RoadTest: RoadTest Open Call
Author: neerajrd82
What other parts do you consider comparable to this product?: OWON VDS1022I;PeakTech P 1290;PINTECH MSO5022I;OWON VDS2252I;PicoScope 2205A MSO
What were the biggest problems encountered?: The most significant challenges encountered during the initial evaluation of the MULTICOMP PRO MP720017 were related to software compatibility and initial probe compensation. Both issues required practical investigation and corrective action before proceeding with the subsequent measurement tests. 1. PC Software and Hardware Compatibility The first and most significant challenge occurred during the initial software installation and USB commissioning. I downloaded and installed the oscilloscope software available through the element14 community resource. Although Windows successfully recognized the MP720017 when connected through USB, the installed application failed to establish the expected operational communication with the instrument. Consequently, I could not initially proceed with normal waveform acquisition and oscilloscope operation. Rather than assuming that the instrument was defective, I investigated the underlying hardware platform and compared its specifications with other commercially available PC-based oscilloscopes. This investigation indicated a strong technical relationship between the MULTICOMP PRO MP720017 and the OWON VDS1022I platform. I subsequently installed the corresponding OWON VDS1022/VDS1022I software package. Following this installation, the oscilloscope began responding within the application. This was an important troubleshooting finding, although further verification was necessary to establish the extent of software and hardware compatibility. **My observation:** The successful USB device recognition by Windows did not necessarily guarantee successful communication with the initially installed oscilloscope application. The experience highlighted the importance of model-specific software, compatible USB drivers, and correct hardware initialization. 2. Initial Probe Compensation Adjustment The second challenge was encountered during the initial commissioning of the supplied passive oscilloscope probes. When I connected the probe to the oscilloscopes built-in square-wave compensation output, the displayed waveform exhibited characteristics of an over-compensated probe. The rising edge showed a sharp upward spike (overshoot), while the falling edge exhibited a corresponding downward spike. This indicated that the probe compensation trimmer required adjustment to match the capacitive characteristics of the probe with the oscilloscope input. I performed the compensation procedure by gradually adjusting the probe's compensation trimmer while continuously monitoring the displayed calibration waveform. This allowed me to fine-tune the probe response and obtain the desired square-wave representation without the excessive peaking associated with over-compensation. **My observation:** This exercise highlighted the importance of proper probe compensation before conducting waveform measurements, particularly when evaluating clock signals, PWM waveforms, switching transients, and other signals where edge characteristics are important. 3. Overall Assessment of the Challenges Both challenges were associated with the initial commissioning and configuration rather than an established hardware failure of the oscilloscope. The software compatibility issue required additional investigation to identify a suitable software environment, while the probe compensation issue was resolved through the normal adjustment procedure provided for passive oscilloscope probes. These experiences also provided useful opportunities to investigate the instrument beyond its published specifications. I have documented the software installation attempts, USB recognition, compatibility investigation, initial oscilloscope response, and probe compensation procedure through original screenshots and video recordings. At this stage, I have not established any hardware failure. Further testing will determine the instrument's measurement accuracy, acquisition performance, triggering behavior, waveform stability, and overall reliability.
RoadTest Programme: element14 Open Call RoadTest
Product: MULTICOMP PRO MP720017 EU-UK
Manufacturer: MULTICOMP PRO
Date of Receipt: 23 October 2026
STEP -1:
UNBOXING PROCEDURE
I am pleased to share my first RoadTest update following the successful receipt of the MULTICOMP PRO MP720017 EU-UK PC-Based Oscilloscope under the element14 Open Call RoadTest programme.
I received the instrument on 23 October 2026. This RoadTest provides me with an opportunity to evaluate a compact, PC-based oscilloscope in practical embedded hardware development, PCB debugging, signal measurement, and electronics troubleshooting applications.
With more than 21 years of professional experience in embedded systems hardware and firmware development, I regularly encounter situations where waveform visualization, timing verification, signal characterization, and hardware-level troubleshooting are essential parts of the engineering development process.
I selected the MP720017 because of its combination of dual analogue input channels, 25 MHz bandwidth, 100 MS/s sampling rate, USB connectivity, and USB 2.0 isolation. I am particularly interested in evaluating how effectively this instrument can support routine embedded electronics development and hardware debugging activities.
This initial article documents the unboxing, supplied accessories, physical condition, and first observations of the instrument. Detailed functional and performance testing will follow in subsequent stages of the RoadTest.
