RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Is there a way to save a draft of my roadtest application before I submit it, as I used to do on the old website?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 9 replies
  • Subscribers 2741 subscribers
  • Views 2894 views
  • RoadTest
kkazem
kkazem over 4 years ago
Is there a way to save a draft of my roadtest application before I submit it, as I used to do on the old website? I'm not seeing any Save Draft button or anything similar. This particular roadtest application will be substantially more lengthy as there are four (4) pieces of equipment tied together in the roadtest. Therefore, it's important that I be able to save a draft overnight so I can pick-up where I left off in the morning.
  • kkazem
    0 kkazem over 4 years ago in reply to phoenixcomm
    @phoenixcomm. Thanks for that link, I'll try it.
  • phoenixcomm
    +1 phoenixcomm over 4 years ago
    kkazem SciTE is here: SciTE Download
    there are binaries for most distros. Winblows, Linux, Unix, Mac and others
    ~~Cris
  • kkazem
    phoenixcomm, Thank you for that tip. I'll give it a try. I was going to use Word, but after your caution, I probably won't.
  • rscasny
    0 rscasny over 4 years ago
    I don't think there is a save draft button. However, just go back to it, and there is an Update button at the bottom.
  • phoenixcomm
    0 phoenixcomm over 4 years ago
    I would and do use a small lightweight editor called SciTE, BTW MS Word does not generate CLEAN HTML. this is a bad thing.
    ~~Cris
  • Dudley
    0 Dudley over 4 years ago in reply to misaz
    It's worth pointing out that you can upload a word document as part of your submission
  • Dudley
    You can just submit it and edit it in the morning.
  • cstanton
    +1 cstanton over 4 years ago
    No, there isn't due to how roadtest applications are now created, they're different to how it was done in Jive.
    Your only option is to either create it off the site, and then submit it when ready, or to submit it and then edit it. It's unlikely it'll be viewed until the deadline date anyway.
  • misaz
    0 misaz over 4 years ago
    I recommend using Word for now.
