RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Like To RoadTest a HandTools Kit?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 25 replies
  • Subscribers 2747 subscribers
  • Views 3450 views
  • scasny
rscasny
rscasny over 8 years ago
The RoadTest program has traditionally focused on development boards, test equipment or other kinds of electronic devices. But I was talking to one of our product managers about hand tools. We talked about roadtesting a hand tools kit. We've started talking about it more and more. Then the idea trickled into one of our team meetings which migrated to my desk to talk tools.image
I even started reminiscing about my favorite screwdriver (heavy rubber ergonomic handle with reinforced carbon steel tips). Power screwdrivers are also a dream; I remember having to remove a back panel of a power supply that had 50 (I kidd you not) philips screws with about 10 already stripped or the heads knocked off....I forgot my tap set too! What were they thinking when they designed that.
Anyway, I could do a Randall's Tool Time, but this is about you, not me. The bottom line is:
What's Your interest in a handtools kit roadtest?
Any tool stories you care to share? Feel free to include.
    dougw over 8 years ago in reply to brotherbob
    On my units the table clamp parts are aluminum, the ball is some kind of alloy casting, the jaws are a different heavy (painted) alloy, possibly cast iron, the screws are all stainless steel. The design is extremely versatile and has been cloned by many manufacturers. I'm sure I've seen versions that are all aluminum except for the ball and screws.
  • ntewinkel
    ntewinkel over 8 years ago
    >"Would You Like To RoadTest a HandTools Kit?"
    The right tools (and being able to find them!) make all the difference in a hobby or DIY project being either fun or frustrating.
    So I'm definitely interested.
    And if it means the kind of hand tools I can use to finish up the Trillium trailer project, then my wife will be even more excited about it than me! image
    (There's some electrical, some plumbing, some cabinets, some riveting... but it's getting closer!)
    -Nico
    shabaz over 8 years ago in reply to brotherbob
    Parts of it could be aluminium. I too like using an aluminium vice for light work. I have one a bit like this, it was quite cheap:
    The benefit being I can easily move it around on the table, and can clamp it with another clamp! - quick release clamp - on a table edge if needed. The disadvantage being it doesn't have all the adjustments available with a ball head of course : (
  • brotherbob
    brotherbob over 8 years ago in reply to dougw
    It looks like its made from a softer metal (not steel), any guesses?
  • jdlui
    jdlui over 8 years ago
    Would eagerly apply to this! image
    My first soldering iron was a Heathkit iron (40 W) - it had a clip that could snap on the heater barrel. the clip had a notch that would melt insulation - you melted just at a point, then you could pull the freed insulation off the end.
    Yes, on one side the collar has a cutout allowing 90 degrees.
  • brotherbob
    brotherbob over 8 years ago in reply to kas.lewis
    Once upon a time we had an engineering build lab (gone with the dinosaurs), the guy in charge (Bill Betz) was an old timer, who had built his own perfect wire stripper made from Cu-Ni wire, with a few electrons flowing it melted wire insulation perfectly, a little pull and you had a perfectly stripped wire with no nicks in sight. I suspect there must be commercial versions of this, using batteries, but I have never seen one. I would be the first in line to buy such a game changer (and it had better be called the Betz Cutter).
  • brotherbob
    Can you get that ball joint to go at least 90 degrees from vertical?
  • brotherbob
    I'm a tool junkie, bring it on, and then some more...
    My tool acquisition philosophy starts with the idea that it is good to have two of everything, an el cheapo that can be abused without regret (there is always a need to abuse, and loaning to that pesky neighbour) and the second priced right, that never gets abused and does exactly whats needed, in a way that makes you feel good using it.
    I feel it is impossible to know what a good tool is without experience, so start by buying something cheap and on sale and learn from it, then relegate it to the abused tool box. Then buy the right tool, keeping in mind that feeling good is what its all about.
    Road tests should be an excellent way of discovering tools.