The instrument arrived in its original MULTICOMP PRO product packaging. After opening the carton, I carefully removed the supplied accessories and arranged the components for an initial visual inspection.
The oscilloscope itself was found inside protective plastic packaging, helping protect the instrument during handling and transportation.
The unboxing photograph documents the main instrument, USB interface cable, passive oscilloscope probes, probe instruction sheet, and PC Oscilloscope Quick Guide.
I have also included an annotated version of the photograph with numbered labels to identify the individual components visible in the package.
3.1 MULTICOMP PRO MP720017 EU-UK PC Oscilloscope
The main instrument is a compact, slim-profile PC-based oscilloscope.
Its enclosure has a metallic-looking finish with MULTICOMP PRO branding. The input and interface markings are visible through the protective packaging, including the two analogue channels (CH1 and CH2) and the multifunction interface.
The compact form factor is particularly interesting because it offers the possibility of keeping a portable oscilloscope setup without requiring the physical space occupied by a conventional bench oscilloscope.
The instrument's USB connectivity and integrated isolation are two features I intend to investigate in greater detail during the functional testing phase.
3.2 USB Interface Cable
A USB interface cable is supplied with the instrument.
This cable provides the connection between the oscilloscope and the host PC. The USB interface is also used for powering the instrument, according to the manufacturer's product information.
I will evaluate the USB connectivity, driver installation, device recognition, communication stability, and reliability during extended operation as part of the software testing.
3.3 Passive Oscilloscope Probes
The package includes two passive oscilloscope probes.
The supplied probe documentation identifies the 1X and 10X attenuation configurations. The product listing specifies two 60 MHz probes.
These probes will be essential for conducting practical measurements on microcontroller development boards, analogue circuits, communication interfaces, power supplies, and switching circuits.
During the initial setup, I will also examine the probe compensation procedure and verify the relationship between the probe attenuation selector and the corresponding software configuration.
3.4 Passive Probe Instruction Sheet
A separate instruction sheet marked "Passive Probe 1X & 10X" is visible in the package.
This documentation provides a reference for the supplied probes and their attenuation configurations.
Correct probe configuration will be particularly important when evaluating measurement accuracy, waveform amplitude, bandwidth, and signal integrity.
3.5 PC Oscilloscope Quick Guide
The package also contains the MULTICOMP PRO PC Oscilloscope Quick Guide.
This document will serve as the initial reference during installation and commissioning of the instrument.
I intend to follow the manufacturer's recommended installation and configuration procedure before proceeding with the electrical and functional validation.
3.6 Additional Probe-Related Accessories
The photograph also shows a few loose accessories alongside the probe assemblies and their leads.
I will identify and inspect these individually during the detailed inventory and setup process, including verification of the probe adjustment accessory against the supplied documentation.
Based on the initial visual inspection, the MP720017 has a compact and portable design.
Some noteworthy observations are:
Slim and lightweight instrument construction.
Two analogue input connections.
Dedicated multifunction interface.
USB-based host connection.
Supplied passive probes and USB cable.
Protective packaging around the main instrument.
Printed product documentation.
No obvious physical damage is apparent in the supplied photograph. A complete physical and functional inspection will be carried out before beginning the measurement tests.
According to the manufacturer's published specifications, the MP720017 offers the following primary capabilities:
| Parameter | Manufacturer Specification |
| Oscilloscope type | PC-based USB oscilloscope` |
| Analogue channels | 2 |
| External trigger | 1 |
| Analogue bandwidth | 25 MHz |
| Maximum sampling rate | 100 MS/s |
| Vertical ADC resolution | 8-bit |
| Acquisition memory | 5 kpts |
| Calculated rise time | ≤14 ns |
| Input impedance | 1 MΩ |
| Vertical sensitivity | 5 mV/div to 5 V/div |
| USB interface | USB 2.0 with isolation |
| Acquisition modes | Sample, Peak Detect, Average |
| Trigger types | Edge, Pulse, Video, Slope, Alternate |
| Mathematical functions | Addition, Subtraction, Multiplication, Division, Inversion and FFT |
These specifications provide the basis for the performance evaluation that I intend to undertake during this RoadTest.
I will not draw conclusions about the actual measurement performance based solely on the published specifications. Each relevant feature will be evaluated through practical testing wherever suitable test equipment and reference signals are available.
