Product Review - Arduino GIGA R1 WiFi + Camera - A beast in the embedded, IoT and robotics makerspace
View table of contents ...
RoadTest: Enroll to Review the Arduino GIGA R1 WiFi + Camera
Author: crisdeodates
What other parts do you consider comparable to this product?: Portenta H7, Arduino Mega / Due
What were the biggest problems encountered?: Availability of onboard off-the-shelf ports such as grove ports could have been better (solvable using shields)
First of all, I would like to thank rscasny, the roadtest program team, and element14 for giving me this awesome chance to roadtest this amazing product Arduino Giga R1 Wifi board. Element14 was kind enough to send me a piece for road testing. I have been playing with Arduino boards ever since I started my robotics path. In fact, my first major project from college was using an Arduino Nano, dating back to the early beginning of the previous decade. So Arduino is not new to me and this beast of a thing is absolutely monstrous. Seriously? 76 GPIOs? Even Mega and Due had only 54 of them. When this board was available for the road test, I was determined to try this, not just for the kind of monster it is in the embedded space, but also to explore the endless possibilities it can provide in terms of scaling and productivity in the maker space. More interestingly, I was intrigued by the following statement from the official page: “You can for example run MicroPython and Arduino code simultaneously and communicate via an RPC”
Unboxing/Out of the box Experience
Let's have a look at the kit and its components:
The box came with the following components:
  1. Arduino box
    1. 1 x Arduino Giga R1 Wifi with glass bottom
    2. 1 x 2.4/5Ghz flexible MOLEX antennae
    3. 1 x classic Arduino thank you slip
    4. 1 x classic Arduino stickers (I have like a lot of them now Grinning)
  2. Arducam box
    1. 1 x Arducam OV7675 VGA Color 20-pin DVP Camera Module
      (Yes, Randall was kind enough to include a camera module for the road testers)
The Arduino board in its “Giga” form really made an excellent first impression. The board was massive to hold at 101.6mm x 53.3mm (just like its older cousins Mega and Due), even dwarfing the Raspberry Pi 4 board's 56.5mm x 85.6mm footprint.
By default, the Arduino Giga board seems to come with a multicolor LED blink arduino program that seems to cycle between the Red, Green, and Blue colors of the inbuilt RGB LED that is present next to the audio jack.
Similar boards
There are basically 3 boards that could potentially be compared to Arduino Giga R1 Wifi.
Arduino GIGA R1 WiFi board basically inherits the STM32H7 dual-core Cortex-M7/M4 microcontroller of Portenta H7 boards while maintaining the larger Arduino Mega/Due form factor.
Performance in comparison to Portenta H7:
Arduino GIGA R1 WiFi board could be expected to have the same high computing capacity as Portenta H7 boards since they share the same STM32H7 microcontroller.
However, in contrast to the Portenta H7, the Giga board comes with 76 GPIO, an audio jack, a USB 2.0 Type-A host port, and extra connectors for a display and a camera. At the same time, the Giga board has no support for DisplayPort over USB-C, no on-board 10/100M Ethernet PHY, no high-density connectors, and no built-in battery support which are present in the Portenta H7 board.
Both boards feature a USB Type-C port for programming, integrating 2 MB of flash memory, 1 MB of RAM, 16 MB QSPI Flash memory, and 8 MB of SDRAM. Additionally, both boards have a Murata module for wireless connectivity (Wi-Fi and Bluetooth Low Energy BLE). Both boards can be programmed with the Arduino IDE or MicroPython. The dual-core design allows two programs to be run simultaneously with either both cores running Arduino code or one core running an Arduino sketch and the other a MicroPython script. An additional advantage of dual-core design as stated by the Arduino team is that, with this architecture, we can separate higher-level logic such as displays, interfaces, and networking from time-critical tasks such as motor control.
Features in comparison to Arduino Mega / Due:
At first look, the Giga board resembles the look of the Mega / Due form factor, although the Mega and Due can never match Giga in terms of performance.
