspberry Pi cam. My telescope has a 1.5 inch eyepiece but you can download the 3D printable file and adjust the size to fit your needs. I am using a Raspberry Pi 3 running Raspbian, using a regular Pi cam. Then using an android phone app I can take pictures and view them on my phone seconds later.image
I plan to take this setup to some remote locations. I chose to use a GoPro flex arm attachment and SmartiPi case for now so I can quickly attach and remove the Raspberry pi from the telescope. I picked up the flex arm for around $12 on amazon, and the SmartiPi case was about $25 from MCM electronics with a GoPro mount built in. These work for now, maybe bring some zip ties to keep the Raspberry Pi attached, remember the telescope with be slewing up and down, and the Pi may try to fall off!!
I use my phone as a wifi hotspot to create a network to connect the phone to the Pi in remote locations. I've already setup Raspbian on the Pi and pre-configured the network connection, so It connects to the phone hotspot automatically. I've had best result using the android phone app RaspiCam Remote It has a video mode that allows me to see what the telescope sees so I can line up the shot. Try using apps like VNCviewer for remote desktop access, You can then run python scripts to take custom photos. Or use the app RaspManager with it's built in photo system we can take pictures, and download them to the phone quickly,but no preview to line up your shot. Below are photos of the moon taken from the 8MP Pi cam!! Very happy with the results now to take this setup into the mountains for some clearer sky's.
For more pictures and even a video visit It'sAliveHobbies.com Thanks for reading!
    mcb1 over 9 years ago +2
    Nice project. I've used UV4L for streaming, and it allows remote setting of the characteristics https://www.linux-projects.org/uv4l/ Mark
  • itsalivehobbies
    itsalivehobbies over 9 years ago in reply to balearicdynamics +2
    The Pi does not control the telescope positioning... yet. I hope to have the Pi run everything in the future especially because I have so much trouble with the celstron alignment software. INDI Library…
    DAB over 9 years ago +1
    Nice update. You can get what is called a T-adapter, on which you can mount the camera and slide it into the eyepiece tube for a snug fit. The lens on the Pi camera can work as your eyepiece, or you can…
  • itsalivehobbies
    The Pi does not control the telescope positioning... yet. I hope to have the Pi run everything in the future especially because I have so much trouble with the celstron alignment software. INDI Library on Raspberry PI for using Raspberry Pi to control telescope!
    I'm going to try out UV4L streaming next. As they say there are many ways to skin a cat and I tried just one way to take photos through a telescope. I will keep trying other methods. Thanks for all the info!
    Nice project.
    balearicdynamics over 9 years ago
    Very good project!
    It has a lot of interesting aspects that can be applied also in other contexts. Do the Pi also keep in charge the telescope positioning ?
    Enrico
    Nice update.
    The lens on the Pi camera can work as your eyepiece, or you can take the lens off the Pi camera and go to prime focus.
    Either way you can get good pictures.
    A 3D printed adapter for eyepiece projection will work, but can purchase those products already and they make a good solid fit into the telescope tube.