Following this initial unboxing and physical inspection, I plan to proceed with the following activities:
Complete the inventory of all supplied accessories and documentation.
Install the oscilloscope software and required USB drivers on the host PC.
Verify device recognition and USB communication.
Perform the initial oscilloscope commissioning and probe compensation.
Examine the graphical user interface and available measurement functions.
Validate basic voltage, frequency, and time-period measurements.
Evaluate triggering, waveform acquisition, FFT, and cursor measurement capabilities.
Begin practical testing using MCU development boards and custom embedded hardware.
Subsequent testing will cover UART, SPI, I²C, PWM, MCU clock signals, analogue sensor outputs, DC power rails, power-supply ripple, and SMPS switching waveforms.
I am also particularly interested in evaluating the practical benefits of the instrument's USB isolation feature during embedded hardware and power-electronics debugging.
The initial unboxing confirms receipt of the main MULTICOMP PRO MP720017 oscilloscope along with its visible USB cable, two passive probes, probe documentation, and PC Oscilloscope Quick Guide.
The instrument's compact construction and PC-based operating concept make it an interesting addition to an embedded electronics development environment.
This article represents only the initial unboxing and physical inspection stage. I will reserve conclusions regarding measurement accuracy, bandwidth performance, triggering, software stability, and USB isolation until the corresponding tests have been completed.
My next RoadTest update will focus on software installation, USB driver configuration, initial commissioning, and the first captured waveforms.
I look forward to sharing the detailed test results and practical observations with the element14 engineering community.
STEP -2:
WHEN USB Recognition Wasn't Enough!
ROADTEST TECHNICAL INVESTIGATION · SOFTWARE & HARDWARE COMPATIBILITY
Following the unboxing and initial physical inspection of the MULTICOMP PRO MP720017 EU-UK PC-based oscilloscope, my next activity was to install the associated PC software, establish USB communication with the instrument, and perform the initial commissioning.
Unlike a conventional standalone oscilloscope, the MP720017 depends on a host PC application for instrument configuration, waveform visualization, acquisition control, and measurement functions. Consequently, successful software installation and communication between the oscilloscope and the host computer are essential prerequisites for its operation.
I initially followed the software download information provided through the element14 community.
Element14 software download reference:
https://community.element14.com/products/manufacturers/multicomp-pro/m/files/151198
The installation and initial USB connection, however, did not produce the expected operational result. This led me to investigate the software compatibility and the underlying hardware platform of the instrument.
I downloaded the PC oscilloscope software and associated USB drivers from the software repository shared on the element14 community.
After installing the software and connecting the MP720017 to the computer through the supplied USB cable, the operating system successfully recognized the connected USB device.
However, USB device recognition alone did not translate into successful oscilloscope operation.
Although the instrument was detected by the computer, the initially installed application did not establish the expected level of communication and operational control with the oscilloscope. The instrument was therefore not available for normal waveform acquisition and measurement through that software installation. Here USB driver shows nothing about oscilloscope.
As you can see above, there is no acquisition of random waveform in-spite of successful detection by USB as given in last screenshot.
This was an unexpected observation because the software had been obtained from the product-related software download resource provided through the element14 community.
At this stage, I initially suspected a possible mismatch between the installed application and the oscilloscope hardware or its associated driver/software architecture.
Rather than concluding that the instrument was defective, I decided to investigate its underlying hardware platform and identify whether the MP720017 shared its architecture with another manufacturer's PC-based oscilloscope.
During this investigation, I found that the MULTICOMP PRO MP720017 is associated with the OWON VDS1022I PC-based oscilloscope platform.
The identification is supported by a community-maintained software project for the OWON VDS1022/I, which explicitly identifies the MULTICOMP PRO MP720016 and MP720017 as instruments sold under alternative branding.
The technical specifications also show a strong correspondence between the two instruments.
| Parameter | MULTICOMP PRO MP720017 | OWON VDS1022I |
| Analogue channels | 2 | 2 |
| Bandwidth | 25 MHz | 25 MHz |
| Maximum sampling rate | 100 MS/s | 100 MS/s |
| ADC resolution | 8-bit | 8-bit |
| Acquisition memory | 5 kpts | 5 kpts |
| USB interface | USB 2.0 isolation | USB 2.0 isolation |
The correspondence in the principal hardware specifications provided a strong reason to investigate the OWON VDS1022I software environment.
