Raspberry Pi Projects
Documents Raspberry Pi Weather Station Project
  • Author Author: jcasiello
  • Date Created: 1 Jun 2016 4:00 PM Date Created
  • Last Updated Last Updated: 10 May 2021 6:52 PM
  • Views 9985 views
  • Likes 20 likes
  • Comments 20 comments
Using SenseHAT, InitialState Cloud Service and your Raspberry Pi, create a working Weather Station
Overview:
This kit helps to build your own local weather dashboard, capturing the weather inside and outside your house or office over time. This super-fun and easy project will leverage the Internet of Things (IoT), using the new Raspberry Pi 3 with built-in WiFi, a Sense HAT, and the Initial State cloud platform. Raspberry Pi will capture all the sensor data from SenseHAT and stream it directly to the cloud and this stream of data/information can be monitored or displayed in a professional graphical fashion which can be accessed from your smartphone or computer from anywhere in the world with just a few button clicks.
  • Project level: Beginner
  • Approximate time to complete: 20 minutes
Get the kit:
SenseHAT Weather StationSenseHAT Weather Station
(you can remove individual item(s) at the cart )
Project requires:
1. Raspberry Pi3Raspberry Pi3
2. Translucent EnclosureTranslucent Enclosure
3. 16GB MicroSD card preloaded with NOOBS16GB MicroSD card preloaded with NOOBS
4. Raspberry Pi Sense HATRaspberry Pi Sense HAT
5. Pi3 Power Supply 5V, 2Pi3 Power Supply 5V, 2A
6. 7" Pi Display7" Pi Display or HDMI monitor with HDMI cable
7. Keyboard & Mouse (for HDMI monitor)
Option 1: Follow the instruction if you have downloaded the full Raspberry Pi project images from element14 community.
Instructions:
1.  Download the full Raspberry Pi image with demo code from here
2.  Insert the uSD card into your computer SD card reader and write the downloaded imaged into uSD card using image writing software like “Win32DiskImager”, wait for the write to complete. Exit the imager and eject the SD card.
3.  Insert the uSD card into Raspberry Pi and boot the system. Now connect your Raspberry Pi to the internet using WiFi setup utility and make sure you are connected to the internet.
4.  Go to the www.InitialState.com and signup for a free account.
5.  Now login to your InitialState account, click on your username in the top right, then go to “my account”. At the bottom of the page click on “Create a New Key” to generate your unique key to stream the data. Make a note of this Access Key.
6.  On the Pi Desktop you will find a Python project file named “pi_weather.py” which we need to edit and update with the Initial State unique Access Key.
7.  Now before we move further we need to install Initialstate ISStreamer. Open the LX terminal and execute below command:
$ cd /home/pi/
$ \curl -sSL https://get.initialstate.com/python -o - | sudo bash
While installing it ll ask your Initialstate account credential created under step 4.
8.  Now we need to edit the demo file using editor of your choice, here given example using Nano editor:
sudo nano pi_weather.py
    a. Replace the text “ENTER YOUR KEY” with your Access Key “XXXX”
    b. Save the file with the same name by pressing Ctrl + X (to exit), y (to save the changes in the file, ENTER (to save with the same name).
9. Now run the modified Python file to start the weather station:
sudo python pi_weather.py
10. Go to the browser from your computer or mobile device and login to your initial state account and start monitoring the data.
Option 2: Please follow below instruction if you want to build this project from scratch on you existing RPi Image.
Preparations:
1. Download the Python project filehere
2. Copy the downloaded file into a USB drive
3. Go to the www.InitialState.com and signup for a free account.
4. Now login to your InitialState account, click on your username in the top right, then go to “my account”. At the bottom of the page click on “Create a New Key” to generate your unique key to stream the data. Make a note of this Access Key.
5. Connect the hardware and USB drive
Hardware & Software Setup:
1. Connect all the provided hardware and boot the Raspberry Pi 3 as a standard setup. Now connect your Raspberry Pi to the internet using WiFi setup utility and make sure you are connected to the internet.
2. Setting up SenseHAT and Initial State streamer on Raspberry Pi to stream sensor data to the cloud;
a. Installing SenseHAT. Open the LX terminal and execute below commands:
sudo apt-get update
sudo apt-get install sense-hat
b. Initial State: Open the LX terminal and execute below command:
c. Above two steps will install SenseHAT drivers and Initialstate ISStreamer on to the Pi, it might ask for your Initialstate account credential password to proceed.
3. Now insert the USB drive and copy the downloaded Python file from the USB drive into Raspberry Pi working directly or directory of your choice.
4. Now we need to edit the Python file to enter you unique Access Key. You can use
any editor of your choice, here given example using Nano editor:
a. replace the text “ENTER YOUR KEY” with your Access Key “XXXX”
5. Now run the modified Python file to start the weather station:
6. Go to the browser from your computer or mobile device and login to your initial state account and start monitoring the data.
  • sense hat
  • design_projects
  • rpibeginner
  • projects
  • pi weather station kit
  • raspberry_pi_project
  • raspberry pi
  • weather station
  • raspberry_pi_projects
    DAB over 10 years ago +3
    Nice post. I hope you go into more detail on the sensors and how you handle them using Python. I like the idea of displaying temperature and pressure over time. Both sensors give you a lot of information…
    balearicdynamics over 10 years ago +2
    Very good post. Inspiring for something I have in mind. Really, good. Enrico
  • sufham
    sufham over 10 years ago +2
    Please, tell me if it is possible to include a more comprehensive sensors like wind speed and direction plus the pyrano-meter and perhelio-meter sensors as well. Thanks. Sufi.
  • gkyates
    gkyates over 9 years ago
    I was able to get the zip file to download. I have unzipped the image and installed on the pi. We are working through steps and we keep getting an error message that pi_weather.py can't be found. WE know it is installed as we see it on the pi desk top. What are we missing now? Suggestions?
  • atomar
    atomar over 9 years ago in reply to gkyates
    Hi Greg,
    Looks some issue with your security settings or firewall.
    I just tried and its working fine.....its 1.3GB file and with my current speed its showing max 20-25min.
    Ankur
  • gkyates
    I am having serious problems getting the zip file to download. Is 10 hours the norm? And the first time I downloaded it after unzipping it said it was corrupt. What am I missing? My son needs this for a class project this week.
  • jwatson
    jwatson over 9 years ago
    Thanks for the comment Peter. We'll feed that back.
    In the mean time, check out all RPi projects at Raspberry Pi Projects
    Thanks.
    Jane
    cc jcasiello
  • peterlc
    peterlc over 9 years ago
    It's a great simple little project but would be so much more useful with multiple remote sensors made from ESP8266 module and something like a Bosch BME280 multisensor, feeding back to a single RPi.
  • mbroder
    mbroder over 9 years ago
    super easy tutorial, worked for me in 10 minutes image, thanks a lot!
  • mikev1963
    mikev1963 over 9 years ago
    If Raspberry PI is indoors with 7" screen.  How does the sensor get stats from outside (Temp, pressure, etc..).  I was under the impression the PI need to be outdoors.
  • sufham
    Thanks.
    Sufi.
    Enrico
    Nice post.
    I like the idea of displaying temperature and pressure over time.  Both sensors give you a lot of information about the changing atmospheric conditions.
