Raspberry Pi Projects
Blog Step by Step Building the Raspberry Pi 2 GPS Geocaching Kit - Part III: Trouble-shooting and Get It Work
  • Author Author: cmelement14
  • Date Created: 17 Aug 2015 6:36 PM Date Created
  • Views 833 views
  • geocaching
  • raspberry_pi_gps_kit
  • raspberry_pi_2
  • raspberry_pi_geocaching
  • raspberry_pi_projects
  • geo_location
cmelement14
cmelement14
17 Aug 2015
In Part II: OS Configuration and Software Installation & Update, I showed how I configured the OS and installed software. In this part III, I will show the problem of SHIM and how I made it work.
To test the kit, I first tried cgps program a few times and each time the program timed out and quit in a couple of seconds. Basically there was no GPS fix at all.
Then I tried to print GPS message but still no luck. I issued poweroff command to brought down the kit and started trouble-shooting.
The first thing I did for trouble-shooting was remove the PiFace and still didn't get a fix.
Next, I directly plugged Microstack baseboard onto GPIO pins. And I got the first GPS fix after powering up the kit for a while.
At this point, I was convinced that I had the same SHIM issue like others had. To solve the problem but not touch the Pi2, I ordered a connector (ESW-120-14-G-D from Samtec) and soldered the connector on the SHIM board.
Put all things together and powered the kit up and got GPS fix in a few seconds.
Next, a quick test with the PiFace
Up to this point, I am confident my kit is ready for the fun of programming. If you have any question or comments about my step by step building process, please post below. Thanks for your reading.
    e14 Contributor over 11 years ago in reply to cmelement14
    I have ordered some, but in the meantime I have managed to get it to work by removing the pin spacers on the raspberry pi.  I broke most of the plastic so I won't be able to reuse them, but it allows the shim to fit all the way down and give the piface good long pins to go inside.  Because of the way it is positioned, I may use the header that comes in to relocate the microstack/gps so it can be easier to put somewhere.
  • cmelement14
    cmelement14 over 11 years ago in reply to e14 Contributor
    I got it from Samtec directly.
    This is the same issue I am having and finally got the light to blink steady intervals by removing the shim and piface and directly plugging into the rasppi connectors.  Now if I can only find that same connector that is less than 9 bucks to ship or that won't take 3-4 weeks by coming from overseas!
    DAB over 11 years ago
    Great post showing your efforts to solve the problem.
    Well done.
