RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum road testing the EFM32™︎ Zero Gecko Starter Kit - Part 4
  • Blogs
  • RoadTests
  • Reviews
  • Subscribers 2745 subscribers
  • Views 861 views
  • RoadTest
  • zero_gecko_starter_kit
Jan Cumps
Jan Cumps over 12 years ago
Part 3: checking the different energy modes
I've gone throught the EFM32 tutorials
Road Test 3: the EMF32 tutorial
The tutorials are integrated in Simplicity Studio. When you select a lesson, you can open the pdf with instructions, and you can generate the template project in the IDE.
The template project has indicators in the source that hint where you should place your code.
The lessons explain how to interprete the Reference Manual, how to use the registers - and how the API works.
The first lessons go into setting and clearing single bits and a range of bits within the registers. This may be common knowledge for lots of us, but it is a nice way to introduce the API's constants, masks and macros that make the code readable.
void initTimer() {
   /* Enable clock for TIMER0 */
   CMU->HFPERCLKEN0 |= CMU_HFPERCLKEN0_TIMER0;
   /* set prescaler to slow down clock by factor 1024, multiple bits so mask needed */
   TIMER0->CTRL =  (TIMER0->CTRL & ~_TIMER_CTRL_PRESC_MASK) |  TIMER_CTRL_PRESC_DIV1024;
The first lessons cover timers and GPIO,
the second set handles interrupts and energy modes.
The third lesson iterates over two of the existing application note examples, and drives you through further refinement of their energy profile.
  • Problemchild
    Problemchild over 12 years ago in reply to Jan Cumps
    The Gecko range certainly seems to get the recommendation for exactly those facilities. I havent seen many projects use them  but I think that's because they are biased to be used in commercial products.
    Thanks for the video BTW it's good to see people making the extra effort.
    Jan Cumps over 12 years ago in reply to Problemchild
    The starter kit will not end up embedded in a project. It will stay in my toolkit, so that I can use it for power management prototyping and profiling. It's the best tool that I have for that at the moment.
    I'm rather impressed by the controller's power save options though. I haven't fully reviewed it yet, but based on my current findings I would consider the EMF32 an excellent candidate for low power designs where I need significant processing power and fast wake-up from the sleep modes. I think that's where it's sweet spot is: nice very low power modes when at rest, and fast wake-up with significant calculation power when needed.
  • Problemchild
    Are you going to use this for a project or for learning/review only?
    I'd be interested in seeing what you do with it after seeing Dave Jones go  on about them so much!
