RoadTests & Reviews
RoadTests & Reviews
Review Blogs Basic features of hobby grade Digital Multimeter
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: neerajrd82
  • Date Created: 26 Oct 2022 8:03 AM Date Created
  • Views 2247 views
  • Comments 10 comments
neerajrd82
neerajrd82
26 Oct 2022
HI,
      i m Neeraj Gupta. I work in a prominent Defense OEM for developing defense equipment.
 I have 16 to 17 year of experience in solving problems/equipment development using embedded systems. I have created solutions for integration of high-end Defense & Aerospace Electronic Equipment/Weapon systems/communication & control systems required to protect all three dimensions of Land, Air & Sea from external threats. Some of my designs from 2007 to 2012 & in the very recent past have been working on Indian naval ships. I'm presently working in a prominent defense OEM for developing new equipment to integrate command & control systems for air defense applications.  I'm also a design consultant & advisor of various Medium & Small-Scale Enterprises (MSME's) or startups in India including some old & good bigger brand names in Electronics Design & Manufacturing.
  In below video, i m giving my introduction of my current hobby grade Digital Multimeter which is not working correctly.
/cfs-file/__key/communityserver-blogs-components-weblogfiles/00-00-00-00-14/multimeter.mp4
  • scottiebabe
    scottiebabe over 4 years ago +1
    You can get a free working multimeter here :) /products/roadtest/rt/roadtests/600/multicomp_pro_-_digi#pifragment-4100=4&pifragment-4106=9
  • colporteur
    colporteur over 4 years ago in reply to scottiebabe
    There is an idea. You have video-generating skills. Pitch an application to earn a new multimeter.
  • scottiebabe
    shabaz over 4 years ago
    Worst meter ever: ( I received a near-identical one (just missing the transistor tester portion) and it's so bad. The rotating dial is unreliable from new, and the surround smells heavily of plasticizer or other chemical : ) It is also not rated to the specification stated. Strongly recommend you ditch it (it's not even great to hand off to kids, I got them a slightly better multimeter), since you can pick up far better multimeters for $25. For a low price it's likely this would be far better, and it is 6000 count: https://uk.farnell.com/multicomp-pro/mp730007/dmm-auto-10a-600v-6000-count/dp/3014339
  • rsc
    rsc over 4 years ago
    If there is a voltage present when you turn the meter to current measurement, a fuse inside the meter will usually fail to protect the meter.  Check inside for a failed fuse.
    Scott
  • Gough Lui
    Gough Lui over 4 years ago
    You should probably replace the battery in your meter - notice the low-battery warning which usually means that your readings are not dependable.
    - Gough
