Raspberry Pi Projects
Blog Hydrogen Fuel Cell Polarisation Curve
  • Date Created: 16 Jan 2014 3:45 PM Date Created
  • Views 1123 views
  • hydrogen
  • UAV
  • raspberrypi
  • rpiexpert
  • fuel-cell
  • raspberry_pi_projects
e14 Contributor
e14 Contributor
16 Jan 2014
Hi all,
The latest update on my project for the chemical engineering nerds out there, how to get a polarisation curve from my fuel cell using a raspberryPi controller.
Unlike batteries, fuel cells do not lose voltage with time because you can keep feeding it fuel. Much like a car engine keeps working until the fuel is completely gone, whereas a battery has a gradual reduction in it's output with respect to it's state of charge (SOC). However, the voltage does vary with load, and this relationship is captured in a polarisation curve.
Hope you find the video interesting and inspiring, if so please click LIKE!
Regards,
Simon
    DAB over 12 years ago in reply to e14 Contributor
    Hi Simon,
    I don't want to cause you any extra work, I am just identifying the issues that engineers will want to see before they try to adopt the technology.
    Keep up the blogs, I find them very interesting.
    e14 Contributor over 12 years ago in reply to DAB
    I can do voltage with time yes.
    Fuel flow is a touch more complex as I dont have an easy to use mass flow controller, but I will get on it!
    Good post,
    Are you planning to do a curve of the voltage output for a fixed current load over time?
    I would also be interested in fuel use over the different loads as well.
    Just a thought,
