Atmel SAMA5D3 Xplained, Add-On Boards + LCD Bundle
View table of contents ...
Atmel SAMA5D3Have you tried the new Atmel SAMA5D3 microcontrollerAtmel SAMA5D3 microcontroller yet? element14 is giving away 5 of these new boards, along with a bundle of accessory boards to help you get up and running in no time!
The Atmel SAMA5D3 Xplained MCU is a fast prototyping and low cost evaluation platform for microprocessor-based design. It comes pre-loaded with the Linux Kernel 3.10 (LTS), Linux Mainline and Yocto 1.5.1 support. Bare metal developers will also benefit from a complete C software package including many examples to get started fast. The board comes with a rich set of ready to use connectivity and storage peripherals and expansion headers for easy customization. A USB device connector can be used to power the board as well as programming and debugging it.
Product Video
The Accessories
Not only are we giving five of these units away, but we are including a bundle of all-new accessory boards to expand the unit's onboard functionality. In addition to the MCU, you'll receive:
Arduino UNO click shieldArduino UNO click shield. You'll need this to connect your board to the other items below.
Sensor Click BoardSensor Click Board. Measure humidity and temperature on the fly.
Wifi DongleWifi Dongle. Connect your board via IEEE 802.11n, IEEE 802.11b/g, WEP, WPA, or WPA2.
LCD8000LCD8000. Connect your board to the new 4.3-inch touchscreen LCD.
What will you build with your new Atmel SAMA5D3 and bundle of clickboards? Describe your project and you might win one of these fantastic product bundles.
More technical information about these products is attached below.
Good luck from all of us here at element14!
Terms & Conditions
  • Testers will be selected on the basis of quality of applications: we expect a full and complete description of why you want to test these particular products.
  • Testers are required to produce a full, comprehensive and well thought out review within 2 months of receipt of the products.
  • Failure to provide this review within the above timescale will result in the enrolee being excluded from future RoadTests.
RoadTest Reviews
Comments
  • For the case I used the brown cardboard box that the board came in, cutting out a few holes to let cables in and the LCD display out.
    Not the best solution but it works for now.
    I did start on making a 3D printable case for the board but the poor design of the header (the spikes), the 90 degree turn the ribbon cable has to go through and the non-aligned mounting holes makes life a little awkward.
    I will get back to trying to design a usable enclosure once I get the board itself working properly.
    I am currently debootstrapping debian to run from one of the SD card slots. If I get it working I will host an image on my server so wish me luck image
  • Thanks greatly for that information Greg.
    I'm still in process of making a suitable enclosure or test bed to mount all the parts to so they won't move and prevent accidental ESD from happening.
    I don't like the 50 header pins that won't be used just sticking out like that on the LCD adapter board, too easy to get shorted or pick up unwanted voltages as is.
    After educating myself on the specs of this new MPU, and then comparing to what I have as the most powerful PIC platform on hand, I think the hardest
    decision now is "what to aim this thing at" or "things".  Its 850 DMIPS against my best PIC32 micromedia Boards 120 MIPS has me wondering if I can actually
    think of a usage application worthy of its attention? image
    But will give it some job to do for sure.
    Robert.
  • Hiya Robert
    I haven't got round to testing the touchpad as of yet, just trying to get an output before I try an input.
    To get the display working I flashed one of the test firmwares from linux4sam (specifically the v4.3 demo_linux_nandflash_pda4.sh).
    I used http://www.atmel.com/Images/Atmel-42328-Using-SAM-BA-for-Linux-on-SAMA5D3-Xplained_Training-Manual_AN8995.pdf
    as a base for my explorations.
    To write to the frame buffer I can then use
    dd if=/dev/urandom of=/dev/fb0 bs=128k
    Using an image file as above gives a throughput of about 200 frames per second (0.0047 seconds, 0.0048 seconds). If omit the block size I get around 160 frames per second so it might pay to find the sweet spot.
