Raspberry Pi Projects
Blog PiSP Pocket
  • Author Author: theluthier
  • Date Created: 10 Apr 2016 11:28 PM Date Created
  • Views 4451 views
  • Comments 18 comments
  • rpibeginner
  • rpi3
  • gameboy
  • pocket
  • retropie
  • gbp
  • raspberry_pi_projects
PiSP Pocket
theluthier
theluthier
10 Apr 2016
About 6 months ago, I stumbled onto the Ben Heck Show and binge-watched several episodes before deciding to try some hardware modding myself. Here's my first project: The "PiSP Pocket"! I.e. a raspberry pi crammed into a gameboy pocket. The Pi-inside-a-GBP isn't an original idea but I think the dual analog sticks is unique, at least in terms of execution. I was inspired by this photoshopped image.
The specs:
  • Raspberry Pi 3 Model B
  • RetroPie 3.6
  • 2.2" SPI TFT display
  • 32 GB microSD storage
  • 3000 mAh battery with Powerboost 1000c (about 3-4 hours of battery life)
  • Battery status indicator circuit
  • 1 regular USB port, 2 micro USB ports (one for charging)
  • Original GBP power switch, D-pad, start, select, A & B buttons with additional L1, L2, R1, R2, X, Y buttons sourced from a TV remote (all interfaced via Teensy 2.0)
  • 2 PSP analog sticks
  • PWR and ACT LEDs
  • 2 mono speakers (no output from headphone jack unfortunately)
The rpi3 plays N64 perfectly, Dreamcast mostly perfect, and PSP surprisingly playable with a decreased frame rate. I'm quite impressed with the performance compared to the rpi2. It's been fun playing these systems on the nostalgic GBP form-factor. Though my adult hands get a skosh achy after a couple hours of playing heh.
Thanks for looking!
knas5S9e1ycQfRBFG_a7kEtySsxgKMObIWomGlqum4-NyikG664c-fSoUXgbHaJ-3AVCFdZxBy_B9RIlLo7ybbq9q4CEp0ZyRQEKNeilBRHjQvZ42rhq4Hm9qIvxCS5S_y0KuJJsSzmuW5R7fjzwMjWz7SZJTNszNEAWwcEFLIHfXha7C1h9pQCoH0FUzOurJ6d-Yp7W-E60EnYhqlzx88MFhIY1ZXWAS5_60B8cZNXspWCC5M1WgmDtKW0PyYrYpmGSSq2rpWtS4sAlzCPK0ct0KpV3OuQ_DtWvfzZwi8ovBDBITHYd0itvBX0t_wFNg82sDS1E3NSLcr0lve8PNgK4AiWLX1mekWEk1wEuLazSTnkoDP7Rn-VaQZJDqksbmynhS7TWn_a83yl_Msry0Pl3ss2h-1GARZ5SAmJf5MIp3rsXTEC7A-rslElBZqn3zzVu2LjG5huDDm2iz3finENrz1SV7_asktl6OksGlVwkmhUoyBZrcS_EbofAr-koANqWq66XZOM7KJpNs7TU8xZ4D1U27VBWj_AJTHoVBZ8iXpBw7S3buMQ_NHPNHhjIOxXy3A=w3064-h2050-no
hlLTAJAu-fV9P4OWdPerKreq5IFLbUPj7-vwd3SvvB0goUjPZy1S3jTOOvgLc5hYxZylj_w5EsRHsN3GTiA8neMrVpukgop3QZHQHfybHd7kJGBEspw38K05VCNQnimrLclN9AHLDtbebGy1TzVz4NBdIEhGbCk-jIGImI2Rbh3ALz7v2D32fvCVqKPGaN0rfmy0vZd5Z719QGkUN97dB-nOK3zy9mxKD86OXwS6snfelSj3Aheqxsc_Ys_fipsEkxW6M9c6bE6_cQM1xG5refzlyyJd6HphbjoXSeDnjRVK31yKePHxw-LM4BVDIWpQ-Z-s_4tsInBPIE1U73SN1zuj8oNaE8nAT3tQyKjlDXOdZKF9ebvGS4Hg309fQDJ-eVwLddKCtD9sJ6zg7nY0vRudcouoC8syH5c0kMmEwpkeWDgGzkkBeEH7ukcgZMkLOLbF5-NEkOfiC-BOcBjyRktwWmkAd1TuF1Lp5decXgGOWdB3h4Ala