Circuit Protection
Circuit Protection
Documents SCHURTER launches CSO clip, designed for heavy duty performance
Join Circuit Protection to participate - click to join for free!
  • Author Author: schurter
  • Date Created: 29 Jun 2012 5:47 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:56 AM
  • Views 575 views
CSO – Heavy Duty Fuse Clip
SCHURTER, the leading provider of fuse holders, is expanding its range to include a fuse clip designed for heavy duty performance.
The CSO clip, designed for 10.3 mm diameter fuses, is suitable for applications with voltages up to 1500 VAC/VDC and currents to 32A.
These unique characteristics are SCHURTER’s response to the present need for increasing photovoltaic system voltages.
The CSO clip is available in solder and screw/rivet versions. The solder version allows direct mounting on a printed circuit board by means of through-hole technology. The screw/rivet version provides additional flexibility for basic designs. Due to the special copper alloy both versions are characterized by a strong clamping force resulting in minimal power loss.
The CSO fuse clip is ideal for a wide range of PV and other DC applications including inverters, battery charge controllers, and string fuse holders. Furthermore, the CSO is well suited for applications in the emobility and industrial electronics sectors. The fuse clip conforms to RoHS specifications and is currently the only photovoltaic clip on the market with cURus approval.
SCHURTER also offers the ASO 10.3x38 PV fuse to fit the new CSO fuse clip. The fuse clip also supports other fuses with a 10.3 mm diameter of any length. This includes, for instance, 10.3x85 mm fuses for higher voltages.
Technical features and benefits:
- High rated voltage of 1500 VAC/VDC
- High rated current of 32 A
- Minimal power dissipation due to strong clamping force (special copper alloy)
- Solder, screw or rivet mounting
- cURus approval
Appropriate fuse links:
- SCHURTER fuse, 10.3 x 38 mm, 1000 VDC, gPV: ASO 10.3x38
- Fuse links with diameter 10.3 mm of any length, up to 1500 VAC/VDC and 32 A
Applications:
- Photovoltaic inverters
- String fuse holder
- Battery charge controllers
- DC applications
- Industrial electronics
- Drives
Resources:
Technical data http://www.schurter.com/pdf/english/typ_CSO.pdf
Stock check http://www.schurter.ch/en/Services/Stock-Check-SCHURTER
Product news http://www.schurter.com/New-Products/Fuses-Fuseholder
Partner Service Links for Type: “CSO“ in Product Group: “Fuseholders“
Training documentation http://www.schurter.com/en/Services/Partner-Services/Partner-Service
Category: “Training Presentations“
PR Text http://www.schurter.com/en/Services/Partner-Services/Partner-Service Category: “Press Releases“
Cross Reference List http://www.schurter.com/en/Services/Partner-Services/Partner-Service
Category: “Cross Reference“
About SCHURTER Group
The SCHURTER Group is headquartered in Lucerne (Switzerland) since 1933. SCHURTER is an internationally leading innovator and manufacturer of fuses, connectors, circuit breakers, input systems and EMC products as well as a PCB assembly service provider. Our industries span telecommunications, IT, medical and measurement technology sectors, emerging food & beverage and alternative energy industries. The major country-specific certifications including VDE, ENEC, UL, CSA, CCC, METI or KTL are evidence of our high quality and absolute reliability in each product.
Contact: info@schurter.com.sg
Website: www.schurter.com
  • fuse
  • clips
  • inverter
  • switzerland
