Enrollment closes in
Days 0 Hours 0 Mins 0 Secs 0
This RoadTest gives you the opportunity to try the PSOC Edge E84 AI Evaluation Kit, use DEEPCRAFT
Studio and DEEPCRAFT
Ready Models, and evaluate how well it supports AI and ML workloads at the edge.
The Infineon PSOC Edge E84 AI Evaluation Kit (KITPSE84AITOBO1) is built for testing machine learning and Edge AI applications. It’s designed to help engineers and developers explore Infineon’s DEEPCRAFT
AI suite, collect data from onboard sensors, and experiment with AI models directly on the device.
The out-of-box experience — from setup to running your first example.
Using DEEPCRAFT Studio to collect data from onboard sensors.
Running and evaluating DEEPCRAFT Ready Models (for example, baby cry detection or motion type detection).
Developing code with ModusToolbox software.
Debugging and programming using the on-board KitProg3 interface.
You’ll share your experience through text, images, or video, showing other community members how easy it is to get started and what the kit can do.
RoadTesters will receive or have access to:
ModusToolbox software (v3.6 or later)
DEEPCRAFT AI Suite, including:
DEEPCRAFT Studio
Cortex®-M55 CPU with Helium DSP and Ethos
-U55 NPU for AI acceleration
NNLite NPU for ultra-low-power ML processing
Multiple onboard sensors:
60GHz XENSIV radar
Barometric pressure sensor
Magnetometer
Analog and digital microphones
Image sensor
Built-in wireless (Wi-Fi + Bluetooth®)
On-board KitProg3 debugger
USB host/device interfaces and MIPI-DSI display connector
Unbox and explore the kit, following the Getting Started Guide.
Test the out-of-box setup and initial software configuration.
Collect data using DEEPCRAFT Studio and onboard sensors.
Flash and test a DEEPCRAFT Ready Model (such as baby cry or gesture classification).
Develop and debug code using ModusToolbox and explore example projects.
Share your findings in a review, including what worked well and any challenges.
The preferred way to test it would be to use it with something you are currently working on. Otherwise, working with the documentation, open the box and test the out of the box experience. Show the reader of this review what you discovered utilizing text, images, videos, and/or any other media, so the reader understands what is involved in using the product.
Steps to Test DEEPCRAFT Studio and DEEPCRAFT Ready models
Begin enrollment |
October 16 2025 |
End enrollment |
November 16 2025 |
Select RoadTesters |
Week of 2nd February |
Ship unit |
Week of 23rd February 2026 |
Begin RoadTesting |
Approx. 27th March 2026 |
element14 followup |
Approx. 8th May 2026 |
Post reviews by |
Approx. 19 June 2026 |
Infineon Technologies is a leading manufacturer of semiconductor and system solutions for automotive, industrial electronics, chip card and security as well as applications in communications with a strategic focus on the three main areas: Energy Efficiency, Communications and Security Infineon’s products stand out for their reliability, their quality excellence and their innovative and leading-edge technology in analog and mixed signal, RF and power as well as embedded control. A strong technology portfolio with about 22,900 patents and applications is characteristic for the company. For more information, click here.
