RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Introducing OFF THE BENCH RoadTests - What Products Do You Prefer to Test?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 49 replies
  • Subscribers 2663 subscribers
  • Views 5647 views
rscasny
rscasny over 2 years ago
About a month ago, I introduced an idea I call "Off The Bench" Roadtests.
Basically, I would reserve a few roadtest slots per year for products that aren't primarily used on your electronics workbench. It's a fairly simple idea.
In this discussion/poll, I wanted to drill down to more specific products, based on the feedback I had previously received from you.
I have a series of polls below, grouped by product types, more or less. I offer two products and the option to suggest an entirely different product in the comments section.
I will take your voting back to our product management, and I could start lining up "off the bench" products in the coming year.
So, if you have the time, vote as little or as much as you have time for.
Thank you in Advance.
Randall Scasny
RoadTest Program Manager
Hand Tool Kits
Tool Kit, Field Maintenance
More Info
PK 1700NA electronic kit
More Info
Shop Cleaning Devices
Vacuum Cleaner
More Info
imageDuster
More Info
Heat Gun and Heat Shrink
imageHeat Gun
More Info
imageHeat Shrink Kit
More Info
Tapes and Adhesives
imageAdhesive
More Info
imageTape
More Info
Printer Accessories
imageResin
More Info
imageFilament
More Info
The product choices above are not confirmed. So, there is an opportunity to suggest other products. Please do so if you are so included in the comments section.
  • misaz
    misaz over 2 years ago +10
    I would like to add some storage containers like the units which you use when shipping Experimenting with ... components. Farnell/newark have plenty of these storage boxes but documentation is very brief…
  • baldengineer
    baldengineer over 2 years ago +6
    Regarding the vacuum / duster. I know it is more expensive, but I have a Datavac Pro. It's both. I think it would be a better option for a test since it is dual-function. (I'm biased on this one since…
    dougw over 2 years ago +5
    In the heat gun category, I would really like to see a hot plate road test. Newark sells a number of them. They have several uses but few people actually have one because they can be pretty expensive.…
    genebren over 2 years ago in reply to tarna
    I know what you are talking about.  For a long time I used drawers/cabinet for storing components.  The drawers would always dump out, or get messed up.  Finding what I needed was a real challenge.
    Now, I mostly avoid this problem by stocking only SMD components.  But for component stock for prototyping, I use small 'Coin' envelopes (2½" x 4¼") that I put a single value of component into.  I mark the envelope with value, tolerance, etc. Then I store the envelopes in a plastic storage box.  This allows me to flip through the envelopes (which are ordered by value), so I can find what I am looking for.
  • cstanton
    cstanton over 2 years ago in reply to dougw
    dougw said:
    I have some, but for those that don't, a road test would be most welcome.
    Maybe even those that have some would like to compare and review the product, it can help to compare these things with known experiences.
  • Fred27
    Fred27 over 2 years ago in reply to dougw
    I agree digital calipers are a great tool. I have some fairly cheap ones and they're great apart from one thing. I have to take the coin cell battery out between (infrequent) uses otherwise they're dead next time I pick them up. The soft on/off switch leaves it in a state that still draws enough power to drain it. I suppose I could add a physical switch to disconnect the battery, but I haven't got round to it.
  • hifromkatie
    hifromkatie over 2 years ago in reply to Fred27
    I had cheap ones, and they did the job fine, I didn't want or need new ones. But my husband bought me a set of Mitutoyo ones and they are amazing. 2 years in and still on the same batteries, most of the time I don't even remember to turn them off, quite often walk to my desk on a monday to find I left them turned on when I left Friday and they are still there displaying the last measurement. I used to have to remove the button batteries from the old ones to stop having to replace them all the time, but these can just be left on for years!
  • rscasny
    rscasny over 2 years ago in reply to iker46
    Could you recommend one in particular? There are a number of different kinds of testers. It would be helpful.
  • rscasny
    I want to thank everyone for their input. As I stated previously, I'm in the planning stage for this project, so I open to considering products not on my original list. What I will do, is make the final list and present them to the product manager so we can develop a years long "Off The Bench" roadtest schedule.
  • rscasny
    rscasny over 2 years ago in reply to hifromkatie
    Good suggestion. Let me take a closer look. Thanks.
  • baldengineer
    baldengineer over 2 years ago in reply to hifromkatie
    The spare battery I had for my Mitutoyo went bad before the battery in the tool did. No joke!
    genebren over 2 years ago in reply to Fred27
    It is a shame that these tools don't have rechargeable options.  I actually prefer to use my 'dial' caliper as I always know that it will work.
    DAB over 2 years ago
    Emissive IR camera for checking heat distribution on a circuit board.
