RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Be Interested in Roadtesting a Current Mode Control DC/DC converter with Fast Transient Response?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 13 replies
  • Subscribers 2740 subscribers
  • Views 3242 views
  • roadtest survey
  • rohm
  • BD9G500EFJ-EVK-001
rscasny
rscasny over 3 years ago
imageI will be roadtesting this product in September. I'd like to get your feeedback, thoughts and interest in this product.
Here are a few facts about the product:
The BD9G500EFJ-EVK-001 uses BD9G500EFJ-LA to output 5V from a 48V input voltage. The input voltage of the BD9G500EFJ-LA is from 7V to 76V and the output voltage is configurable from 1V to 0.97 x VIN V with external resistors. The operating frequency is configurable between 100 kHz and 650 kHz with an external resistor connected to RT pin. This is a current mode control DC/DC converter that provides fast transient response performance and simple phase compensation setup.
Here are a few features of the DC/DC Converter:
  • Wide Input Voltage Range
  • Integrated High-Side MOSFET
  • Current Mode Control
  • Adjustable Frequency
  • Soft Start Function
  • Over Current Protection (OCP)
  • Under Voltage Lockout (UVLO)
  • Thermal Shutdown Protection (TSD)
  • Over Voltage Protection (OVP)
  • HTSOP-J8 package
Here are some documents from the manufacturer:
Datasheet:
User Guide:
Manufacturer's Page:
For More Information
Roadtester Polls
I am considering adding an adjustable DC Power Supply to the kit, Bench Power Supply
    shabaz over 3 years ago in reply to anniel747
    I think there may be some misunderstanding, the 76 VDC is the max input voltage, but a RoadTest is not the same as a test of the specification of the device.
    A RoadTest is a product review (i.e. it is up to the reviewer to decide if a test of parameters to the limits of the specification are something they want in their review or not).
    In reality it is likely near impossible to test everything to the spec (e.g. it may require operation at extreme temperatures and so on) without the actual manufacturer's resources and testbeds.
    Jan Cumps over 3 years ago in reply to anniel747
    which one?
  • anniel747
    anniel747 over 3 years ago in reply to Jan Cumps
    [deleted]
    It's a power electronics design. Also goes to several amps. May get hot. It's part of the trade.
  • anniel747
    anniel747 over 3 years ago in reply to dang74
    [deleted]
    Jan Cumps over 3 years ago in reply to dang74
    That would be a good attack vector for this road test. The switch mode kits are always a good hook to improve your electronics skills, while reviewing the design.
  • dang74
    dang74 over 3 years ago
    I was thinking of using a switching regualtor to serve as a poor man's substitute for a bench top power supply.  The wide operating range of this product in terms of both input and output voltages sounds pretty promising.
  • rsc
    rsc over 3 years ago
    If the output could be raised to 5.3VDC it would be a good PS for a portable Rpi from battery or solar power.
    The Rohm simulation tool is quite nice.. it looks like a normal Spice simulator embedded in a browser, with the circuit and probes all set up. There are "spare" probes at the bottom-right : ) As many of those can be dragged as desired onto the circuit, and new charts appear for them.
  • netaddict
    netaddict over 3 years ago
    I'd love to try this one out !