Reference sources:
OWON VDS series PC oscilloscope: https://en.owon.com.cn/productsdetail/vds-series-pc-oscilloscope.html
OWON VDS1022/I software repository: https://github.com/florentbr/OWON-VDS1022
The OWON manufacturer also maintains a dedicated download section for VDS1022(I) PC oscilloscope software and the associated USB drivers.
Based on the above findings, I decided to investigate whether the software supplied for the OWON VDS1022/VDS1022I could establish proper communication with the MULTICOMP PRO MP720017.
I downloaded the following PC oscilloscope software package:
OWON VDS1022/VDS1022I PC Oscilloscope Software
Download reference:
After extracting and installing this software, I connected the MP720017 to the computer again.
OWON PC oscilloscope software automatically update my old USB driver from 2012 to 2021. Above screenshot also shows that driver is showing the equipment is of OWON make.
This time, I observed a response from the oscilloscope through the OWON software environment.
Although this initial response did not by itself establish that every function of the oscilloscope was operating correctly, it represented an important development in the commissioning process.
The observation suggested that the underlying hardware was capable of communicating with software designed for the OWON VDS1022/VDS1022I platform.
This was a significant finding because it provided a practical direction for resolving the initial software communication problem.
The initial software installation and subsequent compatibility investigation produced the following observations:
5.1 USB Device Recognition
The computer successfully detected the MP720017 after the initial USB connection.
This established that the USB connection and device enumeration were functioning, although it did not establish successful application-level communication.
5.2 Application Compatibility
The first software installation did not provide the expected oscilloscope functionality.
The investigation highlighted the importance of using the correct software package for the particular hardware revision and model.
The element14 download repository contains separate software packages for the MP720016/MP720017 and MP720018/MP720019 models, which is an important distinction when selecting the installer.
5.3 Identification of the OWON Platform
Cross-referencing the product specifications and available technical resources identified the OWON VDS1022/I family as the likely underlying hardware platform for the MP720017.
This finding provided a technical basis for investigating alternative software compatibility.
5.4 Initial Response Using OWON Software
After installing the VDS1022/VDS1022I software package, the instrument began responding within the software environment.
This is a preliminary functional observation and not yet a complete verification of measurement accuracy, waveform acquisition, triggering, or other oscilloscope functions.
In my opinion, this initial experience highlights an important aspect of PC-based test and measurement equipment.
Successful operation depends not only on the physical instrument but also on the compatibility between the hardware, USB drivers, application software, and device-specific communication mechanisms.
An instrument may be successfully detected by the computer at the USB level while the associated application still fails to establish proper communication or initialize the hardware.
For engineers evaluating PC-based instruments, it is therefore important to distinguish between:
USB device enumeration.
Successful USB driver installation.
Application-level device communication.
Hardware initialization.
Actual waveform acquisition and measurement functionality.
These are separate stages of commissioning and should be evaluated independently.
The software compatibility issue encountered during my initial setup also became an interesting part of this RoadTest because it allowed me to investigate the underlying product platform rather than simply proceeding with the first available software installation.
The initial software installation did not provide the expected operational functionality, despite successful USB device recognition by the host computer.
Further investigation identified a strong technical relationship between the MULTICOMP PRO MP720017 and the OWON VDS1022I platform. Installing the corresponding OWON VDS1022/VDS1022I software subsequently produced an initial response from the instrument.
This is a useful preliminary finding, although further testing is required to establish complete software and hardware compatibility.
My next activities will focus on:
Checking the recognition and operation of both analogue input channels.
Performing the initial probe compensation procedure using the Oscilloscope's calibration output.
Capturing known reference waveforms.
Evaluating the time-base, vertical sensitivity, triggering, and acquisition controls.
Investigating waveform measurements, FFT, and other available software functions.
I will document the observations with original software screenshots, photographs, and captured waveforms as the evaluation progresses.
This initial software compatibility investigation has been an important first step in understanding the MP720017, and I look forward to evaluating its actual measurement performance in subsequent RoadTest articles.
STEP -3:
After successfully establishing communication between the MULTICOMP PRO MP720017 PC Oscilloscope and the host PC, my next activity was to perform probe compensation and fine-tune the supplied passive oscilloscope probes.
Probe compensation is an important preliminary step when commissioning an oscilloscope. It ensures that the electrical characteristics of the passive probe are properly matched to the input characteristics of the oscilloscope.
