Raspberry Pi Projects
Blog Step by Step Build Trick or Trivia Halloween Candy Dispenser #4 - LED blink test, GUI Interface
  • Author Author: cmelement14
  • Date Created: 25 Oct 2015 5:08 PM Date Created
  • Views 422 views
  • raspberry_pi_projects
  • pumpkinpi2015
cmelement14
cmelement14
25 Oct 2015
While I am waiting for answers about starting Python interpreter in privilege mode mentioned in my previous blog Step by Step Build Trick or Trivia Halloween Candy Dispenser #3, I'd like to continue my journey. This is going to be a short blog about how I work on LED blink.
I wrote a small piece code LED_Blink_Test.py which blinks LED(toggling red/green LEDs every second) until I hit the enter key. It works as expected.
import RPi.GPIO as GPIO
import time
import sys
import select
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(26, GPIO.OUT)
GPIO.setup(19, GPIO.OUT)
state = True
def toggle_leds():
  global state
  if state:
  GPIO.output(26, True)
  GPIO.output(19, False)
  state = False
  else:
  GPIO.output(26, False)
  GPIO.output(19, True)
  state = True
# endless loop until enter key is stroked, green & red LEDs alternately on/off for 1 second
while True:
  while sys.stdin in select.select([sys.stdin], [], [], 0)[0]:
  line = sys.stdin.readline()
  if line:
  GPIO.cleanup()
  exit(0)
  else:
  toggle_leds()
  time.sleep(1)
I used the same pins to drive LEDs as Charles Gantt used in his blog, but I didn't directly connect LEDs to those pins. The reason for it because each pin will consume more than 25mA if they are directly driven by pins. I am not very comfortable to pull such a big current from an I/O pin unless I see it's specified in its datasheet. Some kind of current limit is required. I don't have appropriate resistors to limit the current to 5 to 10mA per pin, however, the kit includes a few diodes, so I put two diodes in serie to limit the current to about 3mA. The LED isn't super bright, but definitely visible when it lights up.
Make sure you run Python in privilege sudo python LED_Blink_Test.py. Otherwise, you will have run-time problem.
To check the GUI interface, I have to comment out all GPIO related statements. Then run python TrickorTriviaQuiz.py and GUI shows up like this:
Stay tune for the next blog.