    My next stage is cross compiling some software to use the board as a photo frame which will give me practice with system low level access.
  • Hey Lucie,
    If you have not done the add a power connector job yet, it requires two additional 0ohm bridge resistors to also be soldered on the pads near the DC connectors mount location. R3 and R177 I believe is the boards silkscreen markings for them.
    Xplained user guide has details on this.
    I guess a small bare wire could be used instead of actual shorting resistor chips, but I will probably use a SMD fuse instead as there does not appear to be
    any (cheap to replace) protection on the board.
    Good luck with everything, Robert.
  • Hi,
    There is a datasheet for the LCD? Where did you find it?
    Or are you referring to the datasheet for the controller components?
    I can't find a schematic or PIN assignment for LCD or the Adapter board.
    Robert.
  • Thanks Greg,
    You must have beaten me to the post at the same time lol.
    At least you got that far along. Good job.
    Is the TP functional on that setup, and/or is orientation of the display wrong for doing calibration, if it is connected and trying to do calibration setup routine?
    Robert.
  • Also, Sorry.
    I should have offered insight and/or tips for soldering on MikroElektronika products.  But in case it can help anyone still:
    I would have done this much sooner if I had not also been busy searching for information and needed components support downloads.
    I thought of it while I was soldering mine late last nite and didn't have chance to post it until this evening, so I apologize if it would have been more
    helpful sooner.
    As Peter stated, do not use any solder tools that are not isolated from high voltages. Solder Guns are not to be used also, or anything that uses the induction
    principle to heat the tools solder tip. They will induce damaging currents in to the PCB under work and destroy low voltage/power components.
    If using lead-free solder (and you should, it matches the tinning and solder used on these PCB's), higher temperatures than those used with the common 60/40
    lead/tin solder will be needed, so if using a solder station with temperature control, settings as high as 750 degrees (f) could be needed in order to get good
    solder flow to all surfaces in any connections to be soldered.
    This equates to around a 35-40 watt (or higher) soldering iron that does not have temperature control. Attention to keeping the time the parts are being heated
    should be done to have the time as short as possible, but without causing the joint to be too cold and a bad electrical connection.
    The "old rule" for soldering "let the work melt the solder, not the solder tool." is one I find no longer valid with the lead-free solder in practice.
    Its (the solder's) properties are very different than leaded solder and require a different technique to be used in order to get the proper results.
    The solder you put on the iron tip (tinning) prior to touching the joint to be soldered can instantly be wicked away onto the work parts leaving the
    solder irons tip dry and unable to properly transfer enough heat to allow the melting of the fresh solder you are trying to apply, causing an instant
    "cold joint" condition (sometimes resulting with the feed solder to be stuck to the joint and not melting any further) and requires you to reapply some
    solder to the tip to enable proper heat transfer from it to the work parts.
    I find that feeding the solder to the place where the iron tip touches the work parts and melt enough solder that you can use the tip to drag or push
    the molten solder around to get even coverage of solder on the work parts, gets the best results, but may require some practice to get consistent results.
    The "dry tip" condition should be avoided as much as possible and checked for, whenever it seems the solder is not flowing correctly. If not avoided,
    you may damage the components or more importantly, the PCB copper solder pad because the irons heat is not being evenly distributed to all joint parts and allowing proper flow of the solder and the heat is going into an isolated area if at all. The usual tendency is to keep applying the heat to
    get the solder to flow, but in reality a component could be getting excessive damaging heat levels that should be avoided.
    Most of the soldering of the header pins will go without any problems, but the pin connections that are for electrical ground on the PCB's are the ones that
    need more attention to ensure a good solder connection was made.
    These connection PCB pads have more area of connections to the copper ground plane and thus "sink" more of the solder tools heat away from the work area,
    causing the lead-free solder to harden quickly and possibly (probably with low wattage solder tool) make a "cold connection" that can cause non functionality
    of the device and/or intermittent working behavior. And generate possible interference RF and bad digital serial communications.
