Raspberry Pi Projects
Blog PiSP Pocket
  • Author Author: theluthier
  • Date Created: 10 Apr 2016 11:28 PM Date Created
  • Views 4452 views
  • Comments 18 comments
  • rpibeginner
  • rpi3
  • gameboy
  • pocket
  • retropie
  • gbp
  • raspberry_pi_projects
PiSP Pocket
theluthier
theluthier
10 Apr 2016
About 6 months ago, I stumbled onto the Ben Heck Show and binge-watched several episodes before deciding to try some hardware modding myself. Here's my first project: The "PiSP Pocket"! I.e. a raspberry pi crammed into a gameboy pocket. The Pi-inside-a-GBP isn't an original idea but I think the dual analog sticks is unique, at least in terms of execution. I was inspired by this photoshopped image.
The specs:
  • Raspberry Pi 3 Model B
  • RetroPie 3.6
  • 2.2" SPI TFT display
  • 32 GB microSD storage
  • 3000 mAh battery with Powerboost 1000c (about 3-4 hours of battery life)
  • Battery status indicator circuit
  • 1 regular USB port, 2 micro USB ports (one for charging)
  • Original GBP power switch, D-pad, start, select, A & B buttons with additional L1, L2, R1, R2, X, Y buttons sourced from a TV remote (all interfaced via Teensy 2.0)
  • 2 PSP analog sticks
  • PWR and ACT LEDs
  • 2 mono speakers (no output from headphone jack unfortunately)
The rpi3 plays N64 perfectly, Dreamcast mostly perfect, and PSP surprisingly playable with a decreased frame rate. I'm quite impressed with the performance compared to the rpi2. It's been fun playing these systems on the nostalgic GBP form-factor. Though my adult hands get a skosh achy after a couple hours of playing heh.
Thanks for looking!
knas5S9e1ycQfRBFG_a7kEtySsxgKMObIWomGlqum4-NyikG664c-fSoUXgbHaJ-3AVCFdZxBy_B9RIlLo7ybbq9q4CEp0ZyRQEKNeilBRHjQvZ42rhq4Hm9qIvxCS5S_y0KuJJsSzmuW5R7fjzwMjWz7SZJTNszNEAWwcEFLIHfXha7C1h9pQCoH0FUzOurJ6d-Yp7W-E60EnYhqlzx88MFhIY1ZXWAS5_60B8cZNXspWCC5M1WgmDtKW0PyYrYpmGSSq2rpWtS4sAlzCPK0ct0KpV3OuQ_DtWvfzZwi8ovBDBITHYd0itvBX0t_wFNg82sDS1E3NSLcr0lve8PNgK4AiWLX1mekWEk1wEuLazSTnkoDP7Rn-VaQZJDqksbmynhS7TWn_a83yl_Msry0Pl3ss2h-1GARZ5SAmJf5MIp3rsXTEC7A-rslElBZqn3zzVu2LjG5huDDm2iz3finENrz1SV7_asktl6OksGlVwkmhUoyBZrcS_EbofAr-koANqWq66XZOM7KJpNs7TU8xZ4D1U27VBWj_AJTHoVBZ8iXpBw7S3buMQ_NHPNHhjIOxXy3A=w3064-h2050-no
hlLTAJAu-fV9P4OWdPerKreq5IFLbUPj7-vwd3SvvB0goUjPZy1S3jTOOvgLc5hYxZylj_w5EsRHsN3GTiA8neMrVpukgop3QZHQHfybHd7kJGBEspw38K05VCNQnimrLclN9AHLDtbebGy1TzVz4NBdIEhGbCk-jIGImI2Rbh3ALz7v2D32fvCVqKPGaN0rfmy0vZd5Z719QGkUN97dB-nOK3zy9mxKD86OXwS6snfelSj3Aheqxsc_Ys_fipsEkxW6M9c6bE6_cQM1xG5refzlyyJd6HphbjoXSeDnjRVK31yKePHxw-LM4BVDIWpQ-Z-s_4tsInBPIE1U73SN1zuj8oNaE8nAT3tQyKjlDXOdZKF9ebvGS4Hg309fQDJ-eVwLddKCtD9sJ6zg7nY0vRudcouoC8syH5c0kMmEwpkeWDgGzkkBeEH7ukcgZMkLOLbF5-NEkOfiC-BOcBjyRktwWmkAd1TuF1Lp5decXgGOWdB3h4Ala2cHa1-_iEMZSUa-trECoKEKy-3BtT7orxwS0Cva9gqXfPq9MXmEaprnBD3rP596CgLknRRW0Qo0lds7xA=w3064-h2050-no7GJq2aQu4PiI67cnNVkNoGwgjRL8zhRFv-btulZbsG4a0HAcuJNLTc_hhXYyiZjcZZlqmobdSAwfp8Dm-wZLiIhAOCiL4LM1mL_H1BovyUDlGqMTI-71KQ4KpBf3bUSyYe7BAyJupOaiELTe8T4Xsz59aRCoycNG_P5HlyoNS85MTV1D4wEbItoyROmwRDg-lSjbzBSHK2aqIQVpSDazG8LWQuagXwtUIESE4Z7WzMyWZiwOdgbpTmaAhWCx7Z16JjuW0HBTuTCmLAPxpJv1eX7dOE1__qwvA-ncLWgTbdbPAGiP1_qr52wh-XSxvdkRHCDdtMAhCjM6qZg8xP1CKU6MfoRc-lw7LzcRrPNW9G2JtnOrykKLYMKh6pN4kw4tFHXYoOlGMA8E70OSDkT6826ObQ7M7Dye79WrvhafMqAQVdjdTnSCC197D7w7-bpe3-lDQN4oN9cQ13A1sSCmMCuv_22RP3wD_X4loz024qDYyTjf2a-WPFWuChuawk1OpnKBONqwpJAr2z8uaLH4pvgVeqsg0JOa-giIbutZB818Lu_gWtmeMy8R1DUySLL7AGiU9w=w3064-h2050-no
