Raspberry Pi Projects
Blog Lean C++ Stream library for Pico
  • Date Created: 17 Dec 2023 5:56 AM Date Created
  • Views 1838 views
  • Likes 9 likes
  • pico
  • raspberry_pi_projects
  • c++
17 Dec 2023
A lean alternative for the C++ IOStream library, sized for embedded systems
The standard IOStream library works great on a Pico, but inflates the code size. In a 2022 CppCon talk "Modern C++ to Impress Your Embedded Dev Friends", Steve Bush presented a lightweight alternative: a FileStream that's perfectly sized for embedded use.
I ported it for Pico. It supports streaming to the Pico stdio supported COM ports: the Pico's USB, a PicoProbe's USB, or the Pico's UART0.
Usage example:
#include <stdio.h>
#include "pico/stdio.h"
#include "filestream.hpp"
namespace mcu
    FileStream debug(1);
int main(int, char** )
    stdio_init_all();
    mcu::debug << "Hello, world!\r\n";
    mcu::debug << mcu::FileStream::RadixEnum::Hexadecimal << 6 << "\r\n";
    while (true) continue;
To use it in your C++ project, you just add a few lines to your CMake file:
# add_subdirectory()
pico_add_subdirectory(lean_stream_io)
target_link_libraries(${CMAKE_PROJECT_NAME}
        pico_stdlib
        lean_stream_io
# adjust to enable stdio via usb, or uart
pico_enable_stdio_usb(${CMAKE_PROJECT_NAME} 0)
pico_enable_stdio_uart(${CMAKE_PROJECT_NAME} 1)
Github repository, with example program: https://github.com/jancumps/pico-lean-stream-io
Steve Bush CppCon 2022 talk: Modern C++ to Impress Your Embedded Dev Friends
The code is Steve's original code written for the conference. I provided an implementation of the _write() function that uses the Pico.C SDK stdio functionality.
Steve Bush referenced material:
  • original github project for STM32L476RG Nucleo development board:
    https://github.com/sgbush/cppcon2022/tree/release/code/sections/4_lean_stream_io
  • presentation used in the talk: https://github.com/CppCon/CppCon2022/blob/main/
  • video (the topic is discussed at minute 31):
    DAB over 2 years ago
    Nice update Jan.
