Raspberry Pi Projects
Blog Rpi - Audio over IP via OpenOB? Assistance please!
  • Author Author: flyboyd
  • Date Created: 9 Feb 2017 12:15 AM Date Created
  • Views 1014 views
  • raspberry_pi_projects
flyboyd
flyboyd
9 Feb 2017
I'm looking at building an AoIP link using a pair of suitable Rpi's with Wolfson / Cirrus audio boards.
Audio In/Out would be analog. The Ethernet link would be extended using Ubiquity wireless long range access point devices set up as a wireless bridge.
I'm getting a wee bit lost trying to determine the most suitable combination of Rpi board, audio board, and OpenOB version. I also have a strong preference for a board combination that is drop-in compatible with an existing & readily available case such as the Camdenboss Wolfson board case (from what I can gather, this seems to be designed for the older Rpi boards which are no longer available?).
My intention is to set this up as a more or less embedded system that I can plug in, turn on, and send / receive audio.
I'd appreciate some help figuring this out. I'm not really concerned about having the latest & greatest, but rather the combination that is most likely to just work, with as little troubleshooting & fiddling around as possible.
# I work as an audio / light tech, and also as wireless installer for a small ISP using Ubiquity equipment. Although I prefer to use Ubuntu based Linux OS's such as Mint for my daily computing, I'll be the first to admit that I'm not much of terminal / code guy - my configuration requirements for work are VERY basic. I can get a bit of help from our chief technician, although his available time is limited. I can however follow sufficiently clear instructions image
  • bkortleven
    bkortleven over 9 years ago
    Hey guys,
    A while ago, I was able to install and use the OpenOB on a RPi without any issue, using an older RPi 1 board and the good old Wolfson addon audio board. Problem was that the RPi 1 isn't fast enough for high quality low-latency audio links, but the system does work as it should. I went with embedded mini PC's, Atom-based CPU's and a 16GB SSD...
    If there is anything I can help with, please specify where you are stuck, and I can check if I can assist in any way?
  • kylelmartin
    kylelmartin over 9 years ago
    I'm trying to do the very same thing.
    Some people on this thread appear to have had some luck - Anyone any experience of installing OpenOB on RPi?
    If you have any progress on this would you please post here.
    I'm trying to set up a private pipeline for high quality audio to serve as a radio station STL.
    Thanks
