RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Weller Micro Soldering Kit and Filtration Unit - first test with the nano solder kit
  • Blogs
  • RoadTests
  • Reviews
  • Replies 20 replies
  • Subscribers 2747 subscribers
  • Views 1947 views
  • weller
Jan Cumps
Jan Cumps 8 months ago
The kits for the Weller Micro Soldering Kit and Filtration Unit arrived. I used the pico/nano solder iron to replace an tiny resistor on a multilayer board.
The pico/nano iron is 40 W, and I used a 1.3 x 0.4 mm chisel tip. Lead free solder and the iron at 350° C
I need magnification to do this kind of work. When soldering, I used the magnifying glasses. The pcb photo was taken with a phone through the loupe:
  • technogreek
    technogreek 7 months ago
    Thanks for your honest update and opinion on using these irons/tweezers.  It is helpful to understand their utility.
    Jan Cumps 7 months ago
    Some more rework. Components removed with tweezers. Pads cleaned with micro iron and 3.2 mm chisel. Then components soldered with nano iron and 1.0 mm chisel
    Jan Cumps 7 months ago in reply to cluca1969
    cluca1969 said:
    to improve the quality of your work, you might want to consider purchasing a hot air station
    I have one.
    In this case I'm testing a set of solder irons for a road test.
  • rsjawale24
    rsjawale24 7 months ago in reply to Jan Cumps
    Did some SMD work with a mini hot plate and touch up with a fine tip (900M series) on my Tenma 65W soldering station. resistors and Caps are 0603
  • Arnovsharma
    Arnovsharma 7 months ago in reply to cluca1969
    Totally agree with you!
  • cluca1969
    cluca1969 7 months ago in reply to Jan Cumps
    Good job, to improve the quality of your work, you might want to consider purchasing a hot air station. Personally, this type of soldering tool also helps me. First of all, you don't have to buy something expensive.
    Jan Cumps 7 months ago in reply to Jan Cumps
    middle resistor is a redo with the flux pen
    Jan Cumps 7 months ago in reply to michaelkellett
    I used Amtech flux that has that effect. It's good flux - in particular for hot air rework. A paste when it's applied, then turns into a viscose liquid when soldering. With an iron, it doesn't render shiny joints.
    I purchased a different flux a week ago (EDSYN FL2W) that I haven't tried yet. I'll do a few joints with it.
    I also have a flux pen: SMF, got it from Avnet/e14:
    michaelkellett 7 months ago in reply to Jan Cumps
    Looking at your resistor soldering I think that you would get much nicer looking joints if you used more, or maybe different flux.
    I use Warton Metals Future 315 with leaded solder and it gives very good results.
    https://www.warton-metals.co.uk/flux-pens.aspx
    Its marketed as suitable for unleaded and no-clean. Like all no clean fluxes it does leave some residue and because it's very runny (like water) it spreads out a lot. I usually clean after using it.
    Comparison of the tips. Top ones are for nano, bottom for micro handle:
