Analog Discovery 2 + LabView Home Bundle - Review
View table of contents ...
RoadTest: Analog Discovery 2 + LabView Home Bundle
Author: s2000gt
What other parts do you consider comparable to this product?: Saleae Logic
What were the biggest problems encountered?:
The Analog Discovery 2 arrived in it's nice clear plastic case with everything to get started along with the d/l version of Labview 2014.
Waveforms:
The main menu with 13 instrument selections.
The network analyzer with a 10 khz LP filter. AD 2 accurately records it at 10.4 khz.
Testing with the included flywires, resulted in an effective b/w of about 9 mhz, matching Digilents specifications.
The optional bnc adapter board allows full range capability of the device, sacrificing only differential input to the o-scope.
  • Analog bandwidth with Discovery BNC adapter: 30+ MHz @ 3dB, 10 MHz @ 0.5dB, 5 MHz @ 0.1dB (o-scope)
  •        12 MHz @ 3dB, 4 MHz @ 0.5dB, 1 MHz @ 0.1dB (wave gen)
  • Analog bandwidth with included flywires: 9 MHz @ 3dB, 2.9 MHz @ 0.5dB, 0.8 MHz @ 0.1dB
O-scope provides accurate measurement with factory calibration settings.
Spectrum analyzer depicting FM and AM modulation input on 500khz carrier signal.
O-scope with FFT window reading 200khz signal.
Accurate power supply output with factory calibration.
Impedance circuit testing with multiple functions.
Summary:
Previously I reviewed Digilent's Digital Discovery Digilent Digital Discovery with High Speed Adapter - Review and found it to be a very capable
though specialized device, still needed a bit of fine tuning. With the Analog Discovery 2, a unit that has a long history of development, it really shows
what a mature product can do. I found little that couldn't be done with this device that any technician would need in a very portable device.
The Waveforms software is fully utilized to it's extent and I could find very little to improve on. As stated before, the bnc adapter is really a must have to
get the most out of this unit.