ipoxDvv-bxoUQrkOlrYEBhooY3AdxUqeVpUxjOEUWd13qFrYFiyYyb7iSADiw47VMmlE17hgp3zEpVJbaskLbK8HHcjIo-vY9qHuwPKZVmdqXigJjY_LTK0ZOl451NbJFI-CAYccdCCpALIy3xsfsSvCxxQuRHyMeQnQCbdB6RulY8QMBlhztAC1-IUeZ9NxASElZTuvgziI-xKDhidKlSV1ayCobj-MDcwxY0Tnb34s4bf3Tfe-E_-nYMr8E-vMt6ou3RUCzYZXqBxRYjKk7BtTOZGmXQpECz3Ueq9wyIEq2b9lHvmbV1SzMCoaKpPqnr2Njr-Wj6MInPKbYZROAE_GSjZM0jW9C_3Zg2lBy11J6eoF9yf8Zzxx6jRBmRqA5ZmXg1GLEln7QSxFonMJmYo_H-M5dmdaHDqJyXlUZK8LWPn58PdOlfd9a0R4MHshh79AVR-bzyIULORoNLqi9vEb3QeXvOfmrg_AnPaaFaioKNllXS2S3h2u_sS91wilo3ez4E_rvCq5ycq0IpoKVt9BC1TMiMLfGjDXhxnx_CoFEND_foEMgRn_a5r-tBdyIguvUQ=w3064-h2050-no
  • theluthier
    theluthier over 10 years ago in reply to Nate1616 +2
    Thank you, Nate! I've set it to 30 fps with frameskip at 1 and almost every game runs in realtime. So I guess that results in 15 fps. Sounds bad when I put it that way lol...but it renders games quite…
  • clem57
    clem57 over 10 years ago in reply to theluthier +2
    Ben Heck show did the same in one of his episodes. A chip off the old block. Eh!
  • theluthier
    theluthier over 9 years ago in reply to 6paths +2
    Hi Chris - Yes, I cut out pieces of the PCB and used conductive glue to attach wires to the conductive traces. I don't like tactile clicking either. The TV remote buttons have worked great except they…
  • theluthier
    Thank you, Nate! I've set it to 30 fps with frameskip at 1 and almost every game runs in realtime. So I guess that results in 15 fps. Sounds bad when I put it that way lol...but it renders games quite playable.
    Running as PPSSPP standalone instead of lr-ppsspp delivers much better performance. But that seemingly launches the emulator as a desktop GUI, so tweaking things has to be done with a mouse and keyboard - pretty lame given the gameboy-ness of the device. And there's always a mouse cursor visible in the upper corner...I believe psp emulation for retropie is fairly new and will surely improve over time.
  • Nate1616
    Nate1616 over 10 years ago
    Great Project Kent!  What frame rate are you getting with the PSP games?
  • theluthier
    theluthier over 10 years ago in reply to jkutzsch
    I purchased a silicon heat sink pad just in case, but I haven't installed it nor have I experience any issues yet. Though I can feel it warming the back of the case noticeably with the more processor intensive emulators like dreamcast and psp. I should note that I decided to keep the rpi3 stock, so no overclocking.
  • jkutzsch
    jkutzsch over 10 years ago in reply to theluthier
    Did you use a Heatsink or are you noticing any heat issues?
  • theluthier
    jw0752 dougw clem57 - Thanks for the encouraging comments! Indeed the pi3 fits juuuust perfectly after shaving the excess board space under the USB ports and a smidge off the length-wise side.