Image courtesy: MakerHero
The key difference is that Giga boasts a whooping 76 GPIO in contrast to the 54 GPIO in Mega / due boards. Also, Giga additionally has wireless connectivity, an audio jack, a USB 2.0 Type-A host port, a JTAG connector, and extra connectors for a display and a camera. The Giga also comes equipped with a crypto chip and an antenna. Within the generous 76 GPIO pins, 12 support PWM, 12 with analog input & 2 DACs. There are 4 UART, 3 I2C, and 2 SPI buses, plus CAN bus support (requires external transceiver). The Giga board also includes two new pins in contrast to Mega / Due. They are a VRTC pin to keep the real-time clock running when the main power is removed and an OFF pin that shuts down the board. Giga board can be powered with inputs varying from 6-24V DC while the other two only support up to a maximum of 12V. Even though all the existing shields seem compatible, Giga is a 3.3-volt logic device. Hence most of the existing shields might not work if they operate at the 5V levels. Since the microcontroller operates on a voltage of 3.3V, applying a higher voltage than that, such as 5V, to a pin might damage the microcontroller.
Links
Here are some links to get started:
Board walkthrough
Let's have a look at the datasheet and some specifications of the Arduino Giga R1 Wifi board.
The Arduino GIGA R1 is one of the most feature-packed Arduino boards to date. It is supported by the same powerful, ML-capable, dual-core microcontroller found in the Arduino Pro family's Portenta H7.
Courtesy: DroneBot Workshop
Image Courtesy: DroneBotWorkshop
More detailed top view:
Image Courtesy: Arduino
More detailed bottom view:
The reference ICs are:
Ref.
Description
Ref.
Description
U1
STM32H7 Dual Core Microcontroller IC
U8
AT25SF128A-MHB-T 16 MB Flash IC
U3
AS4C4M16SA 8MB SDRAM IC
U4
ATECC608A-MAHDA-T Secure Element IC
U5
LBEE5KL1DX-883 Wi-Fi®/Bluetooth® Module
U6
MP2322GQH Buck Converter 3.3V IC
U7
MP2269GD-Z Buck Converter 5V IC
JANALOG
Analog input/output headers
JDIGITAL
Digital input/output headers
JSIDE
SPI
SPI headers
JTAG
JTAG Headers
J2
USB 2.0 A Host
J15
3.5 mm audio in/out
PB1
RESET Button
PB2
BOOT0 button
J14
Micro UFL connector
J5
Camera
J6
Camera
DL1
Power LED
DL2
RGB SMLP34RGB2W3 Common anode LED
J12
CX90B-16P USB-C® connector
Here are the main technical specifications.
  • STM32H747XIH6 Microcontroller (datasheet)
    • 32-bit Arm® Cortex®-M7 core with double-precision FPU and L1 cache up to 480 MHz
    • 32-bit Arm® 32-bit Cortex®-M4 core with FPU up to 240 MHz
    • Dual-core
  • Full set of DSP instructions
  • Memory Protection Unit (MPU)
  • Murata® 1DX Wi-Fi®/Bluetooth® Module (datasheet)
    • Wi-Fi® 802.11b/g/n 65 Mbps
    • Bluetooth® Low Energy (version 5. X via Cordio stack, version 4.2 via Arduino Stack)
    • Micro UFL connector for external antenna
  • Memory
    • 2 MB Flash
    • 1 MB RAM
    • 16 MB NOR Flash
    • QSPI Interface
    • 8 MB SDRAM
  • I/O
    • Digital I/O Pins: 76
    • Analog input pins: 12
    • PWM pins: 13
    • Analog output pins (DAC0/DAC1): 2
    • USB Host: USB 2.0 A
    • USB Peripheral: USB-C®
    • Logic level: 3.3V
    • VRTC: To power the RTC while the board is off
    • OFF pin: To turn off the board
  • Communication
    • 4x UART
    • 3x I2C
    • 2x SPI
    • 1x CAN (an external transceiver is required)
  • Secure Element ATECC608A-MAHDA-T Module (datasheet)
  • USB
    • Host
    • Programming Port
    • HID
    • USB Host USB 2.0 Type A
    • USB Peripheral USB-C®
  • Connectors
    • Camera: 20-pin Arducam camera connector
    • Display: D1N, D0N, D1P, D0P, CKN, CKP, D68-D75
    • Audio jack: DAC0, DAC1, A7
    • JTAG connector
  • Power
    • Circuit operating voltage: 3.3V
    • Input voltage (VIN): 6-24V
    • DC Current per I/O Pin: 8 mA
  • Target areas
    • 3D printing
    • Signal Processing
    • Maker Space
    • Robotics
  • Compatible Software & Development tools
    • Arduino IDE
    • Arduino CLI
    • Arduino Web Editor
    • Arduino IoT cloud
    • dfu-util
    • Arduino Lab for MicroPython
    • Thonny
    • Arduino Core / MbedOS
    • Micro Python
The pinout of the Arduino Giga R1 Wifi board is as follows.
