3D Printing
3D Printing
3D Printing Forum Ender 3 pro enclosure recommend
  • Replies 16 replies
  • Subscribers 338 subscribers
  • Views 6331 views
  • printer
  • 3d_printing
  • enclosure
  • 3dprinting
Hanhanna
Hanhanna over 2 years ago
Hi, I have an Ender-3 pro with the Sprite extruder, I want to buy an enclosure.
Is there an enclosure recommended?
  • irotsoma
    irotsoma over 2 years ago in reply to opalko +3
    Helps with keeping the temperature stable, reducing exposure to fumes, which isn't a huge deal with PLA or PETG unless it burns, but still a good thing, and fire protection. They won't stop a really hot…
  • rsc
    rsc over 2 years ago in reply to jaygee59 +3
  • Umuju
    Umuju over 2 years ago in reply to Jan Cumps +3
    Nah, it’s in a finished basement. I’m at more risk from my kid’s legos 8-p
    Jan Cumps over 2 years ago in reply to Umuju
    Always wear safety shoes on your shopfloor ;)
  • cstanton
    cstanton over 2 years ago in reply to Jan Cumps
    3D print... some?
  • Umuju
    Umuju over 2 years ago in reply to cstanton
    I don’t print anything except PLA or TPU on these machines. I do have a Welding rated fume extractor as well as a couple of in line ventilation fans I picked up in case I felt the need. I would most likely print a shroud to screw my cooling fan to through the plexiglass and then have the 4” inline fan at the point of exhaust. The case is within 10’ of the window
  • Umuju
  • cstanton
    cstanton over 2 years ago in reply to Umuju
    Unfortunately, the fumes from PLA are still toxic even if they can be less abundant in some circumstances than ABS. There's a good comparative report here:
    https://chemicalinsights.org/wp-content/uploads/2022/12/Chemical-Insights_3D-Toxicity-Report_final.pdf
    Other reports also exist.
  • lilyclark
    lilyclark over 1 year ago
    I recommend the official Creality Enclosure (V2), which can be easily installed on the Ender-3 Pro, even if it’s been upgraded with the Sprite direct drive.
    It’s foldable, portable, and helps retain heat for ABS/ASA printing. It strikes a good balance between cost and ease of setup, though it’s not as rigid as a hard-frame enclosure.
    • Vote Up -1 Vote Down