An incorrectly compensated probe can distort the displayed waveform, particularly during fast signal transitions. This can lead to misleading observations when evaluating rise time, fall time, overshoot, undershoot, and other transient characteristics.
The supplied passive probes incorporate a compensation adjustment mechanism, generally implemented through a small adjustable capacitor (compensation trimmer). This adjustment allows the probe's capacitive characteristics to be matched to the oscilloscope input.
I performed this adjustment procedure on the supplied probes before proceeding with further waveform measurements.
A passive oscilloscope probe typically incorporates a resistive and capacitive divider network. The purpose of this network is to attenuate the input signal while maintaining the waveform characteristics as accurately as possible.
In the commonly used 10X probe configuration, the probe provides approximately 10:1 attenuation. However, the capacitive characteristics of the probe must be matched to the input capacitance of the oscilloscope.
The compensation trimmer is used to adjust the probe's effective capacitance so that the capacitive divider is properly matched with the oscilloscope input.
If the compensation is incorrect, the oscilloscope may display a distorted square-wave signal even when the actual calibration signal is correct.
Three conditions are generally encountered during probe compensation:
A. Under-compensated probe
When the probe is under-compensated, the square-wave transition appears rounded rather than maintaining a sharp, well-defined edge.
The upper portion of the square wave may also appear slightly curved instead of flat.
B. Over-compensated probe
When the probe is over-compensated, the leading edge of the square wave exhibits a sharp upward spike or overshoot.
Similarly, the falling edge exhibits a corresponding downward spike, indicating an undershoot-like transient in the displayed waveform.
This was the initial condition I observed during the probe adjustment procedure.
C. Properly compensated probe
When the probe is correctly compensated, the square-wave signal exhibits:
A relatively flat and uniform upper plateau.
A well-defined lower plateau.
Clean rising and falling transitions.
Minimum overshoot or undershoot attributable to probe compensation.
No significant rounding or excessive peaking caused by compensation mismatch.
The objective is to obtain a waveform that accurately represents the calibration signal without introducing distortion from an improperly adjusted probe.
I performed the probe compensation procedure using the Oscilloscope's built-in probe compensation/calibration output.
The following procedure was followed:
Step 1 – Connecting the Oscilloscope Probe
I connected the passive oscilloscope probe to the corresponding analogue input channel of the MP720017.
The probe tip was connected to the Oscilloscope's calibration output, while the probe ground clip was connected to the corresponding calibration ground terminal.
Step 2 – Configuring the Probe Attenuation
I selected the 10X attenuation setting on the probe, following the probe's operating instructions.
The corresponding probe attenuation factor was also configured in the oscilloscope software, wherever applicable, to ensure that the displayed voltage scaling accounted for the probe attenuation.
Correct configuration of the probe attenuation is important because an incorrect software setting can result in displayed voltage values that differ by a factor of ten.
Step 3 – Displaying the Calibration Waveform
After establishing the connections, I enabled the oscilloscope channel and adjusted the vertical sensitivity and horizontal time-base to obtain a clearly visible square-wave calibration signal.
The square-wave signal provides a convenient reference for evaluating probe compensation because its rising and falling transitions make capacitive mismatch readily visible.
Step 4 – Identifying the Initial Compensation Condition
During the initial observation, I found that the displayed square-wave waveform exhibited characteristics of an over-compensated probe.
The rising edge showed a sharp upward spike or overshoot, while the falling edge exhibited a corresponding downward spike.
These observations indicated that the compensation capacitor required adjustment to achieve the correct capacitive matching between the probe and the oscilloscope input.
Step 5 – Adjusting the Compensation Trimmer
I used a suitable probe-adjustment tool to make fine adjustments to the compensation trimmer provided on the passive probe.
The trimmer was adjusted gradually while continuously observing the displayed square-wave waveform.
The adjustment was performed in small increments, allowing the effect of each adjustment on the waveform shape to be observed.
The objective was to eliminate the excessive peaking at the waveform transitions and obtain a properly compensated square wave with flat upper and lower plateaus.
Step 6 – Final Waveform Verification
After fine-tuning the compensation trimmer, I re-examined the displayed square-wave signal to assess the resulting waveform shape.
The final objective was to obtain clean waveform transitions without the characteristic overshoot and undershoot associated with over-compensation, while also avoiding the rounded transitions associated with under-compensation.
This completed the initial probe compensation procedure and prepared the oscilloscope probes for subsequent measurement activities.