Pin
Function
Type
Description
Three-Pins Header – J1
1
OFF
Digital
3V3 Enable Pin (U6)
2
GND
Power
Ground
3
VRTC
Reset
Real-Time Clock Battery
Analog
1
NC
NC
Not Connected
2
IOREF
IOREF
Reference for digital logic V - connected to 3.3V
3
Reset
Reset
Reset
4
+3V3
Power
+3V3 Power Rail
5
+5V
Power
+5V Power Rail
6
GND
Power
Ground
7
GND
Power
Ground
8
VIN
Power
Voltage Input
9
A0
Analog
Analog input 0 /GPIO
10
A1
Analog
Analog input 1 /GPIO
11
A2
Analog
Analog input 2 /GPIO
12
A3
Analog
Analog input 3 /GPIO
13
A4
Analog
Analog input 4 /GPIO
14
A5
Analog
Analog input 5 /GPIO
15
A6
Analog
Analog input 6 /GPIO
16
A7
Analog
Analog input 7 /GPIO
17
A8
Analog
Analog input 8 /GPIO
18
A9
Analog
Analog input 9 /GPIO
19
A10
Analog
Analog input 10 /GPIO
20
A11
Analog
Analog input 11 /GPIO
21
DAC0
Analog
Digital to Analog Converter 0
22
DAC1
Analog
Digital to Analog Converter 1
23
CANRX
Digital
CAN Bus Receive
24
CANTX
Digital
CAN Bus Transfer
Digital
1
D21/SCL1
Digital
GPIO 21/I2C 1 Clock
2
D20/SDA1
Digital
GPIO 20/I2C 1 Dataline
3
AREF
Digital
Analog Reference Voltage
4
GND
Power
Ground
5
D13/SCK
Digital
GPIO 13/SPI Clock (PWM~)
6
D12/CIPO
Digital
GPIO 12/SPI Controller In Peripheral Out (PWM~)
7
D11/COPI
Digital
GPIO 11/SPI Controller Out Peripheral In (PWM~)
8
D10/CS
Digital
GPIO 10/SPI Chip Select (PWM~)
9
D9/SDA2
Digital
GPIO 9/I2C 2 Dataline (PWM~)
10
D8/SCL2
Digital
GPIO 8/I2C 2 Clockline (PWM~)
11
D7
Digital
GPIO 7 (PWM~)
12
D6
Digital
GPIO 6 (PWM~)
13
D5
Digital
GPIO 5 (PWM~)
14
D4
Digital
GPIO 4 (PWM~)
15
D3
Digital
GPIO 3 (PWM~)
16
D2
Digital
GPIO 2 (PWM~)
17
D1/TX0
Digital
GPIO 1 / Serial 0 Transmitter
18
D0/TX0
Digital
GPIO 0 / Serial 0 Receiver
19
D14/TX3
Digital
GPIO 14 / Serial 3 Transmitter
20
D15/RX3
Digital
GPIO 15 / Serial 3 Receiver
21
D16/TX2
Digital
GPIO 16 / Serial 2 Transmitter
22
D17/RX2
Digital
GPIO 17 / Serial 2 Receiver
23
D18/TX1
Digital
GPIO 18 / Serial 1 Transmitter
24
D19/RX1
Digital
GPIO 19 / Serial 1 Receiver
25
D20/SDA
Digital
GPIO 20 / I2C 0 Dataline
26
D21/SCL
Digital
GPIO 21 / I2C 0 Clock
STM32 ICSP
1
CIPO
Internal
2
+5V
Internal
Power Supply of 5V
3
SCK
Internal
Serial Clock
4
COPI
Internal
5
RESET
Internal
Reset
6
GND
Internal
Ground
Digital Pins D22 - D53 LHS
1
+5V
Power
+5V Power Rail
2
D22
Digital
GPIO 22
3
D24
Digital
GPIO 24
4
D26
Digital
GPIO 26
5
D28
Digital
GPIO 28
6
D30
Digital
GPIO 30
7
D32
Digital
GPIO 32
8
D34
Digital
GPIO 34
9
D36
Digital
GPIO 36
10
D38
Digital
GPIO 38
11
D40
Digital
GPIO 40
12
D42
Digital
GPIO 42
13
D44
Digital
GPIO 44
14
D46
Digital
GPIO 46
15
D48
Digital
GPIO 48
16
D50
Digital
GPIO 50
17
D52
Digital
GPIO 52
18
GND
Power
Ground
Digital Pins D22 - D53 RHS
1
+5V
Power
+5V Power Rail
2
D23
Digital
GPIO 23
3
D25
Digital
GPIO 25
4
D27
Digital
GPIO 27
5
D29
Digital
GPIO 29
6
D31
Digital
GPIO 31
7
D33
Digital
GPIO 33
8
D35
Digital
GPIO 35
9
D37
Digital
GPIO 37
10
D39
Digital
GPIO 39
11
D41
Digital
GPIO 41
12
D43
Digital
GPIO 43
13
D45
Digital
GPIO 45
14
D47
Digital
GPIO 47
15
D49
Digital
GPIO 49
16
D51
Digital
GPIO 51