2cHa1-_iEMZSUa-trECoKEKy-3BtT7orxwS0Cva9gqXfPq9MXmEaprnBD3rP596CgLknRRW0Qo0lds7xA=w3064-h2050-no7GJq2aQu4PiI67cnNVkNoGwgjRL8zhRFv-btulZbsG4a0HAcuJNLTc_hhXYyiZjcZZlqmobdSAwfp8Dm-wZLiIhAOCiL4LM1mL_H1BovyUDlGqMTI-71KQ4KpBf3bUSyYe7BAyJupOaiELTe8T4Xsz59aRCoycNG_P5HlyoNS85MTV1D4wEbItoyROmwRDg-lSjbzBSHK2aqIQVpSDazG8LWQuagXwtUIESE4Z7WzMyWZiwOdgbpTmaAhWCx7Z16JjuW0HBTuTCmLAPxpJv1eX7dOE1__qwvA-ncLWgTbdbPAGiP1_qr52wh-XSxvdkRHCDdtMAhCjM6qZg8xP1CKU6MfoRc-lw7LzcRrPNW9G2JtnOrykKLYMKh6pN4kw4tFHXYoOlGMA8E70OSDkT6826ObQ7M7Dye79WrvhafMqAQVdjdTnSCC197D7w7-bpe3-lDQN4oN9cQ13A1sSCmMCuv_22RP3wD_X4loz024qDYyTjf2a-WPFWuChuawk1OpnKBONqwpJAr2z8uaLH4pvgVeqsg0JOa-giIbutZB818Lu_gWtmeMy8R1DUySLL7AGiU9w=w3064-h2050-no
ipoxDvv-bxoUQrkOlrYEBhooY3AdxUqeVpUxjOEUWd13qFrYFiyYyb7iSADiw47VMmlE17hgp3zEpVJbaskLbK8HHcjIo-vY9qHuwPKZVmdqXigJjY_LTK0ZOl451NbJFI-CAYccdCCpALIy3xsfsSvCxxQuRHyMeQnQCbdB6RulY8QMBlhztAC1-IUeZ9NxASElZTuvgziI-xKDhidKlSV1ayCobj-MDcwxY0Tnb34s4bf3Tfe-E_-nYMr8E-vMt6ou3RUCzYZXqBxRYjKk7BtTOZGmXQpECz3Ueq9wyIEq2b9lHvmbV1SzMCoaKpPqnr2Njr-Wj6MInPKbYZROAE_GSjZM0jW9C_3Zg2lBy11J6eoF9yf8Zzxx6jRBmRqA5ZmXg1GLEln7QSxFonMJmYo_H-M5dmdaHDqJyXlUZK8LWPn58PdOlfd9a0R4MHshh79AVR-bzyIULORoNLqi9vEb3QeXvOfmrg_AnPaaFaioKNllXS2S3h2u_sS91wilo3ez4E_rvCq5ycq0IpoKVt9BC1TMiMLfGjDXhxnx_CoFEND_foEMgRn_a5r-tBdyIguvUQ=w3064-h2050-no
  • theluthier
    theluthier over 10 years ago in reply to Nate1616 +2
    Thank you, Nate! I've set it to 30 fps with frameskip at 1 and almost every game runs in realtime. So I guess that results in 15 fps. Sounds bad when I put it that way lol...but it renders games quite…
  • clem57
    clem57 over 10 years ago in reply to theluthier +2
    Ben Heck show did the same in one of his episodes. A chip off the old block. Eh!
  • theluthier
    theluthier over 9 years ago in reply to 6paths +2
    Hi Chris - Yes, I cut out pieces of the PCB and used conductive glue to attach wires to the conductive traces. I don't like tactile clicking either. The TV remote buttons have worked great except they…
    How do you connect the buttons and analog sticks?
    Do you know if it is possible to use an analog stick as a mouse? Or will it be too shaky?
  • theluthier
    Updated the original post with a video.
  • clem57
  • theluthier
    theluthier over 10 years ago in reply to aaroNiGHTS
    Hey thanks! Removing all the ports on the rpi3 allowed me to squeeze everything in without having to thicken. It's certainly a tight fit though. It took me several attempts at the configuration before it sealed up nicely.
  • aaroNiGHTS
    aaroNiGHTS over 10 years ago
    That looks so cool. Did having a Raspberry Pi 3 inside force you to make the unit any thicker than a normal Gameboy Pocket, or did it all squeeze in?
