Transportation & Automotive
Documents MPC564xL: Qorivva 32-bit MCU for Chassis and Safety Applications*
Join Transportation & Automotive to participate - click to join for free!
  • Author Author: autoembedded
  • Date Created: 29 Aug 2012 4:29 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:11 AM
  • Views 753 views
The Qorivva MPC564xL family of 32-bit Power ArchitectureRegistered MCUs is designed to specifically address the requirements of the safety standards IEC61508 (SIL3) and ISO26262 (ASIL-D). It reduces design complexity and component count by putting key functional safety features on a single chip with a dual-core, dual-issue architecture, which can be statically switched between lockstep mode (redundant processing and calculations) to decoupled parallel mode (independent core operation). Qorivva MPC564xL MCUs are SafeAssure functional safety solutions.
Features
  • Dual e200 Z4 CPU architecture
  • Dual processing spheres including; CPU, DMA, interrupt controller, crossbar and MPU for logic level fault detection
  • Two statically configurable modes of operation: Lockstep operation (redundant processing and calculations) and dual parallel mode (independant core operation)
  • Fault collection unit, which monitors and manages fault events
  • Error correction coding on RAM and flash memory allows detection/correction of memory errors
  • Designed to address safety requirements outlined in IEC61508 and ISO26262
  • Robust communications with FlexRayTm and CAN/safety port high-speed low latency messaging
  • Cross-triggering unit coordinates ADC, timer and PWM generation and minimizes CPU interrupt load
  • eTimer x 3
  • ADC x 2
  • 32bit
  • freescaledocs
  • safety_applications
  • chassis
  • freescale
  • power_architecture
  • microcontrollers
  • qorivva
  • automotive_safety
  • automotive
  • mcu
  • chassis_safety
  • safety
  • safeassure