17
D53
Digital
GPIO 53
18
GND
Power
Ground
Recommended Operating Conditions of Giga are:
Symbol
Description
Min
Typ
Max
Unit
VIN
Input voltage from VIN pad
6
7
32
V
VUSB
Input voltage from USB connector
4.8
5
5.5
V
VDD
Input high-level voltage
0.7*VDD
VDD
V
VIL
Input low-level voltage
0
0.3*VDD
V
TOP
Operating Temperature
-40
25
85
°C
Note: VDD controls the logic level and is connected to the 3.3V power rail and VAREF is for the analog logic
Here is the functional block diagram:
The power distribution is below:
Let us also look at the Arducam module and its datasheet.
The camera is based on an OmniVision 0.3MP OV7675 image sensor. It excels in image capture with its advanced features and exceptional performance and supports RAW/RGB/YUV output format. It is fully compatible with Arduino GIGA R1 board allowing versatile image capture and processing capabilities.
  • Image Sensor: OV7675
  • Resolution: VGA
  • Optical Size: 1/9”
  • Number of effective pixels: 640(H) × 480(V)
  • Pixel Size: 1.75μm × 1.75μm
  • Support Platform: Arduino GIGA R1 WIFI Board
  • Shutter Type: Electronic Rolling Shutter
  • Color Filter Array: Quad-Bayer RGB
  • Frame Rate: 15fps
    • 640×480
    • 320×240
    • 160×120
  • Output Format: RAW
    • RAW RGB
    • YUV422
    • RGB565
  • F.NO: 2.8±5%
  • Focus Distance: 2.7m – ∞
  • Focal Length: 1.75mm
  • Field of View(FOV): 63.9°(D)
  • Power Supply
    • AVDD: 2.7VA ~ 3.0V
    • DOVDD: 1.7V ~ 3.0V
    • DVDD: 1.8V
  • Operating Temperature: -30~70℃
  • Camera Board Size: 30.5mm x 30.5mm
The pinout of the Arducam module is shown below.
Image Courtesy: ArduCam
Getting Started
Now, let’s get down to business and start tinkering with our new Arduino Giga R1 Wifi board. The initial setup with MbedOS is pretty straightforward like any other Arduino board.
  1. Download and Install Arduino IDE from the Arduino Software page.
  2. Open the IDE and install the board package.
    To install the GIGA board package, choose "Board Manager" from the left menu.
    Search for "GIGA" and install the latest version.
  3. Select your board in the board selector.
  4. Connect the board to your computer via the USB-C connector.
Now let us try an example blink sketch
  1. Open the example from File -> Examples -> Basics -> Blink
  2. Verify (Checkmark) and Upload (Right arrow) the sketch to the board
  3. Now the inbuilt RGB LED near the audio port should start blinking green.
  4. We have successfully set up the Giga board with the Arduino Core for mbed devices.
INFO: Normally, if the sketch fails for some reason, the board resets. On the GIGA R1, whenever the MbedOS fails, the board does not reset automatically. Instead, if it fails, the onboard red LED will start to blink in a looping pattern of 4 fast blinks and 4 slow blinks. Hence the red LED does NOT mean your board is broken or bricked. Instead, you can either press the reset button once to reset the sketch or double-tap the reset button to enter bootloader mode which allows you to re-program the board.
