Transportation & Automotive
Documents XKT564L: Evaluation system supporting MPC564xL 32-bit microcontrollers*
Join Transportation & Automotive to participate - click to join for free!
  • Author Author: autoembedded
  • Date Created: 30 Aug 2012 5:09 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:11 AM
  • Views 662 views
The XKT564L EVB is an evaluation system supporting our MPC564xL microcontrollers. The complete system consists of an XPC56xxMB2 motherboard and an XDC564L daughter-card which plugs into the motherboard. Different daughter-cards are available for evaluating devices with different footprints in the MPC564xL family of microcontrollers. The evaluation system allows full access to the CPU, all of the CPU’s I/O signals, and the motherboard peripherals. The mini-module may be used as a stand-alone unit, which allows access to the CPU, but no access to the I/O pins or any motherboard peripherals.
XKT564L KIT Features
  • XKT564L144S1M (KIT) contains a XDC564L144S1M (Mini-Module board) which has a socket for MPC5643L in 144LQFP footprint / XKT564L257S1M (KIT) contains a XDC564L257S1M (Mini-Module board) which has a socket for MPC5643L in 257MAPBGA footprint
  • The Mini-Module Boards can be used as a stand-alone board by providing external 12V power supply input
  • XPC56xxMB2 motherboard
  • ON/OFF Power Switch with LED indicator
  • Reset button with filter and LED indicator
  • XPC56xx Resources CD-ROM
  • P&E USB-ML-PPCNEXUS Hardware Interface Cable
  • USB A-to-B Cable
XPC56xxMB2 Board Features
  • A 12VDC power supply input barrel connector
  • 2 CAN channels with jumper enables
     - One channel with High-Speed transceiver
     - One channel with Low-Speed Fault Tolerant and High-Speed transceiver (selectable with jumpers)
  • 2 LIN channels with jumper enables
     - One with transceiver and pin header connector populated
     - One channel with footprints only
  • 1 SCI channel with jumper enables
  • 2 FlexRay channels with jumper enables
     - One channel with transceiver and DB9 male connector
     - One channel with footprint only
  • 4 user push buttons with jumper enables and polarity selection
  • 4 user LED’s with jumper enables
  • 1 potentiometer for analog voltage input
Kit Contains
  • XPC56xxMB2 Motherboard
  • XDC564L144S1M or XDC564L257S1M Mini-Module
  • USB A-to-B Cable
  • Freescale Warranty Card
Go directly to the Buy / Specifications page here.
  • 32bit
  • freescaledocs
  • evaluation_system
  • freescale
  • power_architecture
  • microcontrollers
  • dual-core
  • evalution_kit
  • Technology
  • Motherboard
  • automotive
  • mcu
  • daughter-board
