RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum How can you do a part 2 of a road test?
  • Blogs
  • RoadTests
  • Reviews
  • Subscribers 2745 subscribers
  • Views 1168 views
robrenz
robrenz over 12 years ago
Is there a way to do a separate part 2 of an existiong road test review? Or do you just edit part one and append it on the end?
  • robrenz
    robrenz over 12 years ago in reply to Dudley
    I did the edit and the part 2 I added was fine but it trashed part one.  Pictures I inserted in part 2 worked fine but when I was done I saw that it also replaced pictures in part one with pictures from part 2.  If I try to edit part 1 now no matter where the cursor is when I add a picture it is inserted at the very top.
    Does a archived version with part one exist where you could just paste the original part one over the trashed part one?
    Thanks for any help.
  • dweb98
    dweb98 over 12 years ago in reply to robrenz
    You may want to try using an HTML Editor to edit your Review, on your Computer and then Copy and Paste it into the Element14 Online Editor. That's what I do. I always use Thunderbird. My favorite E-mail Client App. I have it set to Edit e-mails in HTML Format. I use it to Post to my Personal Blog, every day. It works great, there. I did have some Formatting issues with the Old Element14 Site System. So, I also tried using an old HTML Editing App. That I have used for years.  Kompozer, http://kompozer.net/download.php. And it worked like a Charm!:) All of the odd Spaces are now gone and I didn't have to try and edit them out, one at a time, manually!:) Doing this to text, is a real pain and doing it to links can break them. Kompozer, is an older App and it doesn't look like it is still in development. But, it still works great and it is available for Linux (which I use) and Windows too. You might want to check it out. The New Element14 Online Editor, is much better. But I had similar problems, with my images too. My fix is to just Post my Review to my Personal Blog, first. So, that all images are hosted on my Blog. And then, I just Copy and Paste my Review into the Element14 Editor and Everything works just fine. Here's my last Review on Element14,  http://www.element14.com/community/roadTestReviews/1577 and on my Blog here, DonsDeals: The XBMC Raspberry Pi Solution Bundle from Element14.com - Review and First Experience by Don Bishop. I think it looks better on my Blog, though. You might be able to upload your images to the Element14 Server, as Attached files and then link to them. But in the past, there were problems with uploading images, on the old system. It may be fixed now. I haven't checked. You could also use an Image Hosting site, like Flicker or Google's Picassa and such. Hope this helps...
    Don
  • robrenz
    I did the edit review method.  I am no expert on how the review editor works but I got very flakey behavior with insert picture. No matter where my cursor was when I did insert picture it stuck the picture at the top of the review. I used cut and paste to move it to where it should be and that appeared to work. After making all the changes and posting it I see that it has completely trashed the first part of my review with original part 1 images gone or overwritten with part 2 images.
  • Dudley
    Dudley over 12 years ago in reply to saurocksall
    You should be able to edit it. If you open the review page, to the right of the page is an "Edit RoadTest Review".
    Link to your review for your convenience: http://www.element14.com/community/roadTestReviews/1603
    Shout here if you have more problems
  • saurocksall
    saurocksall over 12 years ago
    Editing would be much easier..
  • Kilohercas
    Kilohercas over 12 years ago
    i guess you can create new blog post, in roadtest place.( Create roadtest review under create button)
