RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Seeking Your Interest in Roadtesting Wireless Sensors and Hub of an Industrial IOT System
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 14 replies
  • Subscribers 2663 subscribers
  • Views 3250 views
  • roadtest survey
  • schneider electric
rscasny
rscasny over 3 years ago
Hi all.
I have met with Schneider Electric who makes Wireless Transmitters (Sensors) and a Hub that operates as intermediate equipment between a transmitter and a PLC or industrial PC.
We have primarily discussed roadtesting these products (which I list below). However they are open to a design challenge.
We are interested in learning:
  • How you would roadtest these products (as they are part of a larger system).
  • What your interest level is in roadtesting these products
  • Other than the products listed below, what else would you need
Let me list the products the roadtester would receive:
ZBRTC1 Wireless transmitter (current sensor)
Wireless transmitter, Harmony XB5R, Current sensor, self-powered current monitoring wireless clamp sensor, 0.5…35A
Datasheet
ZBRTT1 Wireless transmitter (Temp/Relative Humidity sensor)
Easergy CL110 wireless environmental temperature and humidity sensor
Operation manual
Webpage
XB5R Wireless pushbutton
Harmony wireless and batteryless pushbuttons are used for remote control of a receiver relay using a transmitter pushbutton.
Webpage and notes
ZBRN1 Harmony Hub
Harmony Hub wireless ethernet gateway, Harmony XB5R, Zigbee green power gateway, wireless to modbus TCP, 24...240V AC DC
Instruction sheet
Datasheet
User Manual
image image image image
Prospective Roadtester Polls
Please vote in our polls. They provide useful insights as we plan for roadtests. Thank You.
  • Robert Peter Oakes
    Robert Peter Oakes over 3 years ago +2
    To go with this based on initial read I would expect you will need a PLC or sorts (I have plenty) that supports Modbus TCP so you can pull in the data, also some kind of display, if your planning on using…
  • Gough Lui
    Gough Lui over 3 years ago in reply to Robert Peter Oakes +2
    Well, if it supports Modbus TCP, I suspect there's no reason you can't just hook it up to an Ethernet network and use pymodbus (or similar libraries) on any computer or SBC to talk to it, assuming you…
    dougw over 3 years ago +1
    I have an interest in Zigbee but have moved away from the industrial automation sector and I wouldn't use this type of automation at home.
    Robert Peter Oakes over 3 years ago in reply to colporteur
    Even if it measured DC, it is only rated to 35A i think, a car starter would almost certainly blow whatever circuit that was connected to unless it had exceptional protection circuits arround it
  • obones
    obones over 3 years ago
    Oh, zigbee, battery less devices, what a nice setup that is here!
    But as a hobbyist, I don't even have the beginning of an industrial setup to put all those to proper use in order to provide an adequate review.
    I'll thus pass on this one but will be eager to read the reviews.
  • rscasny
    rscasny over 3 years ago in reply to Gough Lui
    Yes, this is AC, not DC.
  • colporteur
    colporteur over 3 years ago in reply to rscasny
    Well that throws that idea out the window. Hummm.... sense motor current on grain dryer blowers.
