Raspberry Pi Projects
Blog Switch My Fogger: Building a relay board for the Foginator 2000
  • Author Author: pettitda
  • Date Created: 29 Oct 2015 6:18 PM Date Created
  • Views 642 views
  • raspberry_pi_projects
  • pumpkinpi2015
pettitda
pettitda
29 Oct 2015
As I read through Charles Gantt's blogs on the Foginator 2000, I saw that he used an off the shelf relay board to switch the fogger on and off.  However, I didn't want to spend the money when I could just as easily create my own relay board.  So, I sketched up the following schematic.  The inputs on the left go to the Raspberry Pi board and the outputs at the top go to the fog machine's remote control.
I pulled the following parts from Seeed Studio's Arduino Starter Kit to build the board.  The perf-board was purchased separately.
Part
Manufacturer
Manufacturer's Part Number
R1VariousVarious
Q1On SemiP2N2222A
D1Diodes Inc1N4001
RY1Tianbo
HJR-4102E-L-05V
Perf-boardRadio ShackN/A
I assembled the circuit on the perf-board, using the extra component lead lengths to connect the parts together.  Then I added wires to connect up to the Raspberry Pi.  Using Charles' python code and a PIR sensor from Radio Shack, I was able to successfully switch the relay upon motion.  Here's a close-up of the completed board and a picture of the test setup.
Now, I have a relay board of my own creation that I can re-use in future projects when needed!
  • pettitda
    pettitda over 10 years ago
    I forgot to mention that the resistor value was 2.2Kohm.