The initial over-compensation condition was particularly useful because it demonstrated how an incorrectly adjusted passive probe can affect the displayed waveform.
The sharp upward spike at the leading edge and corresponding downward spike at the falling edge made the compensation mismatch clearly identifiable.
By progressively adjusting the compensation trimmer while monitoring the square-wave signal, the probe could be fine-tuned to achieve the desired waveform response.
This exercise highlighted the importance of probe compensation before undertaking measurements involving clock signals, PWM waveforms, switching circuits, and other signals where edge characteristics and transient behaviour are important.
I have included an original video recording documenting the complete probe compensation procedure performed using the MULTICOMP PRO MP720017.
Given video above demonstrates these points:
Initial connection of the passive probe to the oscilloscope calibration output.
Display of the square-wave calibration signal.
Identification of the initial over-compensated waveform.
Adjustment of the probe compensation trimmer.
Observation of the waveform changes during fine-tuning.
Final inspection of the compensated waveform.
The video provides a practical demonstration of the adjustment process and shows how the displayed waveform responds to changes in the probe compensation setting.
Probe compensation is a small but essential commissioning procedure that should not be overlooked when using a passive oscilloscope probe.
This exercise demonstrated that even when the oscilloscope and probe are connected correctly, improper capacitive compensation can introduce visible waveform distortion.
Correct adjustment helps ensure that the oscilloscope displays a more faithful representation of the signal under measurement.
Now, 2 probes which are connected with 2-channel oscilloscope are well compensated as shown above.
Having completed this initial probe compensation exercise, the MP720017 is ready for subsequent practical evaluation involving voltage measurements, frequency measurements, MCU clock signals, communication interfaces, PWM signals, and power-electronics waveforms.
STEP -4:
As part of evaluating the MULTICOMP PRO MP720017, I decided to use an electronic PCB inspection microscope as one of the practical signal sources for testing the oscilloscope.
I regularly use this electronic microscope for PCB inspection, particularly for examining solder joints, component placement, soldering defects, PCB tracks, and other fine details during hardware development and troubleshooting.
The microscope provides an analogue CVBS video output, which I connected to Channel 2 of the MP720017 for waveform observation and analysis.
My objective was to investigate whether the oscilloscope could capture and display the different components of a composite video signal, including active video information, horizontal synchronisation pulses, blanking intervals, and colour-reference information.
This test also provided an opportunity to evaluate the MP720017's ability to display relatively complex analogue waveforms rather than only simple sine and square-wave signals.
The following oscilloscope configuration was used for capturing the CVBS signal:
| Parameter | Configuration |
| Signal source | Electronic PCB inspection microscope |
| Video interface | Analogue CVBS |
| Input channel | CH2 |
| Channel coupling | DC |
| Vertical sensitivity | 500 mV/div |
| Horizontal time base | 2 µs/div |
| Sampling rate | 100 MS/s |
| Trigger level | 560 mV |
The captured waveform is shown in the accompanying oscilloscope screenshot.
A conventional CVBS signal combines luminance, chrominance, horizontal synchronization, vertical synchronization, and blanking information into a single analogue signal.
The horizontal scanning process generates the picture line by line. At the end of each active picture line, the signal enters a horizontal blanking interval, which provides the necessary timing for the display to return to the beginning of the next horizontal scan line.
The horizontal blanking interval contains several important components:
Front porch
Horizontal synchronization pulse (H-SYNC)
Breezeway
Color burst
Remaining back porch
After the horizontal blanking interval, the active video signal resumes for the following scan line.
My captured waveform provides a good opportunity to identify these components individually.
Following the waveform from left to right, the following components can be identified.
The waveform initially visible on the left-hand side represents the active picture information from the preceding horizontal scan line.
During this interval, the instantaneous signal amplitude carries the image information.
The luminance component represents the brightness variations across the picture, while the chrominance component carries the associated colour information.
Since the microscope is imaging an actual PCB, changes in the observed image content produce corresponding variations in the analogue video waveform.
This is why the waveform does not appear as a perfectly flat signal during the active video interval. Its amplitude continuously varies according to the picture information being transmitted.
At the end of the active video interval, the waveform transitions towards the blanking reference level.
The relatively short interval between the end of active picture information and the beginning of the horizontal synchronization pulse is called the Front Porch.
During this interval, the video signal remains at its blanking reference level.
