Circuit Protection
Circuit Protection
Documents SCHURTER common mode chokes datasheets now contain impedance diagrams and cURus approval mark
Join Circuit Protection to participate - click to join for free!
  • Author Author: schurter
  • Date Created: 13 Aug 2012 9:07 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:07 AM
  • Views 598 views
Common Mode Chokes
SCHURTER, as a leading supplier of EMC products is constantly improving
the use of its products. The SCHURTER common mode chokes datasheets
now contain impedance diagrams and cURus approval mark.
Current compensated chokes are used to attenuate asymmetrical noise. Such common mode noise is typical for switch circuits such as switching power supplies or inverters. The compact chokes guarantee efficient disturbance suppression on the printed circuit board. Very compact types for surface mounting are also available as are chokes with wire leads for easy assembling for high power applications.
According to the noise level, design engineers can easily select the right choke using the impedance diagram. This may help to avoid many costly and time consuming measurements. Impedance diagrams are now available for all common mode chokes.
A safety certificate can be obtained even quicker due to the new UL approvals for our chokes. All SCHURTER common mode chokes now have the combined UL and CSA approval mark cURus. They were successfully tested according to the UL 1283 and CSA 22.2 No. 8
  1. standard. Approval marks and standards are now listed on all the data
  2. sheets.
Technical Features
- Rated Voltage 250 / 760 VAC
- Rated Current 300 mA - 50 A
- Rated inductance 0.5 mH - 100 mH
- Operating temperature -40 - 125 °C
- Multiple housing options available
Applications
- Switching power supplies
- Inverter
- Industrial electronic
- Lighting
Resources:
Datasheets: http://www.schurter.com/Components/EMC-Products/Suppression-Chokes
About SCHURTER Group
SCHURTER continues to be a progressive innovator and manufacturer of electronic and electrical components worldwide. Our products ensure safe and clean supply of power, while making equipment easy to use. We offer a broad range of standard products including circuit protection, connectors, switches, EMC products and input systems, as well as electronic manufacturing services. Moreover, SCHURTER is ready to work with our customers to meet their application specific requirements, not covered in our standard range. You can rely on SCHURTER’s global network of companies and partners to guarantee a high level of local service and product delivery.
Contact: info@schurter.com.sg
Website: www.schurter.com
  • schurter
  • choke
