Raspberry Pi Projects
Blog RPI Pico Pimoroni Display
  • Author Author: scottiebabe
  • Date Created: 29 Dec 2021 2:42 AM Date Created
  • Views 7028 views
  • Likes 16 likes
  • Comments 10 comments
  • st7789
  • pico
scottiebabe
scottiebabe
29 Dec 2021
Soft 404
  • scottiebabe
    scottiebabe over 4 years ago in reply to shabaz +1
    Deleted
    shabaz over 4 years ago in reply to scottiebabe +1
    Ah, I can help with that bit : ) I too wanted different sizes. For the bitmap fonts, I followed the info in the file st7789py_mpy-master/docs/fonts.html, in the True Type Fonts section. By executing…
    I can't see how to edit the previous message : ( Anyway, an even better solution for the Hershey fonts would be two scale variables, to separately control width and height scaling factors. Maybe that…
    shabaz over 4 years ago in reply to maxpowerr
    These ST7789 displays are great : ) The pin naming conventions confused me for ages, they are different between the boards, some of the code, and the actual function : )
    RES, RST and RS confused me for a while, they all sound the same. Also SDA/SCL is nothing to do with I2C. I tried to write it down, I think this is accurate:
    Name    Alternative Name    Actual Function
    SDA  SPI MOSI
    SCL SPI SCK
    DC RS Register Select (low=Command, high=Data)
    RES RST Reset (low will reset the chip)
    CS Chip Select, can tie to GND
    BLK Backlight (low=off, high=on)
  • maxpowerr
    maxpowerr over 4 years ago
    Nice display. I also recently purchased a display but on a slightly different board.
    IPS_Display_Modul
    You're right, apparently the Vf is max 3.1V. I found a datasheet here: http://www.lcdwiki.com/res/MSP1141/TFT1141-SPEC_V1.0.pdf
  • scottiebabe
    This comment was deleted.
    Anyway, an even better solution for the Hershey fonts would be two scale variables, to separately control width and height scaling factors. Maybe that is gilding the lily too much! :)