    I personally like to adjust the amount the pin that sticks through the pin hole to the solder side of the PCB. Keeping them short and free of any sharp points
    of solder, can prevent damage to any project insulated wiring that does make contact with them, and it is much nicer on your fingers when handling the board.
    They do need to stick out a little from flush to the PCB so a good strength solder connection is possible. Soldering provides both electrical and structural bonding of the soldered parts. Both conditions must be properly met.
    To aid in getting the header pins to be properly aligned and perpendicular to the PCB, it helps if you only solder one pin lightly (one of the end pins is best
    and easiest to get at), then check positioning of the header assembly and make any adjustments by heating the pin you soldered and letting it completely
    cool down before continuing work.
    If the positioning of the header pins is satisfactory, solder the other end of the header assemblies pin connection, then solder pin from opposite end, alternating
    ends and allowing a little cool down time between each solder connection until you reach the middle and last pin to solder.
    To aid in getting the pins perfectly aligned, and you can do this with out dripping solder on the work pieces, you can also insert the long side of the header pin assemblies in to the sockets they will be using and put the Click board or shield board on the short side (proper solder side showing) and carefully
    solder them in place, taking care to not get solder elsewhere and keeping the solder tool away from anything that will melt or be damaged by contact.
    If you are not comfortable doing this for all soldering needed, just solder two pins on each header (the end pins) and after cooled, carefully pry the PCB
    and attached headers from the socket and finish the soldering without fear of damaging the other board(s).
    Be sure to allow enough cooling time between each solder connection so the plastic retainer on the headers does not get melted and loose its additional
    pin support property.
    If using an AC powered solder iron and its wattage is too high for most solder jobs, you can make it a dual wattage iron by making a custom AC outlet
    extension box that has a large high watt diode in the power line and a SPST or SPDT toggle or push-on-push-off switch that shorts across the diodes
    leads, in effect removing it from the circuit.
    This allows the solder iron plugged in to this special outlet to have half of its power cycles blocked and thus reducing its maximum temperature in half
    (approximately).
    A good candidate AC solder iron would be one of 35 to 60 watts of power consumption. Then it would also be operated at 17 to 30 watts on low setting
    of the diode control switch. It does not matter the direction the diode is placed in this circumstance, it just needs to block 1 half of the AC cycles to work.
    (do not use this custom outlet to power anything else, damage to the diode or device plugged in to it may happen!)
    Keep the tip of solder iron clean and tinned with some fresh solder before making a solder connection. A wet piece of natural sponge with distilled water
    is best for cleaning the solder tip of burnt flux and oxidation.
    To clean up the solder connections after soldering is finished, I use an old (clean) toothbrush and denatured alcohol to carefully scrub away the
    residue leftover from the solder rosin or flux the solder may have in its center. Having the PCB held by a PCB holder or solder aid tool is very helpful
    and if it allows for angling the PCB, makes the cleaning job much easier if the alcohol can run off the closest edge (on to paper towel to catch excess and keep
    area from being contaminated by the rosin/flux residue carried by the alcohol) the time/effort needed is less to complete the job.
    Flushing the worked area with alcohol towards the nearest edge may be needed more than once to get all residue removed.
    Do not use any solder that contains acid or is labeled as "Acid Core". If you do not think you can solder competently, have a qualified technician
    do the work for you.
    After cleaning is done, carefully examine your work and look for any cold solder connections and reheat any found or that look suspicious.
    The solder joints should look bright and smooth with the solder flowed to all joining parts surfaces and without any voids or excess solder build up.
    Clippers should be carefully used to remove any sharp points made from solder if can be done without affecting the joints quality of connection,
    otherwise use of the solder iron to fix connection will be needed.
    Reinspect your work and check if pin alignment is correct for the socket they will be inserted into, and if ready to do so, carefully insert the board or shield slowly and evenly in to the sockets until completely seated and header surfaces mated together.
