Business of Engineering
Forum Have Idea, Need Help... LED Lighting related.
Join Business of Engineering to participate - click to join for free!
  • Replies 19 replies
  • Subscribers 241 subscribers
  • Views 2873 views
Hi all! I have an idea, I think it's a good Idea but don't know what hardware to use.
I'm looking to make a network of Sidewalk Lights Using RGB+W LEDs. I really like the "NeoPixel Sticks" so that would be a good start.
Sounds simple, right?
Well, I would like each "Sidewalk Light" to have two Ultrasound/Distance sensors. One looking in each direction of the sidewalk. As a person walks closer to the light, the light will start illuminating. First the LED closest to the person. As the person walks closer the Light will illuminate more and more of the LED's. All LED's are lit, when the person is standing right in front of the light.
As the person walks away, the opposite happens. This should have the effect of the light following the person as they walk light to light. I plan on spacing them about 4'-6' apart.
They will be powered by a buried Low voltage cable and networked via I2C (For example could be WiFi as well, who knows.) together so that the color and intensity can be controlled from a central location. (Orange during Halloween, Green and Red during Christmas, Red White and Blue during 4th of July, and so on... ) The distance Sensor information may be passed back to the master controller via the network so the master controller can respond by controlling that lights LED's accordingly. This way the Light doesn't need any kind of smarts and just acts as a slave.
I may also use the neighboring light's distance sensor to tell the light the person is standing in front of (Via the Master Controller) to stay lit since the person may be standing in between the two Distance sensors field of sight.
In the long run, I would like to expand this same system into the back yard to illuminate the Deck, walk way's, Fence, Pool and Hot Tub. Here again, I would like to control everything from a central location to be able to turn off or on all LED's manually, change the color scheme and/or brightness, or make one color chase another color throughout the entire property.
I realize with this size of a system, I will likely need a full blown PC to control it and I have no problem with that. What I do want, is to keep the cost per Light down as much as possible. If I can keep the cost at about $25-$35 ea. That would be great. less, even better.
Let me know what you guy's think. Eventually, I think this could be a pretty cool commercial product if done right.
So what I'm looking for, is a board that can take two Distance Sensors and report that data back to the master controller, and also be able to control Multiple RGB+W LED's according to instructions sent to it from the master controller.
I found an reasonably priced Ultrasonic distance sensor here for around $5 ea.
Now I need an I2C board that can take two of the Ultrasonic sensors and also control the LED's according to instructions sent from the master controller.
Any Input/help, would appreciated.
--Mike
    e14 Contributor over 10 years ago +1
    So as it stands at the moment, I think i will go with one controller per Light, then a zone controller, then a master controller. The Light and Zone controllers will most likey be ATMel microprocessors…
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    Hugo Matias
    Welcome to: livingleds.com This Web page is parked for FREE, courtesy of GoDaddy.com.
    and
    Updated Date: 07-dec-2015
      Creation Date: 04-jun-2014
      Expiration Date: 04-jun-2016
    Why no web page after almost two years?
    I personally would look elsewhere.
    Clem
    e14 Contributor over 10 years ago in reply to e14 Contributor
    At what point would you guys come into play? I tried looking up your company, but after the initial Amnesty international ad your page comes up empty.
    --Mike
    e14 Contributor over 10 years ago in reply to clem57
    Because I was working in OSRAM and I just open LivingLeds companie a few months ago.
    it will be launch in April.
    No web page yet. It will be launch in April. Regarding the other questions i have just send you an email.
    One other information. I'm going to light + building tomorrow and I can give you a feedback about the actual premium solutions on this field.
    Hugo
  • clem57
    http://www.houzz.com/pro/serotonina/livingleds
    lisbon 2000299
    Portugal
    Is this you?
    Clem
    This is me:
    https://pt.linkedin.com/in/hugo-matias-b29417b
    why are you searching Livingleds?!!!!...
    livingleds is a company...don't need to search you just need to ask...
  • clem57
    When a brand new person shows up, seems reasonable to get more credentials. I thank you for providing them. I withdraw my negative earlier  comment.
    Clem
    No problem, is normal. Just for your information Livingleds is a respectable company with people coming from Philips,OSRAM, University research, Phd in light design and Univesity professores, with incubation in the most advanced park of technology and science of Portugal.
    Our mission is to bring innovative products to the lighting market, so we are able to launch, develop, sell and get investment to good projects.
    Feel free to have a look in the web site in April on Livingleds Lab...
    So as it stands at the moment, I think i will go with one controller per Light, then a zone controller, then a master controller. The Light and Zone controllers will most likey be ATMel microprocessors due to the availability, price and flexibility of them. Most likely I will use the "Trinket".
    For the distance sensors, I'm looking at something like this. Because it only requires one unit rather than two (one Send and one Receive), it would take up less space. It's also waterproof and can be mounted flush into the housing. These sensors require 2 GPIO pins per device. I'm not sure if I will be able to get away with 2 per light, if not, I will use three.
    I will have the Zone controller sync them all, so that they do not interfere with one another.
    I've looked at IR but they are a bit more price wise.
    For the LED's, I found a flexible strip that holds 7 "Smart" RGBW LED's. This will let me take a strip of 7 and mount them at an Arc, so each LED points to a different section of the walkway. This strip will only use one GPIO pin to control all 7 of the LEDs.
    Communication wise, at the moment, I'm looking at RS485 since it seams to be better suited for longer range applications.
    I still need to see how I'm going to connect them all together and back to the zone controller. I'm looking at using RJ11 plugs and some sort of outdoor cat3 direct burial cable. I've seen the Military phone cable that is really strong but I'm not sure how well it works against interference, considering it will most likely be laying directly on top of the Low Voltage supply line.
    Next up, pricing to see how much one light will cost electronics wise. Then I need to design the housing and mounts.
