Circuit Protection
Circuit Protection
Forum HELP!!!.... Blown Electric Mistress pedal
Join Circuit Protection to participate - click to join for free!
  • Replies 48 replies
  • Subscribers 72 subscribers
  • Views 9955 views
Andy Betts
Andy Betts over 6 years ago
I have made a huge school boy error... i was looking at running my original Electric Mistress pedal for a recording I'm doing and needed to run it off an external power supply. I had a 18v supply to hand which I just needed to connect up to a DC plug so that I could power the pedal. In my haste, I accidentally connected the negative and voltage wires the wrong way round...... connected the pedal, switched on the power and I immediately heard a small pop and the smell of burning. I have blown an original 1977 Electro Harmonix Electric Mistress effects pedal worth around $500!!! however, i'm sure it's not dead yet, and it can be brought back to life... Hence this post.
For your reference I have attached the schematic.
can anyone advise the best place to start troubleshooting, I'm assuming anything on the ground side of things could have been the first thing to blow, and I'm thinking a transistor.... bearing in mind the 18v supply was connected to the ground, and the ground was connected to the voltage in. Anything can be replaced, the only issue is if the culprit ends up being the SAD1024 chip that's it... the pedal is a gonner. However I very much doubt the voltage got that far in the circuit to be honest (hopefully)
imageMistress_v2_schematic.pdf
    jw0752 over 6 years ago +4
    Hi Andy, I wanted to understand the voltage regulator a little better so I built one on the bread board. My original intention was to also hook it up backwards to see how it failed. I have decided not…
  • Andy Betts
    Andy Betts over 6 years ago in reply to Andy Betts +4
    repaired... Transistor was around the wrong way
    DAB over 6 years ago +3
    Bad luck is a pain. I looked over your schematic and you will probably need to replace all electrolytic capacitors as they do not tolerate being hooked up wrong. If you smelled or saw smoke, you probably…
  • Andy Betts
    Andy Betts over 6 years ago in reply to Jan Cumps
    How do you establish that..... by working it out??
    Seems high, let me check again in case I measured the wrong leg
  • Andy Betts
    Yep... I measured the correct leg
  • Andy Betts
    Just looking at your post, and the schematic.... Did you mean the voltage on the emitter, not the collector?
    The voltage on the emitter should be 12v - 13.5v, but I'm actually measuring 8.2v on the emitter
  • Andy Betts
    Just rechecked my measurements, there was an error on the LM741
    should be:
    1 - 0
    2 - 10.52
    3 - 4.38
    4 - 0
    5 - 0
    6 - 3.13
    7 - 24.1 (just checked my power supply and that is supplying 24.1v instead of 18v. In my initial readings looks like I put the decimal point in the wrong place... my bad)
    8 - 0
    Jan Cumps over 6 years ago in reply to Andy Betts
    The collector should be 12 V. Not the voltage of your supply.
  • Andy Betts
    Dammit.... my bad... it's PNP...
  • Andy Betts
    I'm wondering if I have the transistor in the wrong way round..... i'll double check
  • Andy Betts
    repaired... Transistor was around the wrong way image
