Raspberry Pi Projects
Blog RPi Haunted Foginator
  • Author Author: jkutzsch
  • Date Created: 16 Oct 2015 5:55 PM Date Created
  • Views 681 views
  • raspberry_pi_projects
  • pumpkinpi2015
jkutzsch
jkutzsch
16 Oct 2015
Project items came in!
List of items staring in the center and spiraling out clockwise:
1.  The Raspberry Pi Sense Hat.  Key to the project.
2.  The Raspberry Pi board.
3.  Adafruit 8 channel level shift
4.  Adafruit Neopixel Stick 8
5.  Visaton Speaker
6.  Element 14 Wi-Pi
7.  ABS Case, Grey
8.  8gb Rasperry Pi card preloaded with Noobs, (8gm microsd with in SD adapter)
9.  Velleman-kit, 2x52 amplifier
Going through the project information item I will need that I don't have spare will include an IR sensor and Relay to sense and trigger the Foginator.  Plus some extra large (20mm) gpi Header pins for the sense hat.  Possible an arduino board for the Neopixel, but I will research that more later.
The Tin at the bottom was a cool Ouija board mint tin that I was hoping was a little larger then the standard Altoids tin to make a custom Halloween case for the Pi, looks standard size. Though.
Huge Thank you! to Element 14 for including me in this project, I will update as the other parts come in and progress continues.
John K.
  • jkutzsch
    jkutzsch over 10 years ago in reply to DAB
    Due to time constraints, needing this done by the end of the month I will probably keep along the lines of original Foginator project for the Sensehat being used.  But I have a couple ideas already for followup projects that will branch out with SenseHat.
    By the way, this post is from the RPi with Wi-Pi!  So those are now tested good to go!
    Sadly the Ouija Mint tin didn't work.
    DAB over 10 years ago
    Nice box of toys.
    I am very interested in seeing how you use the Sense Hat.
    I have some ideas that it might be useful for.