Testing
Here we will test the various features and capabilities of the Arduino Giga R1 Wifi board, along with the interfacing of various sensors and actuators.
GPIO access
Let's connect a bush button to Digital pin 7 of the GigaR1 and read its value.
In the Arduino IDE, go to File -> Examples -> Basics -> DigitalReadSerial
Change the variable pushButton to 7 for Digital Pin number 7 in GigaR1.
Compile and upload the sketch.
Connect a push button to the Digital Pin 7 of the GigaR1.
I used a DFRobot Gravity Push button: https://www.dfrobot.com/product-2362.html
Connect the power pins of the pushbutton to 3.3v and the GND pins of the GigaR1.
Observe the state of Digital Pin 7 in the serial monitor output.
Wifi access
Reference: https://docs.arduino.cc/tutorials/giga-r1-wifi/cheat-sheet#wi-fi
Let's see how the Wifi could be set up in GigaR1.
In the Arduino IDE, go to File -> Examples -> Wifi -> WifiWebClient
Change the SSID and password in the arduino_secrets.h file
Change the server variable name to google.com in WifiWebClient.ino file
Compile and Upload the program
We can see that the Giga R1 successfully connected to our local Wifi and was able to access the Google server webpage.
IoT cloud
Connecting to Arduino Cloud:
  1. Login to Arduino cloud: https://create.arduino.cc/
  2. Download and install the Arduino Create Agent: https://create.arduino.cc/getting-started/plugin/download
  3. Make sure the Agent is active and Giga R1 is connected to the computer
  4. Come to the devices tab and click Add Device
  5. Select the option Arduino board and wait for the board to be detected
  6. Once the device is detected, click configure
  7. Give a name for the device. Eg: GigaR1 and proceed
  8. Now the cloud setup will take place and makes the device accessible to the Arduino IoT cloud
USB access
Reference: https://docs.arduino.cc/tutorials/giga-r1-wifi/giga-usb
USB Host
Generic USB keyboards could be easily connected to the GIGA R1's USB-A connector without any additional circuitry. However, we need the USBHostGiga library.
Note: To enable the USB-A port, you will need to define it as an output (PA_15). We can also disable it inside of a sketch by writing a LOW state to it.
  1. Download the USBHostGiga library as a zip file: https://github.com/arduino-libraries/USBHostGiga
  2. Go to Sketch > Include Library > Add .zip Library and select the downloaded zip to install the library.
  3. Compile and upload the below code:
#include "USBHostGiga.h"
Keyboard keyb;
HostSerial ser;
void setup() {
  Serial.begin(115200);
  while (!Serial);
  pinMode(PA_15, OUTPUT);
  keyb.begin();
  ser.begin();
void loop() {
  if (keyb.available()) {
    auto _key = keyb.read();
    Serial.println(keyb.getAscii(_key));
  while (ser.available()) {
    auto _char = ser.read();
    Serial.write(_char);
  //delay(1);
Once the code is uploaded, connect your USB keyboard to the USB-A port of GigaR1.
Open the serial monitor and start pressing the keyboard keys.
The keys pressed will be displayed on the serial monitor.
USB HID
GIGA R1 board can also be transformed or emulated into a Human Interface Device (HID), e.g. mouse & keyboard, game controller, etc.
Let's try to emulate a keyboard.
In the Arduino IDE, go to File -> Examples -> USBHID -> Keyboard
Open a notepad after the code is uploaded
We can see that the GigaR1 now emulates a keyboard and prints the text “Hello World” as if typed from a keyboard device.
CAUTION: The keyboard continues to print as soon as the code is uploaded as it is inside the loop. Hence make sure you are bringing up a notepad or another textual area as soon as the code upload is finished or the board is reset.
CAUTION: Once the GigaR1 is configured as an HID, it will fail to upload any more sketches. In that case, double press the RST button (to the right of the USB-C port) to enter bootloader mode. You will be able to upload new sketches now.
