Transportation & Automotive
Documents Automotive body and gateway applications: Qorivva MPC560xB/C/D*
Join Transportation & Automotive to participate - click to join for free!
  • Author Author: iLOVEautomotive
  • Date Created: 20 Feb 2013 6:31 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:28 AM
  • Views 718 views
The Qorivva MPC560xB/C/D family of 32-bit MCU includes the latest Freescale integrated devices for automotive body electronics applications. The advanced  cost-efficient host processor core leverages the many strengths of Power  ArchitectureRegistered  technology, such as processing capability, on-chip memory, analog  capabilities, timing systems and other features required to handle complex control and diagnostic systems. In addition, these scalable devices are supported by an  enablement ecosystem that includes software drivers, operating systems and  configuration code to help you quickly implement your designs.
Qorivva MPC560xB/C/D  Key Features
Includes controller area network (CAN),  local interconnect network (LIN) and other  peripherals necessary to implement a range of  functionality in the automotive body network.
  • FlexCAN module supporting both FIFO and mailbox data storage, ideal for CAN gateways to manage event-driven vs.  periodic bus traffic.
  • LINFlex module provides fully automated LIN message management, reducing CPU  load intervention and message latencies.
  • eMIOS timer combines multiple counter sources, including input capture, output  compare and pulse width modulation  (PWM) capabilities into one very flexible module. PWM function supports shifted signal output to improve  electromagnetic compatibility.
  • Cross triggering unit synchronizes PWM output signals with analog-to-digital  conversion to enable accurate diagnostic  and control capabilities.
  • Scalable e200z0 core enables migration toward higher performance solutions.
  • Compatible family of products ensures reuse of software and tools infrastructures.
In addition, the Qorivvva MPC5601D, MPC5602D, MPC5605B, MPC5606B and MPC5607B are available with direct memory access.
Click here to view full Fact sheet (Block Diagram, slector guide, tools, etc)
  • 32bit
  • freescaledocs
  • gateway_applications
  • freescale
  • gateway_controllers
  • qorivva
  • body_control
  • automotive
  • mcu
  • body_electronics