    The boards MikroElektronika produces that have header pin connectors all come un-soldered so the user can use them in a final product or project
    that does not require/need the devices able to be removed or needs to be proofed against vibration or hostile operating environment induced connection losses,
    or use the pin headers and be able to be placed onto many of their development board systems.
    I've been using their products for over five years and gotten use to this practice and thankful I get to make the decisions if the headers are used or not
    for my designs needs, instead of being forced to make something adapt to my design already used.
    Hope the solder tips are helpful, Robert.
  • Hello reviewers and all,
    I believe we are seeing a minor/?major? problem issue with this bundle. The implementation of this particular TFT display and host controller (MCU/MPU) was never done before.
    It would really help us if PIN diagrams with labeling was available for the TFT and its Adapter board, since it seems we might be the ones to solve all aspects
    of their implementation together.
    Any possibility of anyone knowing of any literature or schematics and datasheets for used pertinent device components that would assist the joining of them, would be gratefully received.
    My own searches have been devoid of any finds that help so far also. Robert.
  • I have the board using the LCD controller as a frame buffer /dev/fb0.
    I can make it display images at the moment, back to front and upside down but it is a start image
    http://www.element14.com/community/roadTestReviews/1877
  • You're welcome - I'm glad they turned around the replacement so quickly.
    e14 Contributor in reply to Robert Peter Oakes
    Hey!
    I havent had a great deal of time to have a play around yet, i'm hoping to dedicate a few hours tomorrow though..
    I have been thinking about the LCD situation though, and came up with 2 conclusions.
    A) You need to connect some of the pins on the lcd expansion board to the i2c bus on the xplained board that would provide the lcd commands whereas the standard lcd connector would just provide the lcd data. (this is the most unlikely but would be the best possible solution).
    B) You need to create your own control and drawing functions for the lcd just like you would with any other microcontroller. Again this makes for a couple of options. 1) keep your project as a single program that uses the lcd independantly of the linux distro or 2) find some way of incorporating your lcd code into the linux distro and recompiling etc...
    The linux distro is Yocto which is becoming quite popular on small board computers, but the one on the xplained is very much bare bones, I think it's just a way of being able to use the memory and communicate through lan etc... so maybe just see it as a BIOS that your program can talk to to use onboard peripherals rather than something that could become a full Operating system.
    After my brief look around the internet, there doesn't seem to be much information available at all, and when you do find somebody asking questions in forums, the responses soon dry up. It seems that it's a pretty much start from scratch and help develop the system for other people to use situation.
    If I have any of this wrong then I apologise but as I said I've only had a very brief time to look into it so far.
    I plan on working my way through the getting started guide and web resources tomorrow as well as having a close look t the user manual / data sheet for the lcd tomorrow.
    Lucie
  • ok so I got the USB connection up and running, using PUTTY but as said already, no LCD support built in, Got a network port also up and running.
    tried the standard "sudo apt-get update" kind of commands... nothing, command not found
    not one of the standard distros either, (Not that I could tell) uname -a gives:
    Linux sama5d3_xplained 3.10.0-yocto-standard #1 Wed Feb 5 10:03:20 CET 2014 armv7l GNU/Linux
    I was at least hoping for some basic starting point like the RIoT board that I could work with
    So anyone have any clues how to get this at least working on the LCD and running the demos, because several hours of google and other searches have given me nothing usable so far, even on ATMEL web site proved fruitless so far
    It should not be this hard to get the basics going on a product aimed at the hobbyist
    Peter
  • Mine arrived today, all in the one package
    Notice I need to get the soldering Iron out...
    Try to use a good one the rest of you, none of these directly connected to the mains jobs or risk your road test...
    Peter
  • Hi Christian
    I have just received the SAMA5D3 Xplained, I have definitely not seen a box like this one.
    Very much appreciated, time to crack on and begin playing image
    Thanks for all your help.
  • Hiya Lucie,
    Thanks for the info on the linux kernal used. As for the Click Shield, I opened mine to examine it and the Click sockets look to be mounted right, but the "Prog/UART" switch on mine is mounted a little askew, but seems to operate ok.