USB Read
Reference: https://reference.arduino.cc/reference/en/libraries/arduino_usbhostmbed5/
Let's try to read the contents of a USB drive connected to the USB-A port of the GigaR1.
Go to the Library Manager and install the Arduino_USBHostMbed5 library
#include <DigitalOut.h>
#include <FATFileSystem.h>
#include <Arduino_USBHostMbed5.h>
USBHostMSD msd;
mbed::FATFileSystem usb("usb");
void setup()
    pinMode(PA_15, OUTPUT); //enable the USB-A port
    digitalWrite(PA_15, HIGH);
    while (!Serial)
    Serial.println("Starting USB Dir List example...");
    // if you are using a Max Carrier uncomment the following line
    // start_hub();
    while (!msd.connect()) {
        //while (!port.connected()) {
        delay(1000);
    Serial.print("Mounting USB device... ");
    int err = usb.mount(&msd);
    if (err) {
        Serial.print("Error mounting USB device ");
        Serial.println(err);
        while (1);
    Serial.println("done.");
    char buf[256];
    // Display the root directory
    Serial.print("Opening the root directory... ");
    DIR* d = opendir("/usb/");
    Serial.println(!d ? "Fail :(" : "Done");
    if (!d) {
        snprintf(buf, sizeof(buf), "error: %s (%d)\r\n", strerror(errno), -errno);
        Serial.print(buf);
    Serial.println("Root directory:");
    unsigned int count { 0 };
    while (true) {
        struct dirent* e = readdir(d);
        if (!e) {
            break;
        count++;
        snprintf(buf, sizeof(buf), "    %s\r\n", e->d_name);
        Serial.print(buf);
    Serial.print(count);
    Serial.println(" files found!");
    snprintf(buf, sizeof(buf), "Closing the root directory... ");
    Serial.print(buf);
    fflush(stdout);
    err = closedir(d);
    snprintf(buf, sizeof(buf), "%s\r\n", (err < 0 ? "Fail :(" : "OK"));
    Serial.print(buf);
    if (err < 0) {
        Serial.print(buf);
void loop()
Now connect a FAT-formatted USB pen drive to the USB-A port of the GigaR1.
Please note that the name of the USB drive should be “usb”.
You should be able to see the drive contents in your serial monitor output.
Note: For some strange reason, my pendrive was not mounted. I will try later with another pen drive.
Camera Access
Reference: https://docs.arduino.cc/tutorials/giga-r1-wifi/giga-camera
The GIGA R1 has a dedicated camera connector that allows us to mount certain camera modules directly on the board. This will enable the possibility to use machine vision in our GigaR1 projects.
The GIGA R1 currently supports the following cameras, via the Camera library that is bundled with the Arduino Mbed Core:
  1. OV7670 and OV7675
  2. GC2145
  3. Himax HM01B0
  4. Himax HM0360
We can access the Camera Library here: https://github.com/arduino/ArduinoCore-mbed/tree/master/libraries/Camera
The 20-pin camera connector onboard the GIGA R1 is designed to be directly compatible with some breakout boards from ArduCam. This allows us to simply connect the camera module directly to the board, without making any additional circuit.
Let's try to access the camera module using GigaR1.
We will need to install the software called Processing in order to read the serial camera buffer data sent from GigaR1.
Step 1: Configure Arduino to send camera data via Serial
Connect the camera module to the 20-pin camera connector.
In the Arduino IDE, go to File -> Examples > Camera > CameraCaptureRawBytes
Make sure the correct camera module is selected inside the code. Eg: OV7675
Step 2: Configure Processing to read the camera data via Serial
Open the Processing app.
