RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Like To RoadTest a HandTools Kit?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 25 replies
  • Subscribers 2659 subscribers
  • Views 2718 views
  • scasny
rscasny
rscasny over 7 years ago
The RoadTest program has traditionally focused on development boards, test equipment or other kinds of electronic devices. But I was talking to one of our product managers about hand tools. We talked about roadtesting a hand tools kit. We've started talking about it more and more. Then the idea trickled into one of our team meetings which migrated to my desk to talk tools.image
I even started reminiscing about my favorite screwdriver (heavy rubber ergonomic handle with reinforced carbon steel tips). Power screwdrivers are also a dream; I remember having to remove a back panel of a power supply that had 50 (I kidd you not) philips screws with about 10 already stripped or the heads knocked off....I forgot my tap set too! What were they thinking when they designed that.
Anyway, I could do a Randall's Tool Time, but this is about you, not me. The bottom line is:
What's Your interest in a handtools kit roadtest?
Any tool stories you care to share? Feel free to include.
    mcb1 over 7 years ago +7
    Agree 100%. When you first start out collecting tools for your toolkit you have lots of choices and suppliers. It is very hard to know what is a good investment, and why it pays to spend more money on…
    dougw over 7 years ago +5
    I suspect we all have very definite views on hand tools and our favorites of each type, and lots of reasons why we like them or don't like them. Its probably a lot of work but I would like to see separate…
  • kas.lewis
    kas.lewis over 7 years ago +5
    One of the hand tools I would be very interested in roadtesting would be wire strippers. Looking at standards for automotive or aeronautical applications often mention no tool that scores the wire may…
    dougw over 7 years ago in reply to yosoufe
    Excellent points - I find a vise like this to be indispensable, and more than one is very useful.
    http://canada.newark.com/mcm/22-1735/tools-vice/dp/98B9125?st=vise
    dougw over 7 years ago in reply to n5kzw
    Crimpers - great suggestion - everybody needs crimpers and nobody can afford a full set.
    DAB over 7 years ago
    Hand tools are still the essence of any build.
    Quality tools are a must.
    When I started tech School back in 1970, the first thing they did was have us buy quality screw drivers, pliers, wire cutters and a soldering iron.
    I still have them and they all still do the job 48 years later.
    So if you have a supplier with tools, I can give a very experienced assessment as to how well they stack up to what I have used, just be aware that my standards are high.
  • luislabmo
    luislabmo over 7 years ago
    Tools are widely used in different industries and I'm confident is another good topic many members of this community may share in common. I think it makes complete sense to have Tool RoadTests and by judging at the good quality of the many RoadTests available in Element14, I bet many of us looking to get some tools will definitely see the benefit.
    As other members have commented, personally I also tend to target a good quality/price ratio when buying tools and parts, I remember when I started with my electronics/DIY hobby a couple of years ago, it took me about 8 months to decide buying my first crimping pliers: Engineer PA-09 Micro Connector Crimping Pliers, it was a though decision to make, but it paid out well in the long term.
    Luis
  • michaelwylie
    michaelwylie over 7 years ago
    Yes, tools are essential and often overlooked. The fact that unit had 50 screws likely means, I think, that unit had to pass vibration testing and the only way they knew to do that was with more screws. Was there a thread lock on the screws? More screws and thread lock is usually a definite sign of passing vibration testing.
    When I'm purchasing tools, I'm always curious about the less expensive ones. Note the cheapest, just the ones that aren't as expensive. For example, if I buy WIHA I know I'm getting a quality tool. I use this set all the time:
    http://www.newark.com/wiha/32190/15-piece-insulated-screwdriver/dp/10J2022
    What about DURATOOL or MCM? Are they any good? I've used Xcelite cutters, but never their screw drivers - are they any good?
    http://www.newark.com/xcelite/xps600/screwdriver-set-6-pieces/dp/54W1270?st=Screwdriver%20Set
  • brotherbob
    brotherbob over 7 years ago
    I'm a tool junkie, bring it on, and then some more...
    My tool acquisition philosophy starts with the idea that it is good to have two of everything, an el cheapo that can be abused without regret (there is always a need to abuse, and loaning to that pesky neighbour) and the second priced right, that never gets abused and does exactly whats needed, in a way that makes you feel good using it.
    I feel it is impossible to know what a good tool is without experience, so start by buying something cheap and on sale and learn from it, then relegate it to the abused tool box. Then buy the right tool, keeping in mind that feeling good is what its all about.
    Road tests should be an excellent way of discovering tools.
  • brotherbob
    brotherbob over 7 years ago in reply to dougw
    Can you get that ball joint to go at least 90 degrees from vertical?
  • brotherbob
    brotherbob over 7 years ago in reply to kas.lewis
    Once upon a time we had an engineering build lab (gone with the dinosaurs), the guy in charge (Bill Betz) was an old timer, who had built his own perfect wire stripper made from Cu-Ni wire, with a few electrons flowing it melted wire insulation perfectly, a little pull and you had a perfectly stripped wire with no nicks in sight. I suspect there must be commercial versions of this, using batteries, but I have never seen one. I would be the first in line to buy such a game changer (and it had better be called the Betz Cutter).
    dougw over 7 years ago in reply to brotherbob
    Yes, on one side the collar has a cutout allowing 90 degrees.
    My first soldering iron was a Heathkit iron (40 W) - it had a clip that could snap on the heater barrel. the clip had a notch that would melt insulation - you melted just at a point, then you could pull the freed insulation off the end.
