RoadTest: Raspberry Pi 2/3 Weather Sensor Shield
Author: ninjatrent
What other parts do you consider comparable to this product?: Raspberry Pi Sense HAT , Pimoroni EnviroHAT
What were the biggest problems encountered?: Thermal interference to the sensor readings from the Pi 3's BCM2837 Processor. Limits access to unused GPIO pins.
DPP904R000 - MEAS PI WEATHER SENSOR SHIELD BY TE CONNECTIVITY
GENERAL DESCRIPTION
The MEAS Pi weather shield provides the necessary hardware to interface the HTU21D digital relative humidity sensor; MS5637 digital barometric pressure sensor; temperature system sensor (TSYS)01 digital temperature sensor; TSD305-1C55 digital thermopile sensor to any system that utilizes Raspberry Pi compatible expansion ports configurable for I2C communication. The HTU21D sensor is a self-contained humidity and temperature sensor that is fully calibrated during manufacturing. The sensor can operate from 1.5V to 3.6V, has selectable resolution, low battery detection, and checksum capability. The HTU21D has a low power stand-by mode for power-sensitive applications. The MS5637 sensor is a self-contained pressure and temperature sensor that is fully calibrated during manufacturing. The sensor can operate from 1.5V to 3.6V. The sensor module includes a high-linearity pressure sensor and an ultra-low power 24-bits ΔΣ ADC with internal factory-calibrated coefficients. The temperature system sensor -TSYS-01 series is a self-contained temperature sensor that is fully calibrated during manufacturing. The sensor can operate from 2.2V to 3.6V. The TSYS01 has a low power stand-by mode for power-sensitive applications. The TSD305-1C55 is a contactless temperature measurement system located in a TO5 package. The TSD includes an infrared sensor (thermopile) and a sensor signal conditioner.
Specifications
HTU21D - Digital Humidity Sensor
http://www.te.com/usa-en/product-CAT-HSC0004.html
• Measures relative humidity from 0% to 100%
• Measures temperature from -40°C to 125°C
• I2C communication
• Fully calibrated
• Fast response time
• Selectable resolution 8/12-bits resolution for humidity; 11/14-bits resolution for temperature)
• Very low power consumption
MS5637 - Digital Pressure Sensor
http://www.te.com/usa-en/product-CAT-BLPS0037.html
• Measures pressure from 300 mbar to 1200 mbar
• I2C communication
• Fully calibrated
TSYS01 - Digital Temperature Sensor
http://www.te.com/usa-en/product-G-NICO-018.html
• I2C communication
• Fully calibrated
• 24/16-bits resolution for temperature
TSD305-1C55 - Digital Infrared Thermopile Sensor
http://www.te.com/usa-en/product-G-TPMO-101.html
• Measures temperature from 0°C to 100°C
• I2C communication
• Contactless temperature measurement
• Fully calibrated
• Up to ±1°C accuracy
• Operating Temperature Range: -10°C … +85°C
• Low current consumption
Performance
• 0% to 100% relative humidity range (HTU21D sensor)
• Operating pressure range: 300 to 1200 mbar (MS5637 sensor)
• Measures temperature from -40°C to 125°C, accuracy from 0.1°C to 0.5°C (TSYS0101 sensor)
• Contactless temperature measurement from 0°C to 100°C (TSD305-1C55)
Testing
This Weather Sensor Shield has been personally tested and confirmed as compatible with the Raspberry Pi 3 and the Raspberry Pi Zero Wireless.
I have tested this shield directly attached to the Pi 3’s GPIO Connector,
attached to a Pimoroni BLACK HAT HACK3R GPIO Breakout Board with ribbon cable,
and directly attached to a Pi Zero W.
Getting Started
The most recent Raspbian Stretch Lite and Desktop is found at the Raspberry Pi Foundation's website.
https://www.raspberrypi.org/downloads/raspbian/
The Python Framework and example source code provided by TE Connectivity on the corresponding github page is very helpful for getting started with this Weather Sensor Shield.
https://github.com/TEConnectivity/piweathershield-python
git clone https://github.com/TEConnectivity/piweathershield-python
sudo i2cdetect -y 1
python setup.py install
IBM Bluemix
IBM Bluemix recipe available at
https://developer.ibm.com/recipes/tutorials/connect-te-connectivity-digital-sensors-to-cloud/
With this Shield connected directly to the Pi 3, the sensor readings are affected by heat generated by the BCM2837 processor. This can be remedied with the use of a GPIO ribbon cable and heatsink. With the use of the ribbon cable, sensor readings are very accurate.
sudo python example.py
Notice the Object Temperature matches the temp reading of the TSD305 Infrared Thermopile Sensor.
This is because there is nothing in range of the sensor. When I place my hand in front of this sensor,
the reading is very consistent with the known average temperature of the human body.
This Weather Shield is compatible with the Pi Zero Wireless, and there is less thermal interference to the sensor readings.
This Weather Sensor Shield is confirmed to work with the Raspberry Pi Zero Version 1.3.
Attached to the bottom of the Pi Zero Ver. 1.3 is a Zero4U - 4 Port USB Hub with a TP Link USB WiFi Module.
There is a strip of 3M Dual Lock Command Adhesive on the bottom for modular attachment.
The Pi Zero W with the BCM2835 processor seems to be an ideal candidate for this Shield.
This TSD305-1C55 infrared thermopile sensor is a very interesting sensor to find on a Raspberry Pi Shield. It is the key feature that attracted me to this product.
In order to determine the accuracy of this sensor, a block of solid ice water was placed in front of the thermopile and a few temp readings were captured. The range of this sensor is 0°C to 100°C.
Freshwater freezes at a temperature of 0°C or 32°F and boils at a temperature of 100°C or 212°F.
With the thermopile sensor aimed at the ice block, readings were found to be consistent with the known freezing temp of water (+/- a few degrees).
Notice the TSD305 is sensing an Object Temperature of 0.3°C or 32.54°F. Cool!
Final Remarks
The DPP904R000 - MEAS Pi Weather Sensor Shield by TE Connectivity is a excellent collection of precision sensors on a Raspberry Pi HAT.
With the Python code and IBM Bluemix code provided by the supplier, it is very easy to get started with this Sensor Shield.
I am impressed with the quality of manufacture.
Each sensor is labeled with an easy to read, silkscreen font.
The TSD305 - Contactless Infrared Thermopile Sensor is a great feature, bringing new functionality and innovation to the Raspberry Pi.
This Weather Sensor Shield has been tested and confirmed to be compatible with the Raspberry Pi 3, Pi Zero Wireless, and Pi Zero Version 1.3.
The BCM2837 processor of the Pi 3 can generate heat that might affect sensor readings. Use of a heatsink or means of extending the GPIO connections with a GPIO Ribbon Cable is recommended.
Suggestions for future versions of this Weather Sensor Shield.
- Addition of pinouts for the Pi's GPIO not used by the Shield.
- Daylight and UV Sensors
- Analog pinouts
- Version in Raspberry Pi Zero form factor.
Thank you for your time in reading this Element 14 Road Test Review.
And thanks to everyone at Element 14 and TE Connectivity for allowing me the privilege of test driving this product.