Copy the following code to the processing app:
import processing.serial.*;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
Serial myPort;
// must match resolution used in the Arduino sketch
final int cameraWidth = 320;
final int cameraHeight = 240;
// Must match the image mode in the Arduino sketch
final boolean useGrayScale = false;
// Must match the baud rate in the Arduino sketch
final int baudRate = 115200;
final int cameraBytesPerPixel = useGrayScale ? 1 : 2;
final int cameraPixelCount = cameraWidth * cameraHeight;
final int bytesPerFrame = cameraPixelCount * cameraBytesPerPixel;
final int timeout =  int((bytesPerFrame / float(baudRate / 10)) * 1000 * 2); // Twice the transfer rate
PImage myImage;
byte[] frameBuffer = new byte[bytesPerFrame];
int lastUpdate = 0;
boolean shouldRedraw = false;
void setup() {
  size(640, 480);
  // If you have only ONE serial port active you may use this:
  //myPort = new Serial(this, Serial.list()[0], baudRate);          // if you have only ONE serial port active
  // If you know the serial port name
  //myPort = new Serial(this, "COM5", baudRate);                    // Windows
  myPort = new Serial(this, "/dev/ttyACM0", baudRate);            // Linux
  //myPort = new Serial(this, "/dev/cu.usbmodem14301", baudRate);     // Mac
  // wait for a full frame of bytes
  myPort.buffer(bytesPerFrame);
  myImage = createImage(cameraWidth, cameraHeight, ALPHA);
  // Let the Arduino sketch know we're ready to receive data
  myPort.write(1);
void draw() {
  // Time out after a few seconds and ask for new data
  if(millis() - lastUpdate > timeout) {
    println("Connection timed out.");
    myPort.clear();
    myPort.write(1);
  if(shouldRedraw){
    PImage img = myImage.copy();
    img.resize(640, 480);
    image(img, 0, 0);
int[] convertRGB565ToRGB888(short pixelValue){
  //RGB565
  int r = (pixelValue >> (6+5)) & 0x01F;
  int g = (pixelValue >> 5) & 0x03F;
  int b = (pixelValue) & 0x01F;
  //RGB888 - amplify
  r <<= 3;
  g <<= 2;
  b <<= 3;
  return new int[]{r,g,b};
void serialEvent(Serial myPort) {
  lastUpdate = millis();
  // read the received bytes
  myPort.readBytes(frameBuffer);
  // Access raw bytes via byte buffer
  ByteBuffer bb = ByteBuffer.wrap(frameBuffer);
  // Ensure proper endianness of the data for > 8 bit values.
  // The 1 byte bb.get() function will always return the bytes in the correct order.
  bb.order(ByteOrder.BIG_ENDIAN);
  int i = 0;
  while (bb.hasRemaining()) {
    if(useGrayScale){
      // read 8-bit pixel data
      byte pixelValue = bb.get();
      // set pixel color
      myImage.pixels[i++] = color(Byte.toUnsignedInt(pixelValue));
    } else {
      // read 16-bit pixel data
      int[] rgbValues = convertRGB565ToRGB888(bb.getShort());
      // set pixel RGB color
      myImage.pixels[i++] = color(rgbValues[0], rgbValues[1], rgbValues[2]);
  myImage.updatePixels();
  // Ensures that the new image data is drawn in the next draw loop
  shouldRedraw = true;
  // Let the Arduino sketch know we received all pixels
  // and are ready for the next frame
  myPort.write(1);
Make sure to select the correct serial port and baud rate in the code.
Press the Play button on the app to run the code.
We can see that the processing code will display the output of the serial data sent by the GigaR1 module.
CAUTION: If the serial port says busy in the processing app, make sure that the serial monitor is not open in the Arduino IDE.
Conclusion
The Arduino Giga R1 Wifi was a very fun and interesting board to work with. The readily available out-of-the-box Arduino example sketch will allow anyone to directly jump into using and tinkering with the kit, although the advanced features such as Dual core programming, multi-channel ADC, etc require some experience. MicroPython support also allows a robotics project to be realized with little to no effort. The availability of good documentation is also a plus as it allows in-depth programming and interfacing. The peripheral interfacings are also well set and we have access to a plethora of interfacing pins and options.
The major pros and cons of the kit are summarized below.
Pros
  1. Simple, robust, and easily programmable development board.
  2. MicroPython programming is available.
  3. Very easy module to work with, even for robotics beginners.
  4. Very good first impression and out-of-the-box experience.
  5. Availability of good documentation and community support.
  6. Allows Python (MicroPython) and C++ (Arduino) programming.
  7. A vast array of peripherals is available onboard.
Cons
  1. The absence of onboard off-the-shelf ports such as grove ports could be a bit awkward, but can be solved by using shields.
  2. Some features are advanced and require a deep understanding of the core concepts.
Future Prospects
I wish to do a bit more testing on the advanced capabilities such as Dual core programming, Multi-channel ADC, actuator interfacings, etc.
