RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Seeking Feedback -- Would You Be interested in Roadtesting a Bluetooth®︎5-capable Dev Board?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 18 replies
  • Subscribers 2750 subscribers
  • Views 3809 views
  • roadtester survey
rscasny
rscasny over 2 years ago
imageI am planning on running a roadtest on the following rapid development board for battery-optimized Bluetooth® 5 solutions with the MAX32666 Arm® Cortex®-M4 processor with FPU. The board also has a 6-axis accelerometer/gyro, RGB indicator LED, and pushbutton.
If you have the time, I'd appreciate you voting in the poll below. It helps me gauge interest and the number of kits needed.
Here is some documentation on the board:
MFR page:
Datasheet:
Video
For More Info
RoadTester Poll
  • embeddedguy
    embeddedguy over 2 years ago in reply to shabaz
    I once gave an interview for PhD that deals with localisation using Bluetooth technology. In that, I learned so much about this technology.
    Would be interesting in the future, if this data is fused with GPS to find indoor location of an asset.
  • BigG
    BigG over 2 years ago in reply to shabaz
    I recall that those SP3T switches are tiny, making it almost impossible to hand solder (well for me, anyway). I've been using JLCPCB PCBA service quite a bit recently and it's pretty good if you don't mind spending a bit extra. I must check to see if JLPCB have any of the switches in stock (their range of stock has improved of late too) then I'll get my little board fabricated and assembled. It's very quick too - from order to receipt of finished product is about a week or so.
    shabaz over 2 years ago in reply to BigG
    I was interested at that time too! Pandemic was causing a lot of IC availability issues. I think I eventually decided on which bits to use, and ordered them, but never got around to finding time to work on this, it took so long for all the bits to arrive (and it takes re-learning to recall what the original plan was!). This would take a lot of planning to execute, so it's unfortunately at the back of the queue currently, although it's a highly useful technology!
    Hopefully lower-cost eval boards with the built-in antennas+switches become available to save having to do so much desigh effort.
  • embeddedguy
    embeddedguy over 2 years ago in reply to dougw
    As misaz has said very hard to implement. It requires special antennas as well as API support. SILABs have some good documentation on that...
    www.silabs.com/.../aoa-direction-finding-lab
  • BigG
    BigG over 2 years ago in reply to dougw
    I recall looking into this a couple of years ago. From what I recollect, you need a special dual or triple antenna design for this work where you switch from one antenna to the next and monitor strength of received signal in each antenna. I asked a forum question about tips on how to design a switching circuit, which received some good feedback. It's yet another one of my little projects that never got completed.
     How to build a simple low cost reliable antenna switching circuit
  • hlipka
    hlipka over 2 years ago in reply to robogary
    I think such tests are more a review of the eco-system (compiler, IDE, libraries) than of the board itself. There might be one outstanding criteria (e.g. really low power, high performance, many GPIOs, or whatever), but I would expect these to be highlighted specifically.
  • rscasny
    I'd like to thank everyone who voted. With all your help, I think this poll will be more helpful in my talks with the sponsor than simply a poll asking are you interested or not. Clearly, the interest isn't a yes or no equation. And the voting split is what I would expect: some are more interested than others. I will probably start using this poll more often.
    Randall
  • tarna
    tarna over 2 years ago
    I am currently building home assistant integrations for my home and while I do not have an immediately specific need for this I can imagine a few applications having Bluetooth 5 control utilising something like this.
  • anniel747
    anniel747 over 2 years ago
    Other: No free time far all the paperwork.
  • iker46
    iker46 over 2 years ago
    I don't have a use for it. I have another board for Maxim and I've never done anything with it...
