Raspberry Pi Projects
Blog PIK3A Retro Gaming Table Mk II
  • Author Author: spannerspencer
  • Date Created: 22 Mar 2016 10:45 AM Date Created
  • Views 18271 views
  • Likes 12 likes
  • Comments 44 comments
  • retro gaming
  • rpibeginner
  • retro
  • pi3
  • pik3a
  • raspberry pi
  • raspberry_pi_projects
spannerspencer
spannerspencer
22 Mar 2016
I'm not a fan of Ikea. In fact, it's a place I usually try to avoid, until I discovered that you can hack it's ultra-cheap tables into retro video game systems! You know the one I mean: PIK3A: The Raspberry Pi 3 IKEA Retro Gaming Table.
You guys have been busy making your own versions, which I'm thrilled to be reading about. Keep those photos and top tips coming.
But in the meantime, meet PIK3A Mark II.
Hackin' the LACK
This is, in many respects, the same build as the PIK3A Mk I. The idea came about when I initially bought the square LACK tables that we mounted a monitor in, and added controls to. I was casually keeping an eye out for a table that'd accommodate two players, with six buttons each. You know. A Street Fighter II machine!image
There were definitely options, but the table size makes them prohibitively intrusive for the average living room. So I needed a way to reduce it, while maintaining the full control set.
The answer presented itself in the LACK TV stand; a narrow, 90cm by 26cm table that boasts a shelf and a table top deep enough to accept the joysticks and buttons. By dispensing with the monitor and going straight into the TV, the unit is easily accommodated in your average (well, as average as us element14 types ever really are) front room.
There isn't much to explain about the build that isn't already covered in the PIK3A Mk I. I cut two access holes in the bottom so I could get to the joystick and buttons for each player, and drilled start and coin buttons into the edge as before.
I kept the Raspberry Pi 3 external, mounting it in a case underneath the table top, in the centre. It's still nicely hidden, and there's only a short length of USB cable from the controls into the RPi. The benefits of this are that you don't need any extensions or panel mount connectors for the micro USB input or HDMI output. It also makes it easy to get to the SD card, should you need to.
There's no need for any acrylic or polycarbonate sheeting over the top either, given that there's no screen, making this a quick, simple yet highly effective variation on the PIK3A.
That said, one nice tweak might be coming up with a way to eliminate the HDMI cable and send the video to the TV wirelessly. Any thoughts on that?
  • bwelsby
    bwelsby over 10 years ago in reply to shabaz +2
    Hm yes 12 inputs may not be enough, how about another hack... as in hack a genuine bluetooth keyboard
    e14 Contributor over 10 years ago +2
    You can hack a LG an-wl100 to wireless transmit HDMI and you can buy them for around 15 bucks on eBay. Directions for hacking Hacking the LG Wireless Media Kit AN-WL100W . Not a compact solution but it…
  • ipv1
    ipv1 over 10 years ago +1
    Awesome man!
  • spannerspencer
    spannerspencer over 10 years ago in reply to e14 Contributor
    Hi there! It's covered on the build of our one player PIK3A: The Raspberry Pi 3 IKEA Retro Gaming Table, only in this case you do it twice -- one for each player.
    You loop a ground wire around each button and each microswitch on the joystick, and then take an individual wire from each button (and the other side of the microswitches on the joystick) to the inputs on the Arduino Leonardo. Or, if you're using a different USB adapter, you take the individual wires to the inputs on that. There's a diagram in the link above.
    Hope this helps!
    Wich kind of wiring we need to set up the buttons?
    I am trying to understand that part.
    could u help me please?
    e14 Contributor over 10 years ago in reply to e14 Contributor
    What you want to search for is Sanwa buttons. I'm not a huge fan of them I prefer the US style happ buttons but it's a preference really. You can find ones like this:New 10x 30mm Push Button Replace for Sanwa OBSF 30 Buttons Arcade PC Games | eBay. They have the height your looking for.
    Hey Guys,
    I live over here in the States and I am having a harder time finding "shallow" arcade buttons.  Standard buttons do not work in this MOD.  I built the GEN 1 IKEA LACK table and had to MOD a lot to make it look good because the standard arcade button depth exceeds the depth of the LACK table.  Any Stateside (AMAZON) or brands available over here would be awesome.  Keep up the great work, my three kids and I love the original IKEA table!
  • spannerspencer
    That's correct, yep.