    In cases like what you have, I usually choose to get the solder iron out and apply a little solder and heat each pin leg while putting a slight pressure on the socket towards the direction it needs to move to align correctly with mating components. It sometimes takes a couple of cycles of heating the pin legs to get them corrected.
    I've been a repair technician my whole life, and rarely send anything back if I can fix it myself though.
    I have not put anything together yet or removed from the static bags (except the shield board), but will be setting up an area for the bundle to be used on my workbench tomorrow and do a full examination of all the components. let ya know if I find anything wacky, Robert.
    e14 Contributor in reply to e14 Contributor
    Heya,
    I think you're right about the the study time, the built in linux distro is very simple and doesn't seem to have been community developed much either so there's likely to be some work involved there. It doesnt appear that the lcd works natively with it. I.e. no terminal output so I can't wait to get started just trying to get something on the screen!
    My first task is to put a power connector onto the board so I can power it externally with a 5v supply and network into it through ssh, just to get into my comfort zone a little bit image
    The only thing i'm unhappy about at the minute is the build quality of the click shield in the bundle. The header sockets have been soldered on so wonky that if I were to put the headers onto my click board straight and flush there's no way they would clip together. What's yours like? the little switch is also  bit wonky! have I just got a dud? (the funny thing is that it has a quality control sticker on the bottom.... )
    lucie
  • Welcome Greg,
    Then sorry to say, looks like you are missing it in your "Bundle" package. The Xplained box is slightly smaller than the one for the LCD display.
    I'm sure Christian or somebody is boxing one up for you right now or very soon. I hope you get it soon and look forward to seeing your and everybody Else's
    reviews.
    For doing mine, I am going to need a lot of study time for this new (to me) MPU platform. I have been a "PIC addict" for some time and will probably suffer some
    withdrawal symptoms for the next month. image
    Robert.
  • Thanks Robert
    There was only one fairly large box which contained the TFT display.
    Greg
  • Hi Greg,
    Mine came in a 2.25"(D) x 5.75"(W) x 7.25"(H) white box with a really cool picture of something like a Robosapient with 3 speakers in its body on the box front.
    I doubt you would miss seeing it if it was in the Bundle package. lol.
    The "Bundle" arrived this morning in good shape, and I am very honored and excited to start checking out this collection of HW.
    Thank you Christian, again, for my selection to Road Test this awesome collection of tools. (Now to gather up all the Docs and tools needed)
    I must point out that for me, being a long time MikroElektronika product user, the "Jargon" differences has already given me a surprise (a good one).
    In Mikroe speak, an LCD display refers to a simple 2 line text mono color display, and a GLCD is a mono color Graphic 128x64 (or 128x128) dot matrix display, while the highly desired full color Touch Panel displays are referred to as TFT-TP displays.
    So I was pleasantly surprised to discover that the "LCD Display" part of this Bundle is in fact, a full color (24 bit) TFT display with built in TP controller by way of SPI serial control and at 4.3" of visual real estate, with 480x272 resolution. Wow. Did not expect that.
    I will have to include in the review how this display compares to the same size Mikroe Connect EVE display I have, and I look forward to seeing it in action.
    Thanks again for this opportunity, Robert. (Megahurts @ the Mikroe Forum and most active in the Visual-TFT section)
    ps. Please bear with me as I get used to the action (plenty of it here I see) and format you all are probably used to, and I promise to contribute as much as I possibly can in future.
  • Thanks Christian, much appreciated.
    To confirm, I received:
    Mikroe-1581 Arduino Uno Click Shield
    LCD8000-43T-EX1 LCD module and adapter board
    WiFi dongle
    SHT11-Click board
    I have just read through the packing note and unless I am misreading it the board should indeed have been included .
    Just in case I have been an idiot and not noticed the board while unpacking the box, am I looking for a board slightly larger than an Arduino Mega? Does it come in any sort of packaging?
    Greg
