RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum RoadTester UPDATE: Field Failures and Reviews
  • Blogs
  • RoadTests
  • Reviews
  • Subscribers 2745 subscribers
  • Views 681 views
  • scasny
rscasny
rscasny over 8 years ago
Over the course of the year, we have experienced several field failures. I recall one board had a broken component, and a few others would not start up (and it was later determined that a semiconductor component had failed.)
While field failures do not occur often, given all the product we send out to our roadtesters, they do occur. In engineering, stuff happens.  In Chicago, we make a special effort to ensure the product we send roadtesters is packaged securely. In general, we don't open the anti-static packaging. There have been a few cases where we have, and I've instructed people here how to handle the boards. Roadtesters themselves should take precautions when dealing with boards that are susceptible to ESD damage.
What to do if a Board Fails
If you determine there is a board failure, make a comment on the roadtest page. Include any data you have gathered (i.e, voltage readings, resistance readings, visual inspection, etc.) Often times, the roadtester group members will assist you in troubleshooting the board and/or devices.
Writing the Review
In some cases, I have sent replacement boards, if that is feasible. I will adjust the deadline to make up for the lost time. In any event, whether a board has a field failure or not, the roadtester is required to write a review. If you had a DOA board, then tell as about it. If possible, suggest root causes of the failure. The review is expected within the 60 day testing period unless a modification has been approved by myself.
Randall Scasny
RoadTest Program Manager
  • hlipka
    hlipka over 8 years ago
    I'm quite happy that I never did run into this situation. But even when you do, there are still thing to review: the manufacturers response to the problem (and help during debugging the problem), you can look at the item as such and so how it can be used, look at the provided documentation, make a teardown (its DOA anyway image and so on. Getting a defective unit surely will not result in the roadtest you intended, but its no reason not to write at least a basic review.
    mcb1 over 8 years ago
    Makes sense to me.
    I suspect some have been using it as an excuse to not meet their obligations, and sadly you have to feel for any prospective employer.
  • geralds
    geralds over 8 years ago
    Thanks, I have taken note, I will pay attention accordingly.
    Gerald
