Business of Engineering
Forum College or work experience
Join Business of Engineering to participate - click to join for free!
  • Replies 13 replies
  • Answers 9 answers
  • Subscribers 242 subscribers
  • Views 3235 views
  • college
  • buisness
salesm21
salesm21 over 8 years ago
Dear friends,
I have a big decision ahead of me and wish to have the community input. I am applying to Florida Tech and they have two education paths available to travel. One is called the protrack option and it involves a co-op between you and another local company where you have a paid internship. This is a 3-4 ratio of semesters in class. So you spend 3 in the internship and 4 in college yet still finish in 4 years with a bachelors. (Mine will be a dual major in electrical engineering and computer science) The other option is called the FastTrack and is where you can obtain your masters in 5 years in an accelerated education plan. Is a masters weighed heavier or is experience weighed more. I cant do both (I asked) and with the FastTrack I could do internships but they would be after school and cut into homework time. I could do it but itd be grueling and I dont know how serious they would take an unpaid intern. Any advice would be great.
    jw0752 over 8 years ago +4 suggested
    Hi Mitchell, The actual answers have to come from you but here are some questions that might help you decide. What do you want to do with the degree? Do you envision your future work as primarily theoretical…
    genebren over 8 years ago in reply to salesm21 +4 suggested
    Mitchell, I my case it was a combination of things that limited my career. Location, over specialization and a desired to balance work and lifestyle. Location - I settled in a area that looked to have…
  • james.flynn
    james.flynn over 8 years ago +4 suggested
    First off, congrats on going to Florida Tech (I am biased, I graduated from there when it was called Florida Institute of Technology). As to the 'should I co-op while getting a degree', my experience is…
  • salesm21
    0 salesm21 over 8 years ago in reply to genebren
    Gene,
    It sounds like a lot of your frustration came from the fact that you parent company combined with someone else which will inevitably create friction. How would you recommend not going down the path of specialization? Sometimes Ive seen where becoming really good at something makes you in high demand. Why was your becoming a dying field? Lastly I have a more controversial question. I am currently married and am wondering if this will hold me back in my engineering career.
    0 genebren over 8 years ago in reply to salesm21
    Mitchell,
    Over specialization is really only problematical when it involves an industry that winding down.  The automatic test equipment industry that I was most involved in was based on the concept of a bed of nails making contact with an assembled printed circuit board (in-circuit testing or ICT).  The issue was one of geometry.  As surface mount became more popular and the pin spacing tighter, it became to dense to get good coverage (without a lot of special layout), so the value of ICT tester took a big beating.  Prior to that time, the key for ICT was that you did not really have to do anything special in manufacturing to utilize this technology. Long story short, the division that I worked for eventually was closed down and later the products were discontinued. A lot of what I knew was still valuable, but my personal stock dropped as no one needed an expert with my exact skill set.
    As to you second question, I can safely say that marriage never held my career back.  If anything, my marriage (at least my second one) allowed me the freedom to take on higher risks positions, like working in start-ups or even starting my own venture.
    Best of luck,
    Gene
  • james.flynn
    0 james.flynn over 8 years ago in reply to salesm21
    Mitchell, I've been married 32 years, would do it the same way given the opportunity for a do-over. It is illegal to use marriage, race, or religion as a factor in job placement... and while that sounds good, we all no it sometimes happens as an unspoken thing. But if you are working for someone that is using that as a factor, my suggestion would be find a different employer, if they will use that against you who knows what else they would use.
