Transportation & Automotive
Blog Sphere drone robot
Join Transportation & Automotive to participate - click to join for free!
  • Author Author: Eavesdropper
  • Date Created: 10 Jun 2011 7:33 PM Date Created
  • Views 686 views
  • locomotion
  • transportation
  • japan
  • robot
  • drone
Sphere drone robot
Eavesdropper
Eavesdropper
10 Jun 2011
This video is unavailable.
The Japanese Ministry of Self-Defense went to the geek capitol of Akihabara, a section of Tokyo, to source parts for this "reconnaissance drone." In its current form, it can travel 40 mph for up to 8 minutes. Since the drone if built inside of a protective sphere, it can withstand the sudden impact of drop after losing power. 8 separate fins around the sphere control the direction, and it seems to handle quick turns very well. The 42cm, diameter, drone weighs only 350 grams with all the components and onboard camera. All the parts, collectively, cost approximately $975 USD.
The simplicity, low cost, and versatility of this drone is sure to inspire more and better version. Add thin-cell solar to the roll cage, increase the battery size, and these things will be everywhere. On one hand, these could be used to watch and control people. On the other, they could keep people safe, guide them through cities, or lead them to locations. Either way, I'm all for them.
Eavesdropper
    DAB over 15 years ago
    After watching the video I want one.  This thing is so cool and it has a wide range of possible applications.  Just think about the area you could cover in a search and rescue operations with these tools.  Absolutely amazing, you could coordinate efforts very quickly and get help to survivors very efficiently.  Over water, you could put a raft and supplies in a dropable package and send these things out to find people in the water and drop them a raft with food, fresh water and trigger a GPS transmitter so they could be rescued.
    A whole lot of these could do a lot of work normally done by people on the ground, except these things could cover a whole lot more area in a given time frame.
    Thanks,
