Raspberry Pi Projects
Blog Candy Dispenser - Seting up the Raspberry Pi
  • Author Author: pvalyk
  • Date Created: 23 Oct 2015 7:34 AM Date Created
  • Views 543 views
  • raspberry
  • python
  • halloween
  • touch
  • pi
  • trivia
  • trick
  • tkinter
  • screen
  • raspberry_pi_projects
  • pumpkinpi2015
pvalyk
pvalyk
23 Oct 2015
First off, let say thanks for being part of this project.
A couple of weeks ago I started assembling my project. The LCD display will come after.
I managed to destroy a servo, by playing with it. Also, I'll simplify the box by using and RGB led.
When I first booted into latest version of Raspbian I ran the Configuration menu. I rebooted, and the ran:
sudo apt-get update && sudo apt-get upgrade –y && sudo apt-get dist-upgrade -y
I must say, I’m programming at work so I’m using putty and connect via SSH to the Raspberry pi.
The Pi’s Ip can be found by running:
Ifconfig
The ip is under inet addr: and might look like 192.168.1. ..
Then I imported the project folder running:
git clone https://github.com/CharlesJGantt/Trick-or-Trivia.git
To follow: modify the code, add more questions and so on.
