RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would you like to review the NI USRP B206mini-i?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 34 replies
  • Subscribers 2743 subscribers
  • Views 1498 views
  • RoadTest
  • USRP B206mini-i
  • fpga
  • sdr
  • e14-NI
OwainM
OwainM 5 months ago
We are exploring the opportunity to offer you the USRP B206mini-i from NI   to review.
What is the B206mini-i?
The NI USRP B206mini-i is a Software Defined Radio (SDR) / cognitive radio witha frequency range of between 70 Mhz to 6 GHz. It contains a user-programmable AMD Spartan-6 XC6SLX150 FPGA and the RF front end uses the Analog Devices AD9364 RFIC transceiver with 56 MHz of instantaneous bandwidth. The board is powered by USB 3.0, and includes connection for GPIO, JTAG, 10 MHz clock reference or PPS time reference input signal.
Details
https://www.ni.com/en/shop/hardware/software-defined-radios/model-usrp-b206mini-i
https://www.ni.com/docs/en-US/bundle/usrp-b206mini-i-specs/page/specs.html
https://learn.ni.com/learn/article/getting-started-with-usrp
  • OwainM
    OwainM 5 months ago in reply to veluv01
    Thank you for pointing out my mistake, we've updated the link now!
  • gam3t3ch
    gam3t3ch 5 months ago
    This is one of those pieces of hardware that immediately sparks a long list of project ideas. The combination of wideband SDR capabilities, FPGA processing, high-speed data acquisition, automation, and integration with existing Raspberry Pi and Python-based systems opens the door to far more than traditional radio projects.
    Without giving away too much, I see opportunities in signal analysis, intelligent monitoring systems, advanced diagnostics, sensor fusion, and a few projects that bridge the gap between RF engineering and other technical disciplines.
    The challenge won't be finding something to build, it's deciding which idea to start with first.
  • veluv01
    veluv01 5 months ago in reply to JWx
    Here's the docs : https://www.ni.com/docs/en-US/bundle/usrp-b206mini-i-specs/page/specs.html
  • JWx
    JWx 5 months ago
    Nice!!!
    It seems at a first glance as comparable to an unlocked ADALM Pluto (probably with better parameters as Pluto is operating outside of silicon specs when unlocked), but key issue would be software support.
    Manufacturer's tutorial shows SDR usage with GNU Radio, so independent/standard software support seems to be present.
    Btw - "Getting started" link (abowe) is returning HTTP404 currently