The front porch provides a short timing interval before the horizontal synchronization pulse begins.
In the captured waveform, this corresponds to the first short, relatively flat section following the downward transition from the active video region.
Following the front porch, the waveform exhibits a distinct negative-going pulse.
This is the Horizontal Synchronization Pulse, commonly referred to as H-SYNC.
The synchronization pulse is an important timing component of a composite video signal.
Its purpose is to inform the receiving display or video-processing circuitry that the current horizontal scanning line has ended and that the next line must begin.
The most negative portion of this pulse is commonly referred to as the Sync Tip.
In my oscilloscope capture, this is visible as the lowest and relatively flat portion of the waveform.
For conventional PAL and NTSC composite video, the nominal horizontal synchronization pulse duration is approximately 4.7 µs.
The duration observed in my capture appears to be in this general range, subject to more precise cursor-based measurement.
After the trailing edge of the horizontal synchronization pulse, there is a short interval before the color burst begins.
This interval is known as the Breezeway.
The breezeway separates the synchronization pulse from the color-reference signal and forms part of the horizontal blanking interval.
In the captured waveform, this corresponds to the short relatively quiet interval immediately following the rising edge of the sync pulse and preceding the oscillatory burst.
Immediately following the breezeway, the waveform exhibits a short packet of high-frequency oscillations.
This is consistent with the Color Burst component of a color composite video signal.
The color burst is a reference signal transmitted during the back porch and is used by the receiving video circuitry to establish the phase and frequency reference for demodulating chrominance information.
In a conventional NTSC system, the color sub-carrier frequency is approximately 3.579545 MHz, whereas a conventional PAL system uses approximately 4.43361875 MHz.
The color burst itself generally consists of several cycles of the color sub-carrier.
In my captured waveform, the oscillatory packet is clearly visible between the horizontal synchronization interval and the beginning of the next active video region.
This is particularly interesting because it demonstrates that the oscilloscope can display not only the relatively slow synchronization transitions but also the higher-frequency chrominance-reference activity embedded within the composite signal.
The exact sub-carrier frequency will require a more detailed time-domain measurement or FFT analysis.
Following the color burst, the waveform returns to a relatively stable blanking reference level before the beginning of active picture information.
This interval is called the Back Porch.
The back porch provides a reference interval before the next active video line begins.
It is also important in video signal processing because the receiver can use this portion of the waveform for DC restoration and black-level referencing.
In my oscilloscope capture, the back porch is visible as the relatively flat section between the end of the oscillatory color-burst packet and the next upward transition.
Following the horizontal blanking interval, the waveform rises into the next active video region.
The active picture information resumes, and the signal amplitude begins varying according to the brightness and color information of the following scan line.
This is visible on the right-hand side of the captured waveform.
The continuous amplitude variations represent the picture information being generated by the electronic microscope.
The sequence of active video, front porch, horizontal synchronization, breezeway, color burst, back porch, and the next active video region constitutes the fundamental horizontal structure of a composite video signal.
This experiment provided several useful observations regarding the MP720017.
1. Analogue waveform visualization
The oscilloscope successfully displayed the composite video signal as a continuous analogue waveform, allowing the different signal transitions and blanking-related components to be observed.
2. Observation of synchronization pulses
The negative-going horizontal synchronization pulse was clearly distinguishable from the active video signal.
3. Visibility of high-frequency components
The short oscillatory waveform following the synchronization pulse was visible, allowing the color-burst region to be identified.
4. Measurement resolution
The 100 MS/s sampling rate corresponds to a sampling interval of 10 ns. This allows multiple samples to represent the individual cycles of a several-megahertz color-subcarrier waveform.
5. Practical application
This experiment demonstrates that the MP720017 can be used for investigating analogue video signals in addition to routine embedded-system waveforms, power supplies, and microcontroller interfaces.
Capturing the CVBS output from my electronic PCB inspection microscope was one of the interesting practical experiments performed using the MULTICOMP PRO MP720017.
The experiment allowed me to observe the structure of an analogue composite video signal and identify several fundamental components, including active video, front porch, horizontal synchronization, breezeway, color burst, and back porch.
This exercise also demonstrates the usefulness of an oscilloscope during video-interface troubleshooting, analogue signal investigation, and hardware development.
For PCB inspection equipment and other embedded video applications, the ability to observe the composite waveform provides an additional method of investigating video output integrity, synchronization timing, and signal behavior.
